[ Done! ] Translators please wait with the Draft pages
At the moment I am actively working on the documentation of the draft workbench, revising and updating. Sadly, despite adding {{Page_in_progress}}, a translator was unaware of this and has been translating OLD Draft pages at the same time.
Please give me some time, it is more work than I first thought, and wait with the Draft pages until I am finished.
Re: Translators please wait with the Draft pages
The first 19 pages have now been marked for translation. Note that I have used V0.20 while updating these pages.
Draft_Line
Draft_Wire
Draft_Fillet
Draft_Arc
Draft_Arc_3Points
Draft_Circle
Draft_Ellipse
Draft_Rectangle
Draft_Polygon
Draft_BSpline
Draft_CubicBezCurve
Draft_BezCurve
Draft_Point
Draft_Facebinder
Draft_ShapeString
Draft_Text
Draft_Dimension
Draft_Label
Draft_AnnotationStyleEditor
Draft_Line
Draft_Wire
Draft_Fillet
Draft_Arc
Draft_Arc_3Points
Draft_Circle
Draft_Ellipse
Draft_Rectangle
Draft_Polygon
Draft_BSpline
Draft_CubicBezCurve
Draft_BezCurve
Draft_Point
Draft_Facebinder
Draft_ShapeString
Draft_Text
Draft_Dimension
Draft_Label
thank you for the information and your work.
i would have prefer to stick to the 0.19 as it is the stable version for a while. i wish there are not too much differences between the 0.20 and 0.19. at the first glance the GUI is the same.
Due to our restricted resources we have to document the V0.20 version now. IMO there is no other option.
@Roy_043, a comment about https://wiki.freecadweb.org/Draft_Line#Options: The need to overwrite the values when using polar coordinates is no longer necessary.
Thanks for the information, and the fix. Can you give the PR number?marioalexis wrote: ↑Sun May 16, 2021 10:41 pm about https://wiki.freecadweb.org/Draft_Line#Options: The need to overwrite the values when using polar coordinates is no longer necessary.
Do we have to wait any longer? All the pages have been set to translate. The warning banner is still present.
