[ Done! ] Translators please wait with the Draft pages
david69
Re: Translators please wait with the Draft pages
Post by david69 »
can we remove?
Draft_Drawing
Draft_Array
edit: on some update/creation of pages, like Pattern or Constrain, you didn't put the GuiCommand. most of them are in the context but to me, it's like something is missing on the page. Is this intentional or an oversight?
Roy_043
Post by Roy_043 »
The Drawing WB is still part of FreeCAD that is why Draft_Drawing can't be deleted just yet. And the BIM WB still uses the Draft_Array command.
The Draft_Constrain page and Draft_Pattern page do not document commands. Including GuiCommand is then incorrect.
kaktus
Post by kaktus »
Roy_043
Post by Roy_043 »
kaktus wrote: Sat Aug 21, 2021 8:16 pm references to non-existent pages ...
I can't find them:
There is a link to the Draft_Drawing page, and that page still exists. So that is OK.
And the links to the Draft_AddPoint and Draft_DelPoint pages have been removed when these pages were deleted.
Roy_043
Post by Roy_043 »
kaktus wrote: Sat Aug 21, 2021 8:16 pm After the "cleanup" conducted, one valuable guide now has references to non-existent pages ...
https://wiki.freecadweb.org/Arch_tutorial
The tutorial is now quite old. Somebody has made an attempt to update it. But that was never completed:
https://wiki.freecadweb.org/Sandbox:TutorialArchBIM
david69
Post by david69 »
The Drawing WB is still part of FreeCAD...
, yes you are right.
i can see the wiki is still "moving" although Techdraw has been announced for a while as its replacement and the wiki itself claims it.
@Kunda1, can you remind why we keep Drawing, pls?
Roy_043
Post by Roy_043 »
Note that the following pages were marked for translation in the context of the Module-to-Workbench renaming operation. Please do not translate them just yet!
Draft_Module/Draft_Workbench (move has been initiated, but sometimes takes a long time).
Draft_Preferences
Draft_DXF
Draft_SVG
Draft_OCA
Draft_DAT
Roy_043
Post by Roy_043 »
Another set of pages can be translated:
Draft_Preferences
Draft_DXF
Draft_SVG
Draft_OCA
Draft_DAT
I have not changed much on the last 4 (file format) pages.
Note that the Docnav for these pages is non-standard. For example:
{{Docnav
|[[Draft_DXF|Autodesk .DXF .DWG]]
|[[Draft_OCA|Open Cad format .OCA]]
|[[Draft_Module|Draft]]
|IconL=
|IconR=
|IconC=Workbench_Draft.svg
Previous editors already used this. I think it is a good solution and I have only fixed some inconsistencies.
What remains now are the Draft_Workbench page and the "navi". So almost there...
Roy_043
Post by Roy_043 »
kaktus
Re: [ Done! ] Translators please wait with the Draft pages
Post by kaktus »
Can you provide some information on what the template update consisted of?
