The Code template (https://wiki.freecadweb.org/Template:Code) triggers a "Pages using deprecated enclose attributes" warning. This warning appears since the recent wiki software update.
I cannot fix this because AppImage is protected with the "cascading" option turned on. This means that all templates used on that page are also protected.
Issue with Code template
Re: Issue with Code template
I've seen this as well. The AppImage wiki page is protected due to it being a traffic heavy download page. What do you need to fix on it?
It is not the AppImage page, it is the code template that needs to be fixed.
So what do you need me to do specically?
If you can change the protection of the AppImage so that (most of) the 12 templates used on that page are not locked, I would be able to edit the code template.
Done. The permissions expire in 1 week.
Thanks.
Removing |enclose="div" from https://wiki.freecadweb.org/Template:Code fixed the problem. There do not seem to be adverse side-effects. The HTML produced by the modified template is the same.
