[In progress] About modules and workbenches in wiki.
kaktus
Re: [In progress] About modules and workbenches in wiki.
Post by kaktus »
adrianinsaval wrote: Wed Sep 01, 2021 1:25 am
well recently this module has been split leaving the workbench part of it as an external addon but the core of the module in master https://github.com/FreeCAD/FreeCAD/pull/4971
should there be separate pages for each or just a clarification in the page?
Thanks for the explanation. :D
You just got to the bottom of my question.
While working on the translation of the Plot module page, I began to have doubts ...
https://wiki.freecadweb.org/Plot_Module
... which you have confirmed.
In reference to the information you provided, I believe that there should be open information provided in relation to this work environment.
Maybe making changes to the existing page will be sufficient, but I don't know if that is in line with the existing FreeCAD wiki rules. :roll:
Roy_043
Post by Roy_043 »
Hurray!! The hard graft has been done. Thanks @heda for the epic collaboration!
Some minor loose ends remain:
Renaming the Part_Module and the TechDraw_Module.
The Plot_Module.
The side bar.
I have initiated the renaming of the TechDraw_Module just now and have posted a message to that effect in the Help forum: https://forum.freecadweb.org/viewtopic.php?f=3&t=61969
Maybe we won't have the same issue as with the Part_Module.
Roy_043
Post by Roy_043 »
TechDraw_Module has been renamed and new redirects (Module->Workbench) have been created.
Roy_043
Post by Roy_043 »
I have initiated the renaming of the Part_Module:
https://forum.freecadweb.org/viewtopic.php?f=3&t=62031
This is the 6th attempt... So fingers crossed...
Roy_043
Post by Roy_043 »
Well, that did not work, again...
Renaming the Part_Module page is blocked for some reason.
Can somebody shed some light here please?
Kunda1 wrote: pinged by pinger macro
kkremitzki wrote: pinged by pinger macro
Post by Kunda1 »
it needs to be renamed along with all it's translation pages, right?
Evgeniy
Post by Evgeniy »
Maybe is possible to make py script by pyWikibot?
e.g.
text = text.replace("[[Part_Module/","[[Part_Workbench/")
text = text.replace("[[Part Module/","[[Part_Workbench/")
text = text.replace("[[Part_Module|","[[Part_Workbench|")
text = text.replace("[[Part Module|","[[Part_Workbench|")
(this is only example)
Roy_043
Post by Roy_043 »
Kunda1 wrote: Wed Sep 08, 2021 1:50 pm it needs to be renamed along with all it's translation pages, right?
Yes of course.
Note that I was forced to recreate the redirects. But before initiating the rename operations I have always deleted them.
While the issue with the Part_Module existed I was able to rename the Sketcher_Module page. So it is somehow related to the Part_Module page. Maybe the number of pages involved (1000+, each translation unit is a separate page) is causing the problem?
Roy_043
Post by Roy_043 »
Evgeniy wrote: Wed Sep 08, 2021 2:55 pm Maybe is possible to make py script by pyWikibot?
We are past that stage by now: Rename_Module_to_Workbench.
Post by Kunda1 »
@Roy_043 so Part Workbench pages already exist. So I'm just adding a redirect from Part Module and all their translation pages? i.e erasing the contents of the page and adding:
#REDIRECT [[Part Workbench]]
Correct?
Roy_043 wrote: Wed Sep 08, 2021 3:33 pm While the issue with the Part_Module existed I was able to rename the Sketcher_Module page. So it is somehow related to the Part_Module page. Maybe the number of pages involved (1000+, each translation unit is a separate page) is causing the problem?
Can you elaborate what you mean? Are you trying to figure out why you aren't successfully able to rename Part_Module?
