[In progress] About modules and workbenches in wiki.
Roy_043
Re: [In progress] About modules and workbenches in wiki.
Post by Roy_043 »
@Kunda1
In addition:
On the Donate Page there are two links that need updating:
[[Draft_Module|Draft]] -> [[Draft_Workbench|Draft]]
[[Arch_Module|Arch]] -> [[Arch_Workbench|Arch]]
Regarding the Left bar on the Wiki: It is in dire need of some TLC... But that is a different topic.
Roy_043
Post by Roy_043 »
heda wrote: Tue Aug 24, 2021 11:11 pm something the framework should cope with
This is already possible:
[[Draft_Workbench{{#translation:}}|Draft Workbench]]
Here is a page where you can test things without creating a temporary Sandbox page:
https://wiki.freecadweb.org/Special:ExpandTemplates
In the Context title box enter (f.e.):
/it
In the Input wikitext box enter:
Press the OK button.
Repeat the same experiment with a non-existing language, f.e. /xy.
heda
Post by heda »
TechDraw ready to flush.
take your word for it, dunno much about inner workings of wiki - but did find an extension that mentioned addresses like www.fr.wiki.freecadweb.org
Roy_043
Post by Roy_043 »
heda wrote: Thu Aug 26, 2021 7:30 pm TechDraw ready to flush.
Thanks you!
I will wait with renaming the page, there seems to be an issue with that at the moment.
https://forum.freecadweb.org/viewtopic. ... 84#p527577
heda
Post by heda »
part module ready for flush
btw, could it be that the move failed because there currently are two part wb redirects, "Part Workbench" & "Part workbench".
can imagine that this could be the case if not both of them were deleted, so when you initiate the move there is still one left that blocks the move.
Roy_043
Post by Roy_043 »
heda wrote: Sat Aug 28, 2021 6:10 am could it be that the move failed because there currently are two part wb redirects
If you fail to remove a redirect that is blocking the move you are informed of this by the software. So I think that is unlikely.
heda
Post by heda »
imho the small caps link should be deleted anyway (it had some tenths of links to it) and software sometimes behaves in mysterious ways :-) have no idea if it is the tripping point here, if nothing else, could be worth a try - that's all.
Roy_043
Post by Roy_043 »
OK, why not. After deleting 21 redirects: the 5th attempt. Fingers crossed...
Roy_043
Post by Roy_043 »
No success I am afraid. I have recreated the redirects...
heda
Post by heda »
clearly it did not work this time either - bummer - only idea I have left is to start moving language by language first and last do the actual page (if that is even possible) - that possibly could be a hint of where the tripping point is - reducing the search-space to find out what it is. there are some 16k links related to part wb.
or could be that the db somehow is corrupt on these pages, or that the earlier runs still lie and block further batching (which cannot be true in general since both you and me made some moves yesterday, but could be true for these pages).
there has to be log-files somewhere (assuming that some sort of logging is turned on), so as you said, it is up to admins to chase this down now.
not trying to make people depressed, but I summed number of remaining entries to change (listings from what links here), and came to 8k, of that we have to do at least half, so lets say 60% that means close to 5k links still to be changed :-)
the podium positions if taken by language is italy, france and russia :geek:
I will continue to grind away on it until it is finished, but not spend as much time on it as I did the last week.
