[In progress] Autotranslate Template for [[#top|top]]
Roy_043
Re: Autotranslate Template for [[#top|top]]
Post by Roy_043 »
Yes, The text in my previous was already added to that page. Why do think this is not enough?
kaktus
Post by kaktus »
Maybe it is worth to add information, that template will insert proper text in supported languages without any additional intervention.
Someone may proceed "automatically" and apply it as written:
{{top|"top"}}
which is unnecessary because you have automated this template nicely. :P
Evgeniy
Post by Evgeniy »
Roy_043 wrote: Fri Aug 27, 2021 11:24 am I was able to create a single template for all languages:
https://wiki.freecadweb.org/Template:Top
You can check if the Russian text is OK.
I test it there:
https://wiki.freecadweb.org/Special:ExpandTemplates
All works fine.
tags <p> </p> is sure needs?
and i look template inside
Why top from capital letter?
Previously, it seemed to be with a small one...
We can try to make an experiment on tag integration. For example, on this pages:
https://wiki.freecadweb.org/Path_FAQ
https://wiki.freecadweb.org/Python_scripting_tutorial
https://wiki.freecadweb.org/PySide
https://wiki.freecadweb.org/Mesh_Scripting
Probably after integration, needs to somehow delete unused translations to free up wikipedia's memory.
What about add squre brackets around top link in template? [top] to highlight this link.
Or this is bad idea?
Roy_043
Re: [In progress] Autotranslate Template for [[#top|top]]
Post by Roy_043 »
Evgeniy wrote: Sat Aug 28, 2021 7:09 pm tags <p> </p> is sure needs?
It is necessary if you put the wiki code on a single line:
</translate>{{Top}}<translate>
But not if you do this:
</translate>
{{Top}}
<translate>
Since I wanted to allow for both situations I have decided to add these tags.
There is already a page where I have tested the template:
Topological_data_scripting
Roy_043
Post by Roy_043 »
Evgeniy wrote: Sat Aug 28, 2021 7:09 pm What about add squre brackets around top link in template? [top] to highlight this link.
Square brackets have a specific function in wiki code. So, yes, this is a bad idea. :mrgreen:
Evgeniy
Post by Evgeniy »
Roy_043 wrote: Sun Aug 29, 2021 7:54 am
What about &#91; &#93; ?
<p>&#91;[[#top|{{#switch:{{#translation:}}
|/bg=Top
|/cs=Top
|/zh-hant=Top
|/zh-tw=Top
|Top}}]]&#93;</p><noinclude>
https://wiki.freecadweb.org/Topological ... ing/ru#top
Evgeniy
Post by Evgeniy »
Roy_043 wrote: Sun Aug 29, 2021 7:52 am There is already a page where I have tested the template:
The number of top tags in this page is excessive. In a simple example of creating a slot form, as seven times...
kaktus
Post by kaktus »
Evgeniy wrote: Sun Aug 29, 2021 8:47 am
Evgeniy, I would like to ask you to clarify this for me.
What is the purpose of the control characters, or can you provide a document with a specification to refer to :?:
Evgeniy
Post by Evgeniy »
kaktus wrote: Sun Sep 05, 2021 5:23 am Evgeniy, I would like to ask you to clarify this for me.
A similar style is used in other wikis.
https://en.wikipedia.org/wiki/Template:Go_to_top
This link differs in that it does not lead to any page, but simply scrolls page to up.
Therefore, it probably makes sense to take it in brackets to highlight it.
kaktus
Post by kaktus »
Thank you for your answer, 8-) do you see any advantages compared to the template prepared by Roy :?:
For me Roy's template is excellent.
