Then everything is ok.
[In progress] Autotranslate Template for [[#top|top]]
Re: Autotranslate Template for [[#top|top]]
Yes that is how the system work. I never really thought about this until now. We are using it only for the categories at the bottom of the page, but {{#translation:}} can be used anywhere.
{{Docnav{{#translation:}} }}
{{GuiCommand{{#translation:}} }}
See also here:
https://forum.freecadweb.org/viewtopic. ... 17#p527617
To use a Top template the Wiki code would look like this I suppose:
</translate>{{Top{{#translation:}}}}<translate>
I understand that this will be converted to:
{{Top/en}}
{{Top/ru}}
{{Top/it}}
etc...?
It is quite good.
When the english variant of template is be complete, I will make a translation into my own language.
And needs to update at least one page with a new template for check how it works.
no no no ...
The syntax must be as Roy wrote.
Everything happens "automatically".
I was able to create a single template for all languages:
https://wiki.freecadweb.org/Template:Top
You can check if the Russian text is OK.
The code to use is:
If you replace [[#top|top]] you should also remove the translation tag above it:
Becomes:
The code to use is:
</translate>{{Top}}<translate>
<!--T:nn-->
[[#top|top]]
It works perfectly.
Edit:
It would be good to improve the description on the page. https://wiki.freecadweb.org/WikiPages#Links
I'll explain,
at https://wiki.freecadweb.org/WikiPages
we have a prepared description for writers and translators, with templates and with examples of their use.
We have a new version of one template, so it's worth writing about, the syntax of how to use it has changed.
