Wiki commands pages and it not correct names
Evgeniy
Post by Evgeniy »
FreeCAD 0.20.25 not have https://wiki.freecadweb.org/Part_Attachment but have Part_EditAttachment
Page needs to renamed to Part_EditAttachment
>>> Gui.runCommand("Part_Attachment")
Base.FreeCADError: No such command 'Part_Attachment'
>>> Gui.runCommand("Part_EditAttachment")
Roy_043
Re: Part_Attachment -> Part_EditAttachment
Post by Roy_043 »
Thanks for reporting this.
The page has been renamed.
Redirects were created.
The Template:Part Tools navi pages were updated.
Links in English pages were fixed.
Evgeniy
Post by Evgeniy »
Roy_043 wrote: Fri Sep 03, 2021 9:48 am Thanks for reporting this.
Ok!
Evgeniy
Post by Evgeniy »
TechDraw wiki pages have many not real names...
Perhaps user hwo makes this pages not think about commands name.
The inconsistencies are listed in the same order as on this page https://wiki.freecadweb.org/TechDraw_Module
TechDraw_Dimension_Length-> TechDraw_LengthDimension
TechDraw_Dimension_Horizontal -> TechDraw_HorizontalDimension
TechDraw_Dimension_Vertical -> TechDraw_VerticalDimension
TechDraw_Dimension_Radius -> TechDraw_RadiusDimension
TechDraw_Dimension_Diameter -> TechDraw_DiameterDimension
TechDraw_Dimension_Angle -> TechDraw_AngleDimension
TechDraw_Dimension_Angle3Pt -> TechDraw_3PtAngleDimension
TechDraw_Dimension_Horizontal_Extent -> TechDraw_HorizontalExtentDimension
TechDraw_Dimension_Vertical_Extent -> TechDraw_VerticalExtentDimension
TechDraw_Dimension_Landmark -> TechDraw_LandmarkDimension
Gui.runCommand("TechDraw_Dimension_Length")
Gui.runCommand("TechDraw_LengthDimension")
Gui.runCommand("TechDraw_Dimension_Horizontal")
Gui.runCommand("TechDraw_HorizontalDimension")
Gui.runCommand("TechDraw_Dimension_Vertical")
Gui.runCommand("TechDraw_VerticalDimension")
Gui.runCommand("TechDraw_Dimension_Radius")
Gui.runCommand("TechDraw_RadiusDimension")
Gui.runCommand("TechDraw_Dimension_Diameter")
Gui.runCommand("TechDraw_DiameterDimension")
Gui.runCommand("TechDraw_Dimension_Angle")
Gui.runCommand("TechDraw_AngleDimension")
Gui.runCommand("TechDraw_Dimension_Angle3Pt")
Gui.runCommand("TechDraw_3PtAngleDimension")
Gui.runCommand("TechDraw_Dimension_Horizontal_Extent")
Gui.runCommand("TechDraw_HorizontalExtentDimension")
Gui.runCommand("TechDraw_Dimension_Vertical_Extent")
Gui.runCommand("TechDraw_VerticalExtentDimension")
Gui.runCommand("TechDraw_Dimension_Landmark")
Gui.runCommand("TechDraw_LandmarkDimension")
Result:
Base.FreeCADError: No such command 'TechDraw_Dimension_Length'
Base.FreeCADError: No such command 'TechDraw_Dimension_Horizontal'
Base.FreeCADError: No such command 'TechDraw_Dimension_Vertical'
Base.FreeCADError: No such command 'TechDraw_Dimension_Radius'
Base.FreeCADError: No such command 'TechDraw_Dimension_Diameter'
Base.FreeCADError: No such command 'TechDraw_Dimension_Angle'
Base.FreeCADError: No such command 'TechDraw_Dimension_Angle3Pt'
Base.FreeCADError: No such command 'TechDraw_Dimension_Horizontal_Extent'
Base.FreeCADError: No such command 'TechDraw_Dimension_Vertical_Extent'
Base.FreeCADError: No such command 'TechDraw_Dimension_Landmark'
Roy_043
Re: Wiki commands pages and it not correct names
Post by Roy_043 »
There is currently a discussion about the names of new TechDraw commands. This may also have an effect on existing names. I am not sure. My suggestion is to wait with the renaming of these pages for now.
Roy_043
Post by Roy_043 »
Evgeniy wrote: Sat Sep 04, 2021 9:38 am TechDraw_Dimension_Length-> TechDraw_LengthDimension
Another:
TechDraw_Dimension_Link -> TechDraw_LinkDimension
These 11 pages have now been renamed.
Redirects are in place
Links on the English pages were fixed.
https://wiki.freecadweb.org/Template:Te ... Tools_navi was updated. The 18 untranslated language versions now redirect to this navi.
The following 'navis' need to be updated by translators:
https://wiki.freecadweb.org/Template:Te ... ls_navi/de
https://wiki.freecadweb.org/Template:Te ... ls_navi/fr
https://wiki.freecadweb.org/Template:Te ... ls_navi/it
https://wiki.freecadweb.org/Template:Te ... ls_navi/pl
Note that the new "Extension Package tools" have yet to be added to the navi. These are still very new and I understand the programmer intends to add more in the near future.
Evgeniy
Post by Evgeniy »
Ok.
Roy_043
Post by Roy_043 »
Evgeniy wrote: Thu Sep 16, 2021 2:27 pm Ok. I have already translated them "Docnav".
What do you mean?
Evgeniy
Post by Evgeniy »
Roy_043 wrote: Thu Sep 16, 2021 3:42 pm
What do you mean?
This is be misprint
