$ python3 pwb.py login
ERROR: An error occurred for uri https://wiki.freecadweb.org/api.php?action=query&meta=siteinfo%7Cuserinfo&siprop=namespaces%7Cnamespacealiases%7Cgeneral&continue=&uiprop=blockinfo%7Chasmsg&maxlag=5&format=json
ERROR: Traceback (most recent call last):
File "/home/luzpaz/core/pywikibot/data/api.py", line 1488, in _http_request
data=data, headers=headers)
File "/home/luzpaz/core/pywikibot/tools/_deprecate.py", line 404, in wrapper
return obj(*__args, **__kw)
File "/home/luzpaz/core/pywikibot/comms/http.py", line 263, in request
r = fetch(baseuri, headers=headers, **kwargs)
File "/home/luzpaz/core/pywikibot/comms/http.py", line 425, in fetch
callback(response)
File "/home/luzpaz/core/pywikibot/comms/http.py", line 308, in error_handling_callback
raise response from None
File "/home/luzpaz/core/pywikibot/comms/http.py", line 418, in fetch
**kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='wiki.freecadweb.org', port=443): Max retries exceeded with url: /api.php?action=query&meta=siteinfo%7Cuserinfo&siprop=namespaces%7Cnamespacealiases%7Cgeneral&continue=&uiprop=blockinfo%7Chasmsg&maxlag=5&format=json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f9b5a194828>: Failed to establish a new connection: [Errno 111] Connection refused'))
WARNING: Waiting 5.0 seconds before retrying.
callback(response)
**kwargs)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='wiki.freecadweb.org', port=443): Max retries exceeded with url: /api.php?action=query&meta=siteinfo%7Cuserinfo&siprop=namespaces%7Cnamespacealiases%7Cgeneral&continue=&uiprop=blockinfo%7Chasmsg&maxlag=5&format=json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f9b5a1949b0>: Failed to establish a new connection: [Errno 111] Connection refused'))
WARNING: Waiting 10.0 seconds before retrying.
^CTraceback (most recent call last):
File "pwb.py", line 414, in <module>
if not main():
File "pwb.py", line 409, in main
module)
File "pwb.py", line 107, in run_python_file
main_mod.__dict__)
File "./scripts/login.py", line 151, in <module>
main()
File "./scripts/login.py", line 139, in main
site.login(autocreate=autocreate)
File "/home/luzpaz/core/pywikibot/site/_apisite.py", line 358, in login
if self.userinfo['name'] == self.user():
File "/home/luzpaz/core/pywikibot/site/_apisite.py", line 465, in userinfo
uidata = uirequest.submit()
File "/home/luzpaz/core/pywikibot/data/api.py", line 1739, in submit
self._add_defaults()
File "/home/luzpaz/core/pywikibot/data/api.py", line 1245, in _add_defaults
and self.site.mw_version >= '1.25wmf5'):
File "/home/luzpaz/core/pywikibot/site/_apisite.py", line 953, in mw_version
mw_ver = MediaWikiVersion(self.version())
File "/home/luzpaz/core/pywikibot/site/_apisite.py", line 929, in version
version = self.siteinfo.get('generator', expiry=1).split(' ')[1]
File "/home/luzpaz/core/pywikibot/site/_siteinfo.py", line 296, in get
preloaded = self._get_general(key, expiry)
File "/home/luzpaz/core/pywikibot/site/_siteinfo.py", line 237, in _get_general
default_info = self._get_siteinfo(props, expiry)
File "/home/luzpaz/core/pywikibot/site/_siteinfo.py", line 162, in _get_siteinfo
data = request.submit()
File "/home/luzpaz/core/pywikibot/data/api.py", line 2021, in submit
self._data = super().submit()
File "/home/luzpaz/core/pywikibot/data/api.py", line 1758, in submit
paramstring)
File "/home/luzpaz/core/pywikibot/data/api.py", line 1510, in _http_request
self.wait()
File "/home/luzpaz/core/pywikibot/data/api.py", line 1892, in wait
pywikibot.sleep(delay)
File "/home/luzpaz/core/pywikibot/__init__.py", line 1287, in sleep
time.sleep(secs)
KeyboardInterrupt
CRITICAL: Exiting due to uncaught exception <class 'KeyboardInterrupt'>
luzpaz@fra2:~/core$ python3 pwb.py version
Pywikibot: [https] r-pywikibot-core.git (2cf9bd1, g15361, 2021/08/30, 13:18:55, master)
Release version: 6.6.0.dev0
setuptools version: 40.8.0
mwparserfromhell version: 0.5.2
wikitextparser version: n/a
requests version: 2.21.0
cacerts: /etc/ssl/certs/ca-certificates.crt
certificate test: ok
Python: 3.7.3 (default, Jan 22 2021, 20:04:44)
[GCC 8.3.0]
PYWIKIBOT_DIR: Not set
PYWIKIBOT_DIR_PWB:
PYWIKIBOT_NO_USER_CONFIG: Not set
Config base dir: /home/luzpaz/core
Usernames for family "freecad":
en: Kunda1
PrzemoF wrote:ping
