Macros for generation properties list of active object
Roy_043
Re: Macros for generation properties list of active object
Post by Roy_043 »
Hmm...
>>> obj.getAllDerivedFrom()
['Part::FeaturePython']
Seems useful to me... (obj is Draft_PolarArray).
Or:
>>> box.isDerivedFrom("Part::Primitive")
True
Evgeniy
Post by Evgeniy »
Roy_043 wrote: Thu Sep 09, 2021 4:47 pm Hmm...
Or:
True
But if create Part::Sphere in Part worckbench. Select it and run. Method is return:
sel = FreeCADGui.Selection.getSelection()
obj = FreeCAD.ActiveDocument.getObject(sel[0].Name)
>>> ['Part::Sphere']
This function looks as "Captain Obvious"
if create Strucure in Arch worckbench its return:
But then from where do the IFC properties comes? That are inherited from some unnamed Python class ...
This method does not explain many things...
Roy_043
Post by Roy_043 »
Yes, I agree it is confusing.
Roy_043
Post by Roy_043 »
Note that the solution adopted in Macro_Wiki_Object_Properties_List_Generator is problematic. F.e. a Draft_Text does not inherit the Placement property, but your code will identify it as such.
Evgeniy
Post by Evgeniy »
Roy_043 wrote: Fri Sep 10, 2021 9:30 am Note that the solution adopted in Macro_Wiki_Object_Properties_List_Generator is problematic. F.e. a Draft_Text does not inherit the Placement property, but your code will identify it as such.
im update sorce code in https://wiki.freecadweb.org/Macro_Wiki_ ... _Generator
Can you show me report of selected object for i understand what you mean?
Roy_043
Post by Roy_043 »
Placement inherited from classPartDesign::Body is clearly wrong. A Draft_Text does not inherit anything from PartDesign::Body and, as already mentioned, the Placement property is not inherited:
https://github.com/FreeCAD/FreeCAD/blob ... ext.py#L54
10:28:25
==Properties==
10:28:25
===View===
10:28:25
DisplayMode inherited from classPartDesign::Body
LineColor inherited from classPartDesign::Body
LineWidth inherited from classPartDesign::Body
OnTopWhenSelected inherited from classPartDesign::Body
SelectionStyle inherited from classPartDesign::Body
ShowInTree inherited from classPartDesign::Body
Visibility inherited from classPartDesign::Body
10:28:25
* {{PropertyView|Proxy|PythonObject}}:
10:28:25
{{TitleProperty|Annotation}}
10:28:25
* {{PropertyView|AnnotationStyle|Enumeration}}: Annotation style to apply to this object.
When using a saved style some of the view properties will become read-only;
they will only be editable by changing the style through the 'Annotation style editor' tool.
10:28:25
* {{PropertyView|ScaleMultiplier|Float}}: General scaling factor that affects the annotation consistently
because it scales the text, and the line decorations, if any,
in the same proportion.
10:28:25
{{TitleProperty|Text}}
10:28:25
* {{PropertyView|FontName|Font}}: The font of the text
10:28:25
* {{PropertyView|FontSize|Length}}: The size of the text
10:28:25
* {{PropertyView|Justification|Enumeration}}: The vertical alignment of the text
10:28:25
* {{PropertyView|LineSpacing|Float}}: Line spacing (relative to font size)
10:28:25
* {{PropertyView|TextColor|Color}}: Text color
10:28:25
===Data===
10:28:25
ExpressionEngine inherited from classPartDesign::Body
Label inherited from classPartDesign::Body
Label2 inherited from classPartDesign::Body
10:28:25
* {{PropertyData|Proxy|PythonObject}}:
10:28:25
{{TitleProperty|Base}}
10:28:25
* {{PropertyData|Text|StringList}}: The text displayed by this object.
It is a list of strings; each element in the list will be displayed in its own line.
Evgeniy
Post by Evgeniy »
As far as I know, FreeCAD does not currently have tools to determine whether a property is inherited from or added.
Making a list manually is not a grateful thing. Since everything is very difficult to track.
The property can also be added, and then it is not inherited, but it can be used many times.
I think the algorithm in the form in which it is performs most of the task.
Roy_043
Post by Roy_043 »
Evgeniy wrote:Ping
You have created at least 4 pages and one template while experimenting with this. Some of them can be deleted I think.
The procedure involved has already been pointed out to you:
https://wiki.freecadweb.org/WikiPages#D ... _and_pages
Evgeniy
Post by Evgeniy »
Roy_043 wrote: Sun Sep 19, 2021 10:41 am You have created at least 4 pages and one template while experimenting with this. Some of them can be deleted I think.
What four pages are you talking about?
The template that was used for testing can be deleted.
