Sketcher, CreatePoint
Gift
Post by Gift »
The Limitations are not up-to-date. Sketcher_CreatePoint. See this commit. I'm not native speaker. So, only a draft:
v0.19.2 and above: Select a point and invoke the Sketcher ToggleConstruction tool to set the point available outside of the sketch.
Reason was this german topic. There is a video available.
kind regards
Benjamin
Roy_043
Re: Sketcher, CreatePoint
Post by Roy_043 »
Thanks for mentioning this. I have updated the page.
adrianinsaval
Post by adrianinsaval »
Roy_043 wrote: Wed Nov 10, 2021 10:40 am Thanks for mentioning this. I have updated the page.
shouldn't you mention from what version onwards this is possible? or is the policy to keep the documentation in reference to the current version only?
Roy_043
Post by Roy_043 »
Only when describing a dev version feature do you need to specify the version.
adrianinsaval
Are the references to the dev version number then removed once it gets released?
Roy_043
Post by Roy_043 »
I don't think there is a rule for this. I would remove references to V0.19 when V0.20 is released.
Roy_043
Post by Roy_043 »
adrianinsaval wrote: Wed Nov 10, 2021 12:26 pm shouldn't you mention from what version onwards this is possible?
Looking at this again I see that most features introduced in V0.19 do mention the version. So it is more consistent to do that here as well. Sorry for the confusion.
Gift
Post by Gift »
Thank you very much.
adrianinsaval
added as a note in Sketcher_ToggleConstruction too
Roy_043 wrote:
can you check that I didn't do anything silly and somehow broke translations or something :? I'm not very experienced with the wiki
Roy_043
Post by Roy_043 »
Looks fine. Thanks! :)
