Hi to all,
if I upload the two icons
in wiki, they are empty.
The files can be used without problems in the FreeCAD source code, and can be opened in InkScape.
The first icon is used in https://wiki.freecadweb.org/TechDraw_Workbench and https://wiki.freecadweb.org/TechDraw_Ex ... nDimension
Who can help me ?
Uploaded icons are empty
Re: Uploaded icons are empty
Through trial and error (so I do not know why this works): You need to remove style="filter:url(#filter1958)".
This:
Should be:
This:
<g
inkscape:label="Livello 1"
inkscape:groupmode="layer"
id="layer1"
transform="translate(0,-288.53332)"
style="filter:url(#filter1958)">
<g
id="layer1"
transform="translate(0,-288.53332)">
@Roy_043: Thank you for your help.
Unfortunately I have the next problem: I cannot replace/overload the old (empty) file with the new file. Trying this I receive the message: both files are the same.
I created new files, having an _ (underline) at the end. That works, but is no good solution.
Is it possible to delete and/or rename existing files in wiki ?
Renaming is not possible. And to delete a file you need additional permissions. I was able to overwrite the files. But I also corrected the sodipodi:docname, so maybe that fooled the Wiki software. I have deleted the two files ending in _.
