wiki Main page - sidebar
kaktus
Re: wiki Main page - sidebar
Post by kaktus »
Helooo
I have some problems I can't solve on my own ...
  1. RSS feeds
    The page has been removed - perhaps it is worth deleting this item from the sidebar?
    https://wiki.freecadweb.org/Syndication_feeds
  2. External workbenches
    I tried to do the localization, but I couldn't find the corresponding MediaWiki:Sidebar-* pages either.
    I intuitively created the appropriate pages - no result :roll:
  3. Links -> Interesting links
    situation similar to case 2.
  4. Manual
    site
    https://wiki.freecadweb.org/MediaWiki:S ... -target/pl
    has contents
    Manual
    when I add the language tag [/pl] the redirection stops working
    receives a message about a non-existent site
kaktus
Post by kaktus »
Thanks Roy for correcting my errors.
The following page lists the sites and descriptions in the menu.
https://wiki.freecadweb.org/MediaWiki:Sidebar
It is very helpful for translation. :idea:
How should I treat spaces in in multiword names?
In documents I have edited, I have intuitively replaced them with "_".
Roy_043
Post by Roy_043 »
Somehow I now have access to this part of the Wiki as well. :mrgreen:
#1
Thanks. Removed.
#2 and #3
As you have already found out: open the MediaWiki:Sidebar page for editing:
https://wiki.freecadweb.org/index.php?t ... ction=edit
And look for the correct item, for example:
** {{int:Sidebar-addons-target}}|Sidebar-addons
This gives you the names of the pages involved.
#4
The English link relied on a redirect that does not exist for the Polish language.
I have updated:
https://wiki.freecadweb.org/MediaWiki:S ... ual-target
https://wiki.freecadweb.org/MediaWiki:S ... -target/it
Roy_043
Post by Roy_043 »
kaktus wrote: Sat Jan 22, 2022 1:22 pm In documents I have edited, I have intuitively replaced them with "_"
For the "target" files both spaces and underscores are allowed.
Roy_043
Post by Roy_043 »
There are some overdue maintenance issues related to the side bar. Two spring to mind: the "Module" to "Workbench" renaming effort and the problem with the FAQ page. I'll try to fix those.
kaktus
Post by kaktus »
:mrgreen:
Polish sidebar taken care of.
Thank you all for your commitment, especially our Yorik, who has a lot of tasks and you Roy for fixing problems.
david69
Post by david69 »
to translate the sidebar, I have started from this page https://wiki.freecadweb.org/MediaWiki:Sidebar-messages.
one by one, I have checked the sidebar object in order to translate but it appears the page is somehow a bit desorganized and some sidebar-links are missing or obsolete or links to wiki pages are not consistent.
I have tried to put all together my observations in the spreadsheet.
First tab, on the left side, we find screenshots of the sidebar. I have noted if the link was present in the page https://wiki.freecadweb.org/MediaWiki:Sidebar-messages with a red mark. Then I copied pasted all the sidebar-links and also the sidebar-links-target. The arrangement is not in line with what we see on the page.
The second tab is for the missing sidebar-link in the page https://wiki.freecadweb.org/MediaWiki:Sidebar-messages. May be they should be added for some of them.
I have also checked to which page we go when we click on the shorcuts of the sidebar and sometimes, I think the link can be updated.
sidebar wiki.ods
checking sidebar
(77.54 KiB) Downloaded 75 times
Roy_043
Post by Roy_043 »
david69 wrote: Sat Jan 22, 2022 5:56 pm to translate the sidebar, I have started from this page https://wiki.freecadweb.org/MediaWiki:Sidebar-messages.
Why? Where is this used/displayed?
AFAIK you should start here:
david69
Post by david69 »
because I read it in previous post of Yorik:
- By https://forum.freecadweb.org/viewtopic. ... =10#p80441 the page https://wiki.freecadweb.org/MediaWiki:Sidebar-messages needs to be updated with all the items in the sidebar. Indeed sidebar-workbenches is missing there. As a test, I just added sidebar-workbenches at the bottom now.
- Now is the problem, we should now go to http://www.freecadweb.org/wiki/index.ph ... ki-sidebar and normally we should be able to translate our new item, but I don't see anything?
this link https://wiki.freecadweb.org/MediaWiki:Sidebar-messages
your link is easier to understand and in line with what we read. I'll check it. thank you.
Shalmeneser
Post by Shalmeneser »
What a beauty ! :D
Capture d’écran 2022-02-06 171133.png (28.63 KiB) Viewed 3198 times
