[Draft] Development Environment for Python
piffpoof
Re: [Draft] Development Environment for Python
Post by piffpoof »
Yes, that seems to work. Do you know if when a binary file is uploaded to be a gist, is there a limit on which file types (extensions) are accepted? What I mean is, could a standard FreeCAD document file (e.g. file.FCStd) be uploaded to become a binary gist?
thanks
cox
Post by cox »
piffpoof wrote: could a standard FreeCAD document file (e.g. file.FCStd) be uploaded to become a binary gist?
thanks
Smal
https://gist.github.com/kkoksvik/5a0bd5 ... w/d2.fcstd
EDIT:(Test of binary version control)
Big over 4 MB Original Link tracking spesific version of file
https://gist.github.com/kkoksvik/5a0bd5 ... 20mm.fcstd
Changed approx 3.3MB Link tracking latest file
There is no way, as far as I can see to add binary files via normal web interface.
Use git client on your pc to add binary files.
PS: Thanks to Juan Gonzalez Gomez https://plus.google.com/+JuanGonzalezGo ... ubEd4wLoQ4 for this nice part
piffpoof
Post by piffpoof »
cox wrote: Small
thanks for the test links to the gist files, they all worked perfectly here on v0.14 on Mac OS X using right-click 'Save File As' to download them.
Very nice drawings.
piffpoof
Post by piffpoof »
cox wrote: There is no way, as far as I can see to add binary files via normal web interface.
In git, where in the interface is the option to "add binary file"? Clicking "add file" seems to simply add another paste window on the screen.
I've created a gist for Python script at Python Assistant Window which seems to work OK, but can't figure out how to do the same with a binary file.
thanks
[edit]
I should say that I know virtually nothing about git, and what I know is on the page git for users which is supposed to be documentation for casual users of git
if I can get it figured out how to use gist for binary files then I can write it up for people to use on the Wiki pages.
cox
Post by cox »
I am unfamiliar with mac and git Gui. But i would try to
1 clone the Github repo to your disk
2 add binary file to the local folder containing the repo. Use your filemanager(finder?)
3 Use syncronice command from Gui.
What is a paste window?
piffpoof wrote:I've created a gist for Python script at Python Assistant Window which seems to work OK
The link to your script is pointing to a spesific version of it. To link to the newest version even after a version change remove the version information witch is the long number between /raw/ and /Python Assistant Window/
  • /raw/bdc7bf37a1f81dceda3f08ff0bb6d00688506a98/Python Assistant Window
This way you will not need to edit web pages or documentation when changes are made to scripts or other files in git. If people need to have a look at old revisions they can do so on github.
mario52
Post by mario52 »
hi
piffpoof wrote:I've created a gist for Python script at Python Assistant Window which seems to work OK, but can't figure out how to do the same with a binary file.
may be because it for free formula that must be open code ??
mario
cox
Post by cox »
mario52 wrote:may be because it for free formula that must be open code ??
I have free acount. The limit is that you have to use your git client to be able to add binary files.
This is how I did it
EDIT(added git add -A)
In some folder test
git clone git@gist.github.com:/735fee0727a038425a11.git
cd 735fee0727a038425a11
cp /home/username/somebinaryfile.bin .
git add -A
git commit
git push
Your binary file is uploaded to the gist
piffpoof
Post by piffpoof »
cox wrote:This is how I did it
In some folder test
git commit -a
git push
I had some error messages as follows:
generated:
Cloning into '735fee0727a038425a11'...
The authenticity of host 'gist.github.com (192.30.252.140)' can't be established.
RSA key fingerprint is 16:27:ac:a5:76:28:2d:36:63:1b:56:4d:eb:df:a6:48.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added 'gist.github.com,192.30.252.140' (RSA) to the list of known hosts.
Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
so I used:
git clone https://gist.github.com/piffpoof/735fee0727a038425a11.git
to which I got:
remote: Counting objects: 3, done.
remote: Compressing objects: 100% (3/3), done.
remote: Total 3 (delta 0), reused 0 (delta 0), pack-reused 0
Unpacking objects: 100% (3/3), done.
Checking connectivity... done.
which at least didn't have an error message.
  • I then had FreeCAD save a file named "emptyHouse.FCstd" into the test directory which I had cloned the git repository into
  • there were then 2 files in the test directory: the Python script from earlier and the FreecAD document just saved to there
then I tried:
 git commit -a
which generated:
On branch master
Your branch is up-to-date with 'origin/master'.
Untracked files:
	emptyHouse.FCStd
nothing added to commit but untracked files present
which didn't look so good, but I carried on with:
git push
which produced:
Username for 'https://gist.github.com': piffpoof
Password for 'https://piffpoof@gist.github.com':
Everything up-to-date
Going back to the web interface, there is no binary file. I signed out and back in and still nothing.
Probably I am missing something simple?
Perhaps someone with more extensive git experience can identify what is missing/wrong
cox
Post by cox »
Sorry, missed a step
Try:
git add -A
git commit
git push
//Some aditional info on git add
http://stackoverflow.com/questions/5725 ... nd-git-add
piffpoof
Post by piffpoof »
cox wrote: git commit
This throws me into vim to add a line describing the commit, from which I not sure how to exit, supposedly ":q" is supposed to exit but only enters those characters when I try it. I've tried control-Q and various others but the Terminal session is simply caught by vim.
The following is pre-loaded into the vim editor:
# Please enter the commit message for your changes. Lines starting
# with '#' will be ignored, and an empty message aborts the commit.
# Committer: Macmini2 <macmini2@Intel-Mac-Mini.local>
# On branch master
# Your branch is up-to-date with 'origin/master'.
# Changes to be committed:
#       new file:   emptyHouse.FCStd
