App::PropertyAngle
keithsloan52
App::PropertyAngle
Postby keithsloan52 » Fri Mar 15, 2019 7:06 am
If I specify a property as PropertyAngle what python sees is a string "30 deg"
Is there a way to set it to either radians or degrees?
Chris_G
Re: App::PropertyAngle
Postby Chris_G » Fri Mar 15, 2019 8:13 am
I don't know if you can change the internal unit of the property, but you can set the property with the unit of your choice :
fp = App.ActiveDocument.addObject("Part::FeaturePython","fp")
fp.addProperty("App::PropertyAngle","angle")
fp.angle = 30
fp.angle
>>> 30 deg
fp.angle = "pi rad"
fp.angle
>>> 180 deg
