[Solved] How to use A2Plus solve constraints programatically
daaan
Postby daaan » Tue Nov 05, 2019 4:34 am
I need to do some animations using the A2plus (V0.4.27a) constraints.
I'm thinking about rotating some parts stated as fixed, and then solve the constraints, and repeat.
What is the correct command that does the rubic cube button (Solve constraints) in python?
Also I need to take a snapshot image of the result to make a gif animation, because I'm aware that the solve constraints will take some time to compute.
OS: Ubuntu 18.04.3 LTS
Version: 0.18.3.
Python version: 3.6.8
Qt version: 5.9.5
daaan
Re: How to use A2Plus solve constraints programatically
Postby daaan » Thu Nov 07, 2019 9:54 pm
Here is how you do it:
	doc = App.getDocument("document_name");
	solveConstraints(doc)
	doc.recompute()
	FreeCAD.ActiveDocument.recompute()				#Recompute
	FreeCADGui.updateGui()							#Update the graphics.}
