Draft.scale no longer works
duckmug
Post by duckmug »
I am trying this very simple example after coming across a thread:
import Draft
obj = FreeCADGui.Selection.getSelection()[0]
Draft.scale(obj, delta=App.Vector(2,2,2), center=App.Vector(0,0,0), legacy=True)
It results to an error:
TypeError: scale() got an unexpected keyword argument 'delta'
I also tried to use the help command but I can't find anything useful about this.
My FreeCAD version details:
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: 0d9536ed3e8c7f40197b5606e1b7873625e1d6fe
Python version: 3.8.10
Qt version: 5.12.8
Coin version: 4.0.0
OCC version: 7.5.2
duckmug
Re: Draft.scale no longer works
Post by duckmug »
Update: Removing the keywords delta and legacy did the trick:
import Draft
Draft.scale(obj, App.Vector(2,2,2), center=App.Vector(0,0,0), forcedraft=True)
FreeCAD.ActiveDocument.recompute()
The second parameter is called "scale". You can see these in the docs popping up in Python console.
Edit: using positional arguments without the names works of course as well.
Roy_043
Post by Roy_043 »
The forcedraft argument surprises me. I can't find it in scale.py.
