[Solved] Retrieve 3 selected points snippet code
johnwang
Post by johnwang »
Tried this on FreeCAD_0.20.25541_Win-LPv12.5.4_vc17.x-x86-64:
https://wiki.freecadweb.org/Code_snippe ... or_objects
I selected 3 points, then run it as a Macro. But it tells me 'Select 3 points exactly'.
cheers,
John
mario52
Re: Code_snippets question: Retrieve_the_coordinates_of_3_selected_points
Post by mario52 »
Hi
you must select 3 points on 3 objects different
(1 point by one object)
sel = FreeCADGui.Selection.getSelection()
mario
TheMarkster
Post by TheMarkster »
getSelectionEx() can be used if you want subobjects (faces, edges, vertices). It has property called PickedPoints that will be the XYZ coordinates of the selected points, which can be vertices, points along edges, or some point on a face.
selX = FreeCADGui.Selection.getSelectionEx()
FreeCAD.Console.PrintMessage("Objects selected:\n")
for s in selX:
    FreeCAD.Console.PrintMessage(s.Object.Name + "("+s.Object.Label+")\n")
    for ii in range(0,len(s.PickedPoints)):
        p = s.PickedPoints[ii]
        subName = s.SubElementNames[ii]
        FreeCAD.Console.PrintMessage("     "+subName+"---->(X,Y,Z) = ("+str(p.x)+","+str(p.y)+","+str(p.z)+")\n")
johnwang
Post by johnwang »
mario52 wrote: Fri Sep 17, 2021 2:23 pm you must select 3 points on 3 objects different
OK, I was picking from one BooleanFragments object.
Thank you very much.
johnwang
Post by johnwang »
TheMarkster wrote: Fri Sep 17, 2021 7:36 pm getSelectionEx() can be used if you want subobjects (faces, edges, vertices).
Works perfectly.
TheMarkster
johnwang wrote: Sat Sep 18, 2021 2:00 am
Works perfectly.
There is a difference, which can be confusing at first, between getSelection() and getSelectionEx(). The first one returns a list of the selected document objects while the second one returns a list of selection objects. For example, if you select a cube and a cylinder and run getSelection() the returned value is a list of objects [cube,cylinder]. But getSelectionEx() returns not a list of document objects, but rather a list of selection objects [sel1, sel2, sel3, sel4, etc.] To get at the selected objects:
[sel1.Object, sel2.Object, sel3.Object...]
heda
Re: [Solved] Retrieve 3 selected points snippet code
Post by heda »
this is just a copy of Markster's working code, utilizing some of the "batteries included" in python
just putting an alternative style of code out there, making use of pythons 3 versions of string formatting,
as well as the ability to loop over objects
PrintMsg = FreeCAD.Console.PrintMessage
PrintMsg("Objects selected:\n")
for sel in selX:
    maxname = max((len(name) for name in sel.SubElementNames)) + 4
    msg = '{:>%d}  --->  (X,Y,Z) = ({:.3f}, {:.3f}, {:.3f})\n' % maxname
    PrintMsg(f'{sel.Object.Name} ({sel.Object.Label})\n')
    for subName, p in zip(sel.SubElementNames, sel.PickedPoints):
        PrintMsg(msg.format(subName, p.x, p.y, p.z))
