Pie Menu
looo
Pie Menu
Postby looo » Sat May 09, 2015 12:44 pm
Blender has this pie menu, and I think freecad could also benefit from such a menu. It extends the short-cuts and is useable for both, beginners and power users.
First I tried to directly paint to the graphics view of the viewer but then the pie-menu can be displayed not outside the viewer. (The blender pie-menu is displayed anywhere on the window.) In the code I'm posting below the menu is inside a new graphics view which is shown or hidden on key-press-event ("a" for the example) holding the key will show you the possibilities (no icons yet, but this shouldn't be too hard). Releasing the key hides the menu and executes the highlighted command.
For this example the menu is used as a workbench-switcher. When switching to arch or draft the key-press-event is disabled somehow and the behaviour of the menu changes a bit.
if you want, try it out and if you know how to improve it let me know... :D
thanks
from __future__ import division
import FreeCADGui as Gui
import numpy as np
class PieButton(QtGui.QGraphicsEllipseItem):
    def __init__(self, pos=[0, 0], angle_range=(0, 1), size=[50, 50], view=None, parent=None):
        super(PieButton, self).__init__(None, scene=parent)
        self.view = view
        self.angle_range = angle_range
        self.setRect(pos[0] - size[0] / 2, pos[1] - size[1] / 2, size[0], size[1])
        self.setBrush(QtGui.QBrush(QtCore.Qt.red))
        self.setAcceptHoverEvents(True)
        self.command = None
        self.hoover = False
    def setHoover(self, value):
        if not self.hoover == value:
            self.hoover = value
            if value:
                self.setBrush(QtGui.QBrush(QtCore.Qt.blue))
                self.view.setText(self.command[0])
            else:
class PieView(QtGui.QGraphicsView):
    def __init__(self, key, commands, parent=None):
        super(PieView, self).__init__(parent)
        self.key = key
        self.setWindowFlags(QtCore.Qt.Widget | QtCore.Qt.FramelessWindowHint)
        self.setAttribute(QtCore.Qt.WA_TranslucentBackground)
        self.setStyleSheet("QGraphicsView {border-style: none; background: transparent;}" )
        self.setHorizontalScrollBarPolicy(QtCore.Qt.ScrollBarAlwaysOff)
        self.setVerticalScrollBarPolicy(QtCore.Qt.ScrollBarAlwaysOff)
        self.scene = QtGui.QGraphicsScene(self)
        self.scene.setSceneRect(-200, -200, 400, 400)
        self.setScene(self.scene)
        self.center = [0, 0]
        self.buttons = []
        self.label = QtGui.QGraphicsSimpleTextItem("")
        self.scene.addItem(self.label)
        self.add_commands(commands)
    def setText(self, text):
        self.label.setText(text)
        self.label.update()
        self.label.setPos(-self.label.sceneBoundingRect().width() / 2, 0)
    def add_commands(self, commands):
        num = len(commands)
        r = 100
        a = 70
        pie_phi = np.linspace(0, np.pi * 2, num + 1)
        phi = [(p + pie_phi[i + 1]) / 2 for i, p in enumerate(pie_phi[:-1])]
        for i, command in enumerate(commands):
            button = PieButton(
                [r * np.cos(phi[i]), r * np.sin(phi[i])],
                [pie_phi[i], pie_phi[i + 1]],
                [a, a], self, self.scene)
            button.command = command
            self.scene.addItem(button)
            self.buttons.append(button)
    def mouseMoveEvent(self, event):
        r2, angle = self.polarCoordinates
        hoover = False
        for item in self.buttons:
            if (item.angle_range[0] < angle and
                angle < item.angle_range[1] and
                r2 > 1000):
                item.setHoover(True)
                hoover = True
            else:
                item.setHoover(False)
        if not hoover:
            self.setText("")
    @property
    def polarCoordinates(self):
        pos = QtGui.QCursor.pos() - self.center
        r2 = pos.x() ** 2 + pos.y() ** 2
        angle = np.arctan2(pos.y(), pos.x())
        return r2, angle + (angle < 0) * 2 * np.pi
    def showAtMouse(self, event):
        if event["Key"] == self.key:
            self.show()
            self.center = QtGui.QCursor.pos()
            self.move(self.center.x()-(self.width()/2), self.center.y()-(self.height()/2))
    def keyReleaseEvent(self, event):
        super(PieView, self).keyReleaseEvent(event)
        if event.key() == QtGui.QKeySequence(self.key):
            if not event.isAutoRepeat():
                for item in self.scene.items():
                    if hasattr(item, "hoover"):
                        if item.hoover:
                            item.command[1]()
                self.hide()
if __name__ == "__main__":
    def part_design(): Gui.activateWorkbench("PartDesignWorkbench")
    def part(): Gui.activateWorkbench("PartWorkbench")
    def draft(): Gui.activateWorkbench("DraftWorkbench")
    def arch(): Gui.activateWorkbench("ArchWorkbench")
    def fem(): Gui.activateWorkbench("FemWorkbench")
    def sketch(): Gui.activateWorkbench("SketcherWorkbench")
    def draw(): Gui.activateWorkbench("DrawingWorkbench")
    def mesh(): Gui.activateWorkbench("MeshWorkbench")
    command_list = [
        ["PartDesign", part_design],
        ["Part", part],
        ["Draft", draft],
        ["Arch", arch],
        ["Fem", fem],
        ["sketch", sketch],
        ["draw", draw],
        ["mesh", mesh]]
    a = PieView("a", command_list)
    view = Gui.ActiveDocument.ActiveView
    view.addEventCallback("SoKeyboardEvent", a.showAtMouse)
drei
Re: Pie Menu
Postby drei » Sat May 09, 2015 7:05 pm
This looks really good :D,
Perhaps an implementation could be set to also use this within the workbenches,
say if I'm in sketcher and I summon the macro it will allow me to select tools within the WB, and if I enter another one, it may allow me to use the commands of that WB.
TT-RS
Re: Pie Menu
Postby TT-RS » Sat May 09, 2015 7:29 pm
drei wrote:Perhaps an implementation could be set to also use this within the workbenches,
+1
Yes, such context pop-up menu is good idea, and as drei says it should have functionality dependend on WB.
looo
Re: Pie Menu
Postby looo » Sun May 10, 2015 8:38 am
That is the plan. One global menu for wb.switch and one locale menu for every workbench. The problem is, that it is too heavy and buggy in this state and I don't know how to improve that. One thing is that background events sometimes close the window, or maybe that is a problem with the autorepeat option of the keyevent. The other thing is the key down suppress of the draft wb...
Here is a short demo of the menu connected with some framebuild functionality in action.
https://vimeo.com/127369120
looo
Re: Pie Menu
Postby looo » Sun May 10, 2015 8:53 am
Ok, I have connected the menu to a key allready used in Draft. So this shouldn't be that difficult to solve.
microelly2
Re: Pie Menu
Postby microelly2 » Sun May 10, 2015 6:54 pm
very nice idea,
this is the functionality I have looked for to get direct context sensitive interaction. New opportunities to get the jobs faster done. Thanks.
NormandC
Re: Pie Menu
Postby NormandC » Sun May 10, 2015 8:25 pm
I shared your video on the FreeCAD Google+ community: https://plus.google.com/117324667497119 ... 4Hg7QxbnKZ
ilyxa
Re: Pie Menu
Postby ilyxa » Mon May 11, 2015 5:32 pm
Can you provide bit more infos about Beam and Shape feature used in this video for fast and nice tube contsruction?
looo
Re: Pie Menu
Postby looo » Mon May 11, 2015 8:03 pm
thanks for the promotion normandC :)
The frame-builder stuff is a macro I've done some time ago. The idea was to simplify the procedure of dragging and rotating a sketch to a line and extruding it. The cutting tools are a miter cut, a plane cut and a shape cut.
if you want you can try: https://bitbucket.org/looooo/beam
r-frank
Re: Pie Menu
Postby r-frank » Mon May 11, 2015 8:21 pm
Reading about the pie menu ... well I had no idea what you were talking about ...
Then I saw your video on vimeo.
Now this is quite cool ...
It would speed up things and make FreeCAD more user-freindly and context-sensitive.
Please keep on working on this loo.
Roland
My GrabCAD FreeCAD-Projects
