GMSH macro
fandaL
Re: GMSH macro
Postby fandaL » Fri Jun 17, 2016 6:33 pm
I had a problem with a comma as a decimal separator, which is default on my current office computer. It was not possible to mesh with a maximum mesh size lower than 1. The error in the Report view
Unexpected error in GMSHMesh macro: <class 'subprocess.CalledProcessError'>
and the mesh with setting 1,9 looks exactly the same as with setting 1,0. That seems to cut decimals out.
Now it works when I added to the beginning of the macro
import string
and changed comma for dot in the variables clmax and clmin by adding lines
clmax =	string.replace(clmax,",",".")
clmin =	string.replace(clmin,",",".")
just after their input approximately at lines 172, 173
GMSH macro version
# Version: 04/07/2015
GMSH 2.12.0
OS: Windows 7
Version: 0.17.7745 (Git)
Hash: 79dcdfbc782e24bb34db882143af7ce8ebd237bd
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
tvargasn
Re: GMSH macro
Postby tvargasn » Sat Mar 11, 2017 10:12 pm
Hi, I run the macro on Freecad 0.17 but I get the following error:
  File "/Users/tommy/Library/Preferences/FreeCAD/Macro/GMSH.FCMacro", line 19, in <module>
    import FemAnalysis
ImportError: No module named FemAnalysis
I put all the path but still failing.
I appreciate the help. Excuse my English.
OS: Mac OS X
Version: 0.17.10433 (Git)
Branch: (detached from 5625bab)
Hash: 5625bab1703bd3d4810b1730a34e852a66c99a00
Python version: 2.7.13
OCC version: 7.1.0
ulrich1a
Re: GMSH macro
Postby ulrich1a » Sat Mar 11, 2017 10:58 pm
tvargasn wrote:Hi, I run the macro on Freecad 0.17 but I get the following error:
The macro code is integrated into the FEM-workbench in FreeCAD version 0.17. There is a button in the FEM-workbench that provide nearly all the functionality of the macro.
The FEM-workbench got a lot of changes recently. This affects especially the Python-import function.
If you do not need to mesh two independent parts, then there is not need to use the macro in FreeCAD version 0.17.
Ulrich
tvargasn
Re: GMSH macro
Postby tvargasn » Sun Mar 12, 2017 3:03 am
ulrich1a wrote:The macro code is integrated into the FEM-workbench in FreeCAD version 0.17.
Ohhhh, thanks a lot.
