Ticket #2187 - Unusable Wire from Section
Chris_G
Re: Unusable Wire from Section
Post by Chris_G »
IMHO, but I am not a developer, this bug is valid.
The user doesn't even have an hint on what went wrong.
The user should, at least, be informed that the path is not valid for this sweep.
Post by Kunda1 »
DeepSOIC wrote:This is why I created Macro Section some while ago.
Do you mind fleshing out what part of issue #2187 is a legit bug?
Post by Kunda1 »
bump
Post by Kunda1 »
Bump
Post by Kunda1 »
ickby wrote:ping
please weigh in once more to clarify
Chris_G
Post by Chris_G »
I am a bit sceptical about the result of the Part.Section tool.
From what I see here : FeaturePartSection.cpp#L45, it uses OCC's BRepAlgoAPI_Section that inherits from BRepAlgoAPI_BooleanOperation.
However, the intersection curves are not similar between a section operation and, for example, a cut operation.
See the result for the 2 shapes of this example.
The 2 input shapes :
The section operation gives the following result (the red edges):
Edge 1 : BSpline curve, Degree 1, 965 poles, continuity C0
Edge 2 : BSpline curve, Degree 1, 430 poles, continuity C0
The cut operation gives the following result on these same edges:
Edge 1 : BSpline curve, Degree 8, 170 poles, continuity C1
Edge 2 : BSpline curve, Degree 8, 79 poles, continuity C1
Why such a difference ?
Would there be a way to make the Section tool produce the same kind of intersection curves as the other Boolean Operations ?
Werner ?
wmayer wrote: ping
UR_
Post by UR_ »
Please have a look at this section implementation by DeepSOIC
https://www.freecadweb.org/wiki/Macro_Section
Example SectionPart vs FCMacro.png (46.11 KiB) Viewed 2105 times
Section by Macro.png (11.16 KiB) Viewed 2105 times
Section by PartWB.png (10.19 KiB) Viewed 2105 times
File:
SectionPart vs FCMacro.FCStd
(68.3 KiB) Downloaded 45 times
Done with:
Version: 0.17.12802 (Git)
Hash: 91bb7ed0c51ba47f011199af7bc0a3a2964cf5be
Python version: 2.7.8
OCC version: 7.1.0
Chris_G
Post by Chris_G »
UR_ wrote: Wed Dec 13, 2017 10:37 pm Please have a look at this section implementation by DeepSOIC
Hi UR_,
I knew DeepSOIC's macro.
My question was more : "Why does OCC have this strange behaviour ?"
Even if I suppose that we probably cannot do anything anyway :(
Post by Kunda1 »
soft bump to keep this discussion going
Post by Kunda1 »
Should we open an upstream ticket about this ?
