How to extend an part class inside python?
microelly2
Postby microelly2 » Wed Oct 14, 2015 9:51 pm
I want to enrich a standard FreeCAD object example Box by a string list.
b=App.ActiveDocument.addObject("Part::Box","Box")
b.addProperty("App::PropertyStringList","script","main","script")
It doesnt work because Part::Box has no method to add props.
When I use FeaturePython, then I can add my property but have to reimplement all the Box functionality.
b1=App.ActiveDocument.addObject("Part::FeaturePython","My")
b1.addProperty("App::PropertyStringList","script","main","script")
I'm looking for something like this (common Qt syntax):
class MyBox(PartBox):
	def __init__(self,**args):
		super(PartBox, self).__init__(**args)
		self.script=["Hello", "it's so simple to add a property"]
or some other incantation in python to be able for this
b2=App.ActiveDocument.addObject("Part::Box::MyBox","MyBox")
b2.addProperty("App::PropertyStringList","script","main","script")
b2.script=["Hello", "it's so simple to add a property"]
I'm sure this can be done in C++, but is there a open door for pythoneers too?
Site Admin
Re: How to extend an part class inside python?
Postby wmayer » Thu Oct 15, 2015 9:09 pm
For none of the C++ feature classes this is possible. It's as you said only possible for custom feature classes.
Yes, but it's not that much code. You just have to add properties for length, width and height and then use Part.makeBox to create the shape.
class Box:
    def __init__(self, obj):
        PartFeature.__init__(self, obj)
        obj.addProperty("App::PropertyLength","Length","Box","Length of the box").Length=1.0
        obj.addProperty("App::PropertyLength","Width","Box","Width of the box").Width=1.0
        obj.addProperty("App::PropertyLength","Height","Box", "Height of the box").Height=1.0
        obj.Proxy = self
    def onChanged(self, fp, prop):
        if prop == "Length" or prop == "Width" or prop == "Height":
            fp.Shape = Part.makeBox(fp.Length,fp.Width,fp.Height)
    def execute(self, fp):
In C++ it's possible to add a property as class member (i.e. at compile time) which means that this member is bound to the class. But the addProperty method adds a property to a single instance at runtime and this is not possible either in C++. As you can see that addProperty is called inside the __init__ method which means that the properties are added for all created instances separately.
microelly2
Postby microelly2 » Sat Oct 17, 2015 3:14 pm
Thank you,
with your answer I have found the complete example
https://raw.githubusercontent.com/FreeC ... ePython.py
Works fine with other primitives too.
For bool ops I use Part.makeCompound
but what are the Shape constructors for fuse, common and cut?
Part.makeFuse does not exist in pythonland :roll:
Site Admin
Postby wmayer » Sat Oct 17, 2015 3:31 pm
The boolean ops are not part of the module but of the shape class
import Part
c=Part.makeCylinder(2,10)
b=Part.makeBox(10,10,10)
c.fuse(b)
c.cut(b)
c.common(b)
microelly2
Postby microelly2 » Tue Oct 20, 2015 11:08 am
Thank you Werner once more.
my wrapper is growing - parts and bool ops are okay.
https://www.youtube.com/watch?v=VK8LF1ApNuA
the draft objects are already python featured.
So I want to add the part design objects
Is there a way to get the pad/pockets and sketches too?
Site Admin
Postby wmayer » Tue Oct 20, 2015 7:24 pm
No.
sketches too?
For sketches there is indeed a custom feature version available but the problem is that it's not usable.
class SketchFeature:
    obj.Proxy = self
  def execute(self, obj):
    pass
SketchFeature(App.ActiveDocument.addObject("Sketcher::SketchObjectPython"))
App.ActiveDocument.ActiveObject.ViewObject.Proxy=1
Now edit it and try to add some geometry...
microelly2
Postby microelly2 » Tue Oct 20, 2015 7:43 pm
thank you, its not the best answer
but so I will use a draft clone and check the idea to have moveable pads ;)
Site Admin
Postby wmayer » Tue Oct 20, 2015 7:59 pm
I have an idea how to overcome the limitations with sketcher. This idea then can be applied to any other high-level feature class, too.
Site Admin
Postby wmayer » Tue Oct 20, 2015 10:47 pm
With git commit e7a3dc48e834591e5553 sketcher can now be used in Python as custom feature.
So, from now on a Python feature doesn't need to have an execute() method any more. If it's not there then the execute() method of the related C++ class is called instead.
If your Python feature must have an execute() method but you also want to call the execute() of the C++ class you must return "False".
Examples:
    obj.Proxy = self
    return False
    obj.Proxy = self
microelly2
Postby microelly2 » Wed Oct 21, 2015 4:34 am
Thank you.
So I hope for a rainy weekend to test and use it all.
