QtGui closeEvent
QtGui closeEvent
I'm doing a a macro with QtGui interface
I would need to trigger an action on closing the main QtGui windows
starting from the QtGui example
http://www.freecadweb.org/wiki/index.ph ... r_Examples
More Than 2 Buttons
I would need to trigger a message box on closing the main Qt windows (e.g. a warning message before closing it)
thank you
Maurice
More Than 2 Buttons
thank you
Maurice
Re: QtGui closeEvent
from PySide import QtGui
class MyWindow(QtGui.QWidget):
def closeEvent(self, e):
res = QtGui.QMessageBox.question(None,"Close","Do you want to close the window?",QtGui.QMessageBox.Yes|QtGui.QMessageBox.No)
if res is QtGui.QMessageBox.No:
e.ignore()
m=MyWindow()
m.show()
@wmayer
thanks a lot ... that was exactly I was looking for...
just an other question... is there a way to check if an other instance of the same QTGui window is running, so to avoid to double exec the widgets?
Maurice
Maurice
In order to control this you have to implement the singleton pattern: http://python-3-patterns-idioms-test.re ... leton.htmljust an other question... is there a way to check if an other instance of the same QTGui window is running, so to avoid to double exec the widgets?
thanx again!
very helpful forum and people!
Maurice
Maurice
@wmayer
I tried singletone and it works if I launch my fuction e.g. twice in the same macro...
but my target was to avoid the possibility to execute the same macro invoked from e.g. FreeCAD toolbar...
thanks
Maurice
thanks
Maurice
Don't quite understand what you want to achieve.but my target was to avoid the possibility to execute the same macro invoked from e.g. FreeCAD toolbar...
hi @wmayer,
e.g. I have configured in the tool bar a button for calling a QtGui macro e.g. Macro Clone Convert
http://www.freecadweb.org/wiki/index.ph ... oneConvert
I would like to avoid that the action to click on that macro button twice, will open two QtGui windows of the same macro
thanks
thanks
