Points in Sketch
petat
Points in Sketch
Postby petat » Fri Dec 04, 2015 5:49 pm
I had idea to make macro for holes but I found some problem.
When I put some individual points to sketch and close sketcher point are hide. Why?
I cant select those point.
Thanks
DeepSOIC
Re: Points in Sketch
Postby DeepSOIC » Fri Dec 04, 2015 7:19 pm
Hi!
Points in sketches are always construction geometry, and are never exposed to the outside. Generally, exposing the points to the outside is undesired (this will confuse extrusion and revolving routines), but in a few cases, I would like to actually do that too.
You can access the points through sketch.Geometry, together with all other elements, construction and not.
petat
Postby petat » Fri Dec 04, 2015 8:03 pm
I am designer and I know Catia and Inventor and there are posible to make individual points in sketch and
after use points as driving geometry for holes and use those points for multiple pattern.
DeepSOIC
Postby DeepSOIC » Fri Dec 04, 2015 8:10 pm
I often use circles instead of points, when making sketch-defined array.
jmaustpc
Postby jmaustpc » Sat Dec 05, 2015 11:13 am
A "point" from Part WB, i.e not PartDesign WB, which will be ordinary visible geometry in 3d not construction geometry.
petat
Postby petat » Sat Dec 05, 2015 3:07 pm
Yes I know, but points from Draft WB is dificult dimensioning.
Why points from Part Design WB dont have two posibility (visible/unvisible) similar as line and other objects?
Thanks
