It doesn't even need an image:
- new file
- activate Image WB
- Scale
- click two points
- cancel
-> crash
No need to be sorry: You made it - thanks - an error occurred -
This needs to be fixed in the CMakeLists.tst file. It's the installed vs non-installed build thingy. I will try to make a pull request tomorrow.
Hi @sgrogan,
You have to change the z-component of the placement of the image. Usually you do this during import in the placement popup by setting a negative value for the offset.
