Hello I'm trying to get png images of parts in a headless Docker container. I'm using this code snippet given by wmayer from the first page of this thread
import FreeCAD, Part
from pivy import coin
box=Part.makeCone(10,8,10)
iv=box.writeInventor()
# SoInput.setBuffer seems broken with pivy, so save to file and load from there
output=open("part.iv","w")
output.write(iv)
output.close()
inp=coin.SoInput()
inp.openFile(output.name)
data = coin.SoDB.readAll(inp)
base = coin.SoBaseColor()
base.rgb.setValue(0.6,0.7,1.0)
data.insertChild(base,0)
root = coin.SoSeparator()
light = coin.SoDirectionalLight()
cam = coin.SoOrthographicCamera()
root.addChild(cam)
root.addChild(light)
root.addChild(data)
axo = coin.SbRotation(-0.353553, -0.146447, -0.353553, -0.853553)
viewport=coin.SbViewportRegion(400,400)
cam.orientation.setValue(axo)
cam.viewAll(root,viewport)
off=coin.SoOffscreenRenderer(viewport)
root.ref()
ret=off.render(root)
root.unref()
if ret > 0:
off.writeToPostScript("crystal.ps")
if off.isWriteSupported("PNG"):
off.writeToFile("crystal.png","PNG")
When I run this function the program crashes with the error message below. It seems to be erroring out at the line ret=off.render(root)
Coin error in glxglue_init(): Couldn't open NULL display.
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7fdaf58d9f20]
#1 /usr/lib/x86_64-linux-gnu/libX11.so.6(XDefaultScreenOfDisplay+0) [0x7fdadb7a97c0]
#2 /usr/lib/x86_64-linux-gnu/libCoin.so.80c(+0x3c6b9d) [0x7fdad5e37b9d]
#3 /usr/lib/x86_64-linux-gnu/libCoin.so.80c(+0x3c6d61) [0x7fdad5e37d61]
#4 /usr/lib/x86_64-linux-gnu/libCoin.so.80c(glxglue_context_create_offscreen+0x14) [0x7fdad5e38b84]
#5 /usr/lib/x86_64-linux-gnu/libCoin.so.80c(cc_glglue_context_max_dimensions+0x80) [0x7fdad5e306c0]
#6 0x7fdad5fa588c in CoinOffscreenGLCanvas::getMaxTileSize() from /usr/lib/x86_64-linux-gnu/libCoin.so.80c+0x7c
#7 0x7fdad5fa5a1d in CoinOffscreenGLCanvas::clampSize(SbVec2s&) from /usr/lib/x86_64-linux-gnu/libCoin.so.80c+0x1d
#8 0x7fdad5fa5b67 in CoinOffscreenGLCanvas::setWantedSize(SbVec2s) from /usr/lib/x86_64-linux-gnu/libCoin.so.80c+0x17
#9 0x7fdad5fa01fa in SoOffscreenRendererP::renderFromBase(SoBase*) from /usr/lib/x86_64-linux-gnu/libCoin.so.80c+0xca
#10 /usr/lib/python2.7/dist-packages/pivy/_coin.x86_64-linux-gnu.so(+0x3db534) [0x7fdad6859534]
#11 python(PyEval_EvalFrameEx+0x695b) [0x557bda68a8db]
#12 python(PyEval_EvalCodeEx+0x6da) [0x557bda681d0a]
#13 python(PyEval_EvalFrameEx+0x5cb8) [0x557bda689c38]
#14 python(PyEval_EvalFrameEx+0x52b2) [0x557bda689232]
#15 python(PyEval_EvalCodeEx+0x6da) [0x557bda681d0a]
#16 python(PyEval_EvalCode+0x19) [0x557bda681629]
#17 python(+0x12461f) [0x557bda6b261f]
#18 python(PyRun_FileExFlags+0x82) [0x557bda6ad322]
#19 python(PyRun_SimpleFileExFlags+0x18d) [0x557bda6ac67d]
#20 python(Py_Main+0x68b) [0x557bda65b1ab]
#21 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7fdaf58bcb97]
#22 python(_start+0x2a) [0x557bda65aa2a]
My base image is Ubuntu:18.04 and I'm using a freecad-daily ppa build "FreeCAD 0.18, Libs: 0.18R16093 (Git)"
Is this possible in a Docker container? Thanks.
