IconThemes
triplus
Re: IconThemes
Postby triplus » Mon Apr 01, 2019 11:02 pm
Hi @Wsk8.
First remove the IconThemes module. After copy and paste the code snippet in FreeCAD Python console and restart FreeCAD:
p = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Bitmaps/Theme")
p.SetString("Name", "None")
https://forum.freecadweb.org/viewtopic. ... 10#p276881
Such result is what you are after?
Wsk8
Re: IconThemes
Postby Wsk8 » Tue Apr 02, 2019 11:37 am
Executing the python commands didn't worked, but after installing IconThemes (only installing) the issue was gone and now the icons are correct.
mfg
triplus
Re: IconThemes
Postby triplus » Wed Apr 03, 2019 5:05 pm
mfg
Actually yes, as installing IconThemes module will currently automatically set FreeCAD-default icon theme on FreeCAD start. And therefore icons from your desktop environment icon theme won't get used on a toolbar like File.
P.S. Such support was enabled on Linux a while back, but i have seen a few reports in the past, where people reported this behavior as representing an issue for them.
triplus
Re: IconThemes
Postby triplus » Fri May 10, 2019 2:30 pm
I am pleased to announce that after a few years of progressing this area we have reached a milestone. There is still some work left to do but FreeCAD now has a proper cross-platform icon themes support. Thanks to all involved in any way in the past. In addition a high quality icon theme pack in .rcc format was made (currently targeting FreeCAD 0.18):
https://forum.freecadweb.org/viewtopic. ... 90#p306251
P.S. People interested in compiling an icon theme pack can find instructions here and here. Note that the same approach could likely be used for things like enabling translations (external modules).
Re: IconThemes
Postby Kunda1 » Wed Sep 04, 2019 4:59 pm
There is a lot of info spread out in this thread. I'm trying to understand how to test this Addon/Module. It's very sparse documentation since it's still under development. Can someone create a summary post of where things are now and how to test?
Specifically having issues with this notion of .rcc files
For the demonstration purposes demo.rcc (for legacy support DemoTheme.zip) icon theme was provided. Move the demo.rcc (for legacy support extract the DemoTheme.zip archive) to an appropriate location.
ref: https://github.com/triplus/IconThemes/issues/3
Re: IconThemes
Postby Kunda1 » Wed Sep 04, 2019 5:11 pm
The Addon shows the README.md page of each Addon/Module/Workbench, what I'm proposing in https://github.com/triplus/IconThemes/issues/3 is to slightly improve the documentation that is there, not write comprehensive technical writing. It makes the testing of this Addon much more viable for testers as well, like myself. If you're interested in me testing it...?
triplus
Re: IconThemes
Postby triplus » Wed Sep 04, 2019 5:56 pm
What i imagine happened is, yesterday you have seen:
https://forum.freecadweb.org/viewtopic. ... 51#p331400
And therefore in less then 24h you were able to figure out things like, there must be some sort of FreeCAD module, managing FreeCAD icon packs. Indeed there was one. You manged to enable the demo theme. Documentation therefore can't be all that sparse as you say. Now i guess you need a more complete icon pack? AFIAK there are currently two of them available:
One only supporting legacy option for now, that is why the legacy option is still there:
https://forum.freecadweb.org/viewtopic.php?f=22&t=18417
And one already available in .rcc format:
https://forum.freecadweb.org/viewtopic.php?f=34&t=34687
P.S. Try to figure the next step out. If something won't work, ask, i can write further instructions tomorrow.
Re: IconThemes
Postby Kunda1 » Sun Sep 08, 2019 6:04 pm
JFYI, I'm not a huge fan of this type of 'Laura Croft Tombraider' style of documentations. AKA searching for clues buried in long murky phpbb threads that need to be waded through while the README.md of the repo is desert sparse that resutls may lead to an anti-climactic treasure. (ok, sorry for waxing polemic)
I prefer documentation that explains how to test even if it's in an alpha state; what known issues are; where more work is needed, and ways to help contribute. I'm trying to help with getting there, but it seems my attempts are not so welcomed.
Re: IconThemes
Postby Kunda1 » Sun Sep 08, 2019 7:58 pm
Screenshot as follows:
IconTheme dialog window (top left)
IconTheme(legacy) dialog window (bottom left)
Terminal showing the content of ~/.FreeCAD/Mod/IconTheme/ (there is no .FreeCAD/Gui directory, does it need to be manually created?)
Note: the top left dialog has a checkbox that can't be unchecked (no response when clicking on it)
OS: Manjaro Linux (XFCE/xfce)
Version: 0.19.18095 (Git) AppImage
Hash: 27cb54009b57c1938f7ff97026c8b35c1688233f
Python version: 3.7.3
Qt version: 5.12.1
IconTheme latest revision:
commit 42d9c1d6c28d7abc40ac576ee6c2e94970b3f912 (HEAD -> master, origin/master, origin/HEAD)
Author: triplus <triplus@users.noreply.github.com>
Date:   Fri Mar 22 18:38:13 2019 +0100
    Check if directory exist
Re: IconThemes
Postby Kunda1 » Sat Sep 14, 2019 5:06 am
If you zoom in on the image, you can see
b'FreeCAD default\n'
so, some sort of formatting issue.
