Macro for Spreadsheet Alias setup and Part Family Generation
Re: Macro for Spreadsheet Alias setup and Part Family Generation
Dear hatari,
Nice work, very usefull!
Do you think it is possible to get column and row numbers directly from a selected region in the Spreadsheet?
For your cube-example does this mean that I would like to mark B2 to D4 in the drv-spreadsheet and run you script.
BR
HoWil
BR
HoWil
Hi hatari,
Some additional comments:
line 118
should look like
How about using 'Save a Copy' instead of using 'Save as' in 'Generate Part Family'?
This would have the benefit that one works always on the same file with the same filename, while the current script always changes the filename I am working on which is a bit confusing.
Maybe something like a 'auto' mode would help saving time:
The script looks up which row in A is the first without input and defines the variable range accordingly. After that runs the variation loop until the variation name in the first row is empty.
THX
line 118
endCell = QtGui.QInputDialog.getInteger(None, "End Cell Row", "Input Start Cell Row:")
endCell = QtGui.QInputDialog.getInteger(None, "End Cell Row", "Input End Cell Row:")
THX
Thanks for your thoughts, HoWil!
I'm still a very beginner in this and don't have a deep insight in the FreeCAD architechture yet, but I guess this is possible and it's actually on my to do list. However, I'm a bit short of time at the moment, so I didn't figure out how to implement it, yet...HoWil wrote: Do you think it is possible to get column and row numbers directly from a selected region in the Spreadsheet?
Thanks, it's now fixed!HoWil wrote: Some additional comments:
line 118should look likeCode: Select all
How about using 'Save a Copy' instead of using 'Save as' in 'Generate Part Family'?Code: Select all
Yeah, that's also a good idea. So if there's other content besides the Part Family data in the spreadsheet, it's enough to just separate it from the rest with an empty row/column.HoWil wrote: Maybe something like a 'auto' mode would help saving time:
Dear hatari,
I adopted your code a bit and 'implemented' the automatically mode as 'routine5' as I described before.
I changed also the saveCopy part and the text for the QInputDialog.
The implementation is a bit rough since I am also no computer scientist nor a software-engineer, but it works and maybe it helps others:
# -*- coding: utf-8 -*-
''' Script for setting, moving and clearing aliases in the Spreadsheet.
It allows to generate Part Families
hatari 2016 v0.2
GNU Lesser General Public License (LGPL)
from PySide import QtGui, QtCore
import os
class MyButtons(QtGui.QDialog):
def __init__(self):
super(MyButtons, self).__init__()
self.initUI()
def initUI(self):
option1Button = QtGui.QPushButton("Set Aliases")
option1Button.clicked.connect(self.onOption1)
option2Button = QtGui.QPushButton("Clear Aliases")
option2Button.clicked.connect(self.onOption2)
option3Button = QtGui.QPushButton("Move Aliases")
option3Button.clicked.connect(self.onOption3)
option4Button = QtGui.QPushButton("Generate Part Family")
option4Button.clicked.connect(self.onOption4)
option5Button = QtGui.QPushButton("Generate Part Family automatically")
option5Button.clicked.connect(self.onOption5)
buttonBox = QtGui.QDialogButtonBox()
buttonBox = QtGui.QDialogButtonBox(QtCore.Qt.Vertical)
buttonBox.addButton(option1Button, QtGui.QDialogButtonBox.ActionRole)
buttonBox.addButton(option2Button, QtGui.QDialogButtonBox.ActionRole)
buttonBox.addButton(option3Button, QtGui.QDialogButtonBox.ActionRole)
buttonBox.addButton(option4Button, QtGui.QDialogButtonBox.ActionRole)
buttonBox.addButton(option5Button, QtGui.QDialogButtonBox.ActionRole)
mainLayout = QtGui.QVBoxLayout()
mainLayout.addWidget(buttonBox)
self.setLayout(mainLayout)
# define window xLoc,yLoc,xDim,yDim
self.setGeometry(400, 400, 300, 50)
self.setWindowTitle("Alias Manager")
self.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
def onOption1(self):
self.retStatus = 1
self.close()
def onOption2(self):
self.retStatus = 2
self.close()
def onOption3(self):
self.retStatus = 3
self.close()
def onOption4(self):
self.retStatus = 4
self.close()
def onOption5(self):
self.retStatus = 5
self.close()
# Define Aliases
def routine1():
column = QtGui.QInputDialog.getText(None, "Column containing Values", "Enter Column Letter")
if column[1]:
col = str.capitalize(str(column[0])) # Always use capital characters for Spreadsheet
startCell = QtGui.QInputDialog.getInteger(None, "start Row number", "Input start Row number:")
if startCell[1]:
endCell = QtGui.QInputDialog.getInteger(None, "end Row number", "Input end Row number:")
if endCell[1]:
for i in range(startCell[0],endCell[0]+1):
cellFrom = 'A' + str(i)
cellTo = str(col[0]) + str(i)
App.ActiveDocument.Spreadsheet.setAlias(cellTo, '')
App.ActiveDocument.Spreadsheet.setAlias(cellTo, App.ActiveDocument.Spreadsheet.getContents(cellFrom))
# Clear Aliases
def routine2():
if column[1]:
if startCell[1]:
if endCell[1]:
# Move Aliases
def routine3(columnFrom=None, columnTo=None, startCell=None, endCell=None):
columnFrom = QtGui.QInputDialog.getText(None, "Value Column", "Move From")
if columnFrom[1]:
columnTo = QtGui.QInputDialog.getText(None, "Value Column", "Move To")
if columnTo[1]:
colF = str.capitalize(str(columnFrom[0]))
colT = str.capitalize(str(columnTo[0]))
if startCell[1]:
if endCell[1]:
cellDef = 'A'+ str(i)
cellFrom = str(colF[0]) + str(i)
cellTo = str(colT[0]) + str(i)
App.ActiveDocument.Spreadsheet.setAlias(cellFrom, '')
App.ActiveDocument.Spreadsheet.setAlias(cellTo, App.ActiveDocument.Spreadsheet.getContents(cellDef))
# Generate Part Family
def routine4():
# Get Filename
doc = FreeCAD.ActiveDocument
if not doc.FileName:
FreeCAD.Console.PrintError('Must save project first\n')
docDir, docFilename = os.path.split(doc.FileName)
filePrefix = os.path.splitext(docFilename)[0]
def char_range(c1, c2):
"""Generates the characters from `c1` to `c2`, inclusive."""
for c in xrange(ord(c1), ord(c2)+1):
yield str.capitalize(chr(c))
columnFrom = QtGui.QInputDialog.getText(None, "Column", "Range From")
if columnFrom[1]:
columnTo = QtGui.QInputDialog.getText(None, "Column", "Range To")
if columnTo[1]:
startCell = QtGui.QInputDialog.getInteger(None, "Start Cell Row", "Input Start Cell Row:")
if startCell[1]:
if endCell[1]:
fam_range = []
for c in char_range(str(columnFrom[0]), str(columnTo[0])):
fam_range.append(c)
for index in range(len(fam_range)-1):
cellFrom = str(fam_range[index]) + str(i)
cellTo = str(fam_range[index+1]) + str(i)
sfx = str(fam_range[index+1]) + '1'
suffix = App.ActiveDocument.Spreadsheet.getContents(sfx)
filename = filePrefix + '_' + suffix + '.fcstd'
filePath = os.path.join(docDir, filename)
FreeCAD.Console.PrintMessage("Saving view to %s\n" % filePath)
# App.getDocument(filePrefix).saveAs(filePath)
App.getDocument(filePrefix).saveCopy(filePath)
# Generate Part Family automatically
def routine5():
# Get Filename
fam_range = []
# Walk through all columns in row 1 and test if the cell is empty
values_present = True
curr_column = 1 # column 1 or A is for alias definition
while values_present and curr_column<=26: # crashes for columns like AA or AB
curr_column += 1
cellDef = str.capitalize(chr(65-1+curr_column)) + '1' # the integer representation of the char 'A' is 65
try:
if App.ActiveDocument.Spreadsheet.getContents(cellDef)=='':
values_present = False
except:
columnFrom = []
columnFrom.append(str.capitalize(chr(65-1+1)) )
columnTo = []
columnTo.append(str.capitalize(chr(65-1+curr_column-1)) )
# Walk through all rows in column A and test if the cell is empty
curr_row = 1
while values_present:
curr_row += 1
cellDef = 'A' + str(curr_row)
try:
except:
startCell = []
startCell.append(2)
endCell = []
endCell.append(curr_row)
# Generate all variants
for c in char_range(str(columnFrom[0]), str(columnTo[0])): # !!! This does not include columns like AA or AB !!!!
fam_range.append(c)
# Move the alias back to column B
colF = str.capitalize(str(columnTo[0]))
colT = 'B'
form = MyButtons()
form.exec_()
#try:
if form.retStatus==1:
routine1()
elif form.retStatus==2:
routine2()
elif form.retStatus==3:
routine3()
elif form.retStatus==4:
routine4()
elif form.retStatus==5:
routine5()
#except:
# pass
Hi all,
I've been working on improving this macro for a while. I'm not an experienced coder but as I found it very useful and I have used it for a while now, I wanted to improve it in order to speed up the workflow and solving some issues and inconsistencies I found in the @hatari original macro.
I have talked with @hatari and we decided to release both (original and this improved version) under LGPL licence so that you all can enjoy it and, if you feel like, try to improve it even more.
Some of the improvements are:
I have also included an icon in case you want to add the macro to the toolbar with a unique icon: I hope you like it
Cheers
- the GUI is now a popup window from where quickly inset the requested information
- now the rows/columns range start and ends at the correct cell
- is possible to run the command and rerun it without having to close the popup window
- little fixes and improvements to the original code
Cheers
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
Didn't test it yet as i guess i must first grasp the concept a bit better.
Just wanted to say if you will in addition add Macro to the FreeCAD Wiki more users will be able to find it.
Thank you triplus, I will do it when I have a new spare timetriplus wrote:Didn't test it yet as i guess i must first grasp the concept a bit better.
Donepablogil wrote:Thank you triplus, I will do it when I have a new spare timetriplus wrote:Didn't test it yet as i guess i must first grasp the concept a bit better.
Great.
P.S. And could you share one example on how you use it? For me to follow the procedure and see how it goes.
It basically does the same as the original tahari macro, read the first thread post and you will know how to use it and even a pair of examples to play withtriplus wrote:Great.
