Faces or Edges constraint among non cylindrical parts Macro
easyw-fc
Postby easyw-fc » Mon Nov 21, 2016 2:35 pm
this Macro covers some constraint that I was not able to find around:
- Concentric constraint among non cylindrical parts
- Constraint on center Faces and/or Edges
inspired from Macro CenterFace and Macro WorkFeatures :D
it can be used in Assembly2, but it doesn't create any fixed constraint
Maurice
# -*- coding: utf-8 -*-
# 29/04/2014
# select a face launch and list the center coordinate XYZ of face
# To change the color of the dot change
# red   = 1.0  # 1 = 255
# green = 0.0  #
# blue  = 0.0  #
# evolution of Macro_CenterFace
# and some part of Macro WorkFeature
# center objs faces/closed_edges to first obj face/closed_edge
__title__   = "Center Faces of Parts"
__author__  = "maurice"
__url__     = "kicad stepup"
__version__ = "0.24"
__date__    = "11.2016"
import FreeCAD, FreeCADGui, Draft, Part
from FreeCAD import Vector, Rotation, Placement
from FreeCAD import Base
cx = 1  # center x -> 1
cy = 1  # center y -> 1
cz = 1  # center z -> 1
create_points=False
use_bb = True #align center based on bounding boxes or center of mass
def say(msg):
    FreeCAD.Console.PrintMessage(msg)
    FreeCAD.Console.PrintMessage('\n')
def sayw(msg):
    FreeCAD.Console.PrintWarning(msg)
    FreeCAD.Console.PrintWarning('\n')
def angleBetween(e1, e2):
    """ Return the angle (in degrees) between 2 edges.
    if isinstance(e1,Part.Edge) and isinstance(e2,Part.Edge):
        # Create the Vector for first edge
        v1 = e1.Vertexes[-1].Point
        v2 = e1.Vertexes[0].Point
        ve1 = v1.sub(v2)
        # Create the Vector for second edge
        v3 = e2.Vertexes[-1].Point
        v4 = e2.Vertexes[0].Point
        ve2 = v3.sub(v4)
    elif isinstance(e1,Base.Vector) and isinstance(e2,Base.Vector):
        ve1 = e1
        ve2 = e2
    elif isinstance(e1,Part.Edge) and isinstance(e2,Base.Vector):
        ve1 = v1.sub(v2)
        ve2 = e2
    elif isinstance(e1,Base.Vector) and  isinstance(e2,Part.Edge):
        ve1 = e1
        ve2 = v3.sub(v4)
    else:
        return
    angle = ve1.getAngle(ve2)
    import math
    return math.degrees(angle), angle
sel = FreeCADGui.Selection.getSelection()
selEx = FreeCADGui.Selection.getSelectionEx()
say("number of objects: "+ str(len(selEx)))
objs = [selobj.Object for selobj in selEx]
say(objs)
coords = []
normals = []
coordPs = []
sEdge = []
j = 0
# .BoundBox.Center
#align faces
if (len(selEx) > 1) and (len(selEx)==len(sel)):
    #s = obj.Shape
    for fc in selEx:
        say ("j= "+str(j))
        say("len selEx "+str(len(selEx)))
        s=fc
        #selectedEdge = FreeCADGui.Selection.getSelectionEx()[j].SubObjects[0] # select one element SubObjects
        selectedEdge = selEx[j].SubObjects[0] # select one element SubObjects
        sEdge.append(selectedEdge)
        pad=0
        if str(fc.SubObjects[0])[1:5] != "Face":
            wire = Part.Wire(selectedEdge)
            fw = Part.Face(wire)
            #Part.show(fw)
            f=FreeCAD.ActiveDocument.addObject("Part::Feature","Facebinder")
            f.Shape=fw
            pad=1
            #FreeCAD.ActiveDocument.recompute()
            say("Label : "+ str(sel[j].Label))     # extract the Label
            say("Name  : "+ str(sel[j].Name))     # extract the Name
            say( "Center Face Binder "+str(0)+" "+str(FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].CenterOfMass)) # Vector center mass to face
            say( "Center Face Binder bb "+str(0)+" "+str(FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].BoundBox.Center)) # Vector center mass to face
        else:
            pad=0
            f=Draft.makeFacebinder(s)
            say( "Center Face Binder "+str(0)+" "+str(f.Shape.Faces[0].CenterOfMass)) # Vector center mass to face
            say( "Center Face Binder bb "+str(0)+" "+str(f.Shape.Faces[0].BoundBox.Center)) # Vector center mass to face
        # LineColor
        red   = 1.0  # 1 = 255
        green = 0.0  #
        blue  = 0.0  #
        if create_points:
            if pad==0:
                if use_bb:
                    Draft.makePoint(f.Shape.Faces[0].BoundBox.Center.x,f.Shape.Faces[0].BoundBox.Center.y,f.Shape.Faces[0].BoundBox.Center.z) # create a point
                else:
                    Draft.makePoint(f.Shape.Faces[0].CenterOfMass.x,f.Shape.Faces[0].CenterOfMass.y,f.Shape.Faces[0].CenterOfMass.z) # create a point
                FreeCADGui.activeDocument().activeObject().PointColor = (red, green, blue)
            else:
                if use_bb:
                    Draft.makePoint(FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].BoundBox.Center.x,FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].CenterOfMass.y,FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].CenterOfMass.z) # create a point
                else:
                    Draft.makePoint(FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].CenterOfMass.x,FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].CenterOfMass.y,FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].CenterOfMass.z) # create a point
        if pad==0:
            if use_bb:
                coordNx = f.Shape.Faces[0].BoundBox.Center.x
                coordNy = f.Shape.Faces[0].BoundBox.Center.y
                coordNz = f.Shape.Faces[0].BoundBox.Center.z
                coordP  = f.Shape.Faces[0].BoundBox.Center
            else:
                coordNx = f.Shape.Faces[0].CenterOfMass.x
                coordNy = f.Shape.Faces[0].CenterOfMass.y
                coordNz = f.Shape.Faces[0].CenterOfMass.z
                coordP  = f.Shape.Faces[0].CenterOfMass
        else:
            if use_bb:
                coordNx = FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].BoundBox.Center.x
                coordNy = FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].BoundBox.Center.y
                coordNz = FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].BoundBox.Center.z
                coordP  = FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].BoundBox.Center
            else:
                coordNx = FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].CenterOfMass.x
                coordNy = FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].CenterOfMass.y
                coordNz = FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].CenterOfMass.z
                coordP  = FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].CenterOfMass
        coords.append ([coordNx,coordNy,coordNz])
        coordPs.append (coordP)
        norm = f.Shape.Faces[0].normalAt(0,0)
        say (norm)
        normals.append (norm)
        FreeCAD.ActiveDocument.removeObject(f.Name)
        if j>0:
            pos=App.Vector(-coords[j][0]+coords[0][0],-coords[j][1]+coords[0][1],-coords[j][2]+coords[0][2])
            ## objs[j].Placement.move(pos)
            m_angle, m_angle_rad = angleBetween(normals[0],normals[j])
            say (m_angle)
            Origin = Base.Vector(0, 0, 0)
            rot_axis = normals[0].cross(normals[j])
            rot_center = coordPs[j]
            rot_angle = m_angle # + m_angleAlignFaces
            say("axis,center,angle")
            say(rot_axis)
            say(rot_center)
            say(rot_angle)
            if rot_angle!=0:
                Draft.rotate(objs[j],-rot_angle,rot_center,rot_axis)
            say("Rotated     : angle "+str(-rot_angle)+" center "+str(rot_center)+" axis "+str(rot_axis))
        j=j+1
coords = []
normals = []
coordPs = []
j = 0
#align centers
if (len(selEx) >= 1) and (len(selEx)==len(sel)):
    #s = obj.Shape
    for fc in selEx:
        s=fc
        print j
        selectedEdge = sEdge[j] # select one element SubObjects
        pad=0
            #Part.show(fw)
            f.Shape=fw
            pad=1
        else:
            pad=0
        # LineColor
        red   = 1.0  # 1 = 255
        green = 0.0  #
        blue  = 0.0  #
        if create_points:
            if pad==0:
            else:
        if pad==0:
            if use_bb:
            else:
        else:
            if use_bb:
            else:
            norm    = FreeCAD.ActiveDocument.getObject(f.Name).Shape.Faces[0].normalAt(0,0)
        say (norm)
        if j>0:
            say("Moved     : "+str(coordNx-coords[0][0])+" "+str(coordNy-coords[0][1])+" "+str(coordNz-coords[0][2]))
        j=j+1
for obj in objs:
    FreeCADGui.Selection.removeSelection(obj)
# except:
#     App.Console.PrintError( "select a face"+"\n")
mario52
Re: Faces or Edges constraint among non cylindrical parts Macro
Postby mario52 » Mon Nov 21, 2016 3:22 pm
hi
nice why not ask right to put your macros in the wiki Macros_recipes
(same style the excellent Flamingo)
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
triplus
Postby triplus » Mon Nov 21, 2016 10:33 pm
Such tools are usable in a lot of tasks therefore thanks for sharing.
easyw-fc
Postby easyw-fc » Wed Nov 23, 2016 10:32 pm
triplus wrote:Such tools are usable in a lot of tasks therefore thanks for sharing.
thx :D
I just improved a bit the macro with a GUI to configure what to align and in which mode:
mario52 wrote:hi
@mario52 I tried to write the macro in the wiki (I have already the rights to do it), but when I try to create the file, I don't get the Macro Template, but just a blank page to write over... Am I missing something?
thx
Maurice
__version__ = "0.27"
import FreeCAD, FreeCADGui, Draft, Part, DraftTools
# Form implementation generated from reading ui file 'C:\Cad\Progetti_K\3D-FreeCad-tools\CenterAlignObjectswFacesEdges.ui'
# Created: Wed Nov 23 23:17:52 2016
#      by: pyside-uic 0.2.15 running on PySide 1.2.2
# WARNING! All changes made in this file will be lost!
class Ui_CenterAlignObjectsFacesEdges(object):
    def setupUi(self, CenterAlignObjectsFacesEdges):
        CenterAlignObjectsFacesEdges.setObjectName("CenterAlignObjectsFacesEdges")
        CenterAlignObjectsFacesEdges.setWindowModality(QtCore.Qt.NonModal)
        CenterAlignObjectsFacesEdges.resize(367, 351)
        CenterAlignObjectsFacesEdges.setFocusPolicy(QtCore.Qt.NoFocus)
        self.verticalLayout = QtGui.QVBoxLayout(CenterAlignObjectsFacesEdges)
        self.verticalLayout.setObjectName("verticalLayout")
        self.verticalLayout_2 = QtGui.QVBoxLayout()
        self.verticalLayout_2.setObjectName("verticalLayout_2")
        self.lbl_info = QtGui.QLabel(CenterAlignObjectsFacesEdges)
        font = QtGui.QFont()
        font.setWeight(75)
        font.setBold(True)
        self.lbl_info.setFont(font)
        self.lbl_info.setObjectName("lbl_info")
        self.verticalLayout_2.addWidget(self.lbl_info)
        self.horizontalLayout = QtGui.QHBoxLayout()
        self.horizontalLayout.setObjectName("horizontalLayout")
        self.groupBox = QtGui.QGroupBox(CenterAlignObjectsFacesEdges)
        self.groupBox.setObjectName("groupBox")
        self.rb_bb = QtGui.QRadioButton(self.groupBox)
        self.rb_bb.setGeometry(QtCore.QRect(11, 20, 161, 20))
        self.rb_bb.setChecked(True)
        self.rb_bb.setObjectName("rb_bb")
        self.rb_mass = QtGui.QRadioButton(self.groupBox)
        self.rb_mass.setGeometry(QtCore.QRect(200, 20, 121, 20))
        self.rb_mass.setObjectName("rb_mass")
        self.horizontalLayout.addWidget(self.groupBox)
        self.verticalLayout_2.addLayout(self.horizontalLayout)
        self.verticalLayout.addLayout(self.verticalLayout_2)
        self.hLayout2 = QtGui.QHBoxLayout()
        self.hLayout2.setObjectName("hLayout2")
        self.groupBox_2 = QtGui.QGroupBox(CenterAlignObjectsFacesEdges)
        self.groupBox_2.setObjectName("groupBox_2")
        self.rb_centers = QtGui.QRadioButton(self.groupBox_2)
        self.rb_centers.setGeometry(QtCore.QRect(20, 20, 261, 20))
        self.rb_centers.setObjectName("rb_centers")
        self.rb_planes = QtGui.QRadioButton(self.groupBox_2)
        self.rb_planes.setGeometry(QtCore.QRect(20, 50, 261, 20))
        self.rb_planes.setObjectName("rb_planes")
        self.rb_centers_planes = QtGui.QRadioButton(self.groupBox_2)
        self.rb_centers_planes.setGeometry(QtCore.QRect(20, 80, 261, 20))
        self.rb_centers_planes.setChecked(True)
        self.rb_centers_planes.setObjectName("rb_centers_planes")
        self.cb_x = QtGui.QCheckBox(self.groupBox_2)
        self.cb_x.setGeometry(QtCore.QRect(290, 40, 41, 20))
        self.cb_x.setChecked(True)
        self.cb_x.setObjectName("cb_x")
        self.cb_y = QtGui.QCheckBox(self.groupBox_2)
        self.cb_y.setGeometry(QtCore.QRect(290, 60, 41, 20))
        self.cb_y.setChecked(True)
        self.cb_y.setObjectName("cb_y")
        self.cb_z = QtGui.QCheckBox(self.groupBox_2)
        self.cb_z.setGeometry(QtCore.QRect(290, 80, 41, 20))
        self.cb_z.setChecked(True)
        self.cb_z.setObjectName("cb_z")
        self.label_2 = QtGui.QLabel(self.groupBox_2)
        self.label_2.setGeometry(QtCore.QRect(270, 20, 61, 16))
        self.label_2.setObjectName("label_2")
        self.hLayout2.addWidget(self.groupBox_2)
        self.verticalLayout.addLayout(self.hLayout2)
        self.verticalLayout_3 = QtGui.QVBoxLayout()
        self.verticalLayout_3.setObjectName("verticalLayout_3")
        self.cb_inv_normals = QtGui.QCheckBox(CenterAlignObjectsFacesEdges)
        self.cb_inv_normals.setObjectName("cb_inv_normals")
        self.verticalLayout_3.addWidget(self.cb_inv_normals)
        self.line = QtGui.QFrame(CenterAlignObjectsFacesEdges)
        self.line.setFrameShape(QtGui.QFrame.HLine)
        self.line.setFrameShadow(QtGui.QFrame.Sunken)
        self.line.setObjectName("line")
        self.verticalLayout_3.addWidget(self.line)
        self.label = QtGui.QLabel(CenterAlignObjectsFacesEdges)
        self.label.setObjectName("label")
        self.verticalLayout_3.addWidget(self.label)
        self.hLayout1 = QtGui.QHBoxLayout()
        self.hLayout1.setObjectName("hLayout1")
        self.btnAlign = QtGui.QPushButton(CenterAlignObjectsFacesEdges)
        self.btnAlign.setObjectName("btnAlign")
        self.hLayout1.addWidget(self.btnAlign)
        self.verticalLayout_3.addLayout(self.hLayout1)
        self.verticalLayout.addLayout(self.verticalLayout_3)
        self.retranslateUi(CenterAlignObjectsFacesEdges)
        QtCore.QMetaObject.connectSlotsByName(CenterAlignObjectsFacesEdges)
    def retranslateUi(self, CenterAlignObjectsFacesEdges):
        CenterAlignObjectsFacesEdges.setWindowTitle(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "Center Align Faces/Edges", None, QtGui.QApplication.UnicodeUTF8))
        self.lbl_info.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "Select multiple face(s) or closed Edges and click Align", None, QtGui.QApplication.UnicodeUTF8))
        self.groupBox.setTitle(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "reference", None, QtGui.QApplication.UnicodeUTF8))
        self.rb_bb.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "Center of Bounding Box", None, QtGui.QApplication.UnicodeUTF8))
        self.rb_mass.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "Center of Mass", None, QtGui.QApplication.UnicodeUTF8))
        self.groupBox_2.setTitle(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "aligning", None, QtGui.QApplication.UnicodeUTF8))
        self.rb_centers.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "Align Faces/Edges Centers", None, QtGui.QApplication.UnicodeUTF8))
        self.rb_planes.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "Align Faces/Edges Planes", None, QtGui.QApplication.UnicodeUTF8))
        self.rb_centers_planes.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "Align Faces/Edges Centers and Planes", None, QtGui.QApplication.UnicodeUTF8))
        self.cb_x.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "x", None, QtGui.QApplication.UnicodeUTF8))
        self.cb_y.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "y", None, QtGui.QApplication.UnicodeUTF8))
        self.cb_z.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "z", None, QtGui.QApplication.UnicodeUTF8))
        self.label_2.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "center on:", None, QtGui.QApplication.UnicodeUTF8))
        self.cb_inv_normals.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "invert Normal for Plane", None, QtGui.QApplication.UnicodeUTF8))
        self.label.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "First Face/Edge is the Reference for alignment", None, QtGui.QApplication.UnicodeUTF8))
        self.btnAlign.setText(QtGui.QApplication.translate("CenterAlignObjectsFacesEdges", "Align", None, QtGui.QApplication.UnicodeUTF8))
### ---------code to be inserted and remove from new generation------------------------- ###
        self.btnAlign.clicked.connect(self.onAlign)
    def onAlign(self):
        say("Align clicked")
        normal=0;type=0;mode=0
        if self.cb_inv_normals.isChecked():
            say("Align Normal Inverted")
            normal=1
        if self.rb_bb.isChecked():
            say("centering on Bounding Boxes")
        else:
            say("centering on Center of Mass")
            type=1
        if self.rb_centers_planes.isChecked():
            say("Centering and aligning Planes")
        elif self.rb_centers.isChecked():
            say("Centering Faces/Edges")
            mode=1
        else:
            say("Aligning Planes")
            mode=2
        cx=0;cy=0;cz=0
        if self.cb_x.isChecked():
            cx=1
        if self.cb_y.isChecked():
            cy=1
        if self.cb_z.isChecked():
            cz=1
        Align(normal,type,mode,cx,cy,cz)
def say(msg):
def sayw(msg):
def singleInstance():
    app = QtGui.qApp
    for i in app.topLevelWidgets():
        if i.objectName() == "CenterAlignObjectsFacesEdges":
            i.deleteLater()
        else:
            pass
#    t=FreeCADGui.getMainWindow()
#    dw=t.findChildren(QtGui.QDockWidget)
#    #print str(dw)
#    for i in dw:
#        print str(i.objectName())
#        if str(i.objectName()) == "CenterAlignObjectsFacesEdges": #"kicad StepUp 3D tools":
#            i.deleteLater()
#        else:
#            pass
singleInstance()
CenterAlignObjectsFacesEdges = QtGui.QWidget()
ui = Ui_CenterAlignObjectsFacesEdges()
ui.setupUi(CenterAlignObjectsFacesEdges)
#CenterAlignObjectsFacesEdges.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
CenterAlignObjectsFacesEdges.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint | QtCore.Qt.WindowTitleHint | QtCore.Qt.WindowMinimizeButtonHint | QtCore.Qt.WindowSystemMenuHint);
#self.setWindowFlags(self.windowFlags() & ~QtCore.Qt.WindowStaysOnTopHint)
CenterAlignObjectsFacesEdges.show()
# def center(self):
#     frameGm = self.frameGeometry()
#     screen = QtGui.QApplication.desktop().screenNumber(QtGui.QApplication.desktop().cursor().pos())
#     #say(screen)
#     centerPoint = QtGui.QApplication.desktop().screenGeometry(screen).center()
#     #say(centerPoint)
#     frameGm.moveCenter(centerPoint)
#     self.move(frameGm.center)
#center(CenterAlignObjectsFacesEdges)
CenterAlignObjectsFacesEdges.move(10,100)
## to do:
## ok single instance
## - always on top
## - no maximize
def Align(normal,type,mode,cx,cy,cz):
    #cx = 1  # center x -> 1
    #cy = 1  # center y -> 1
    #cz = 1  # center z -> 1
    say(str(cx)+str(cy)+str(cz))
    create_points=False
    if type==1:
        use_bb = False #align center based on bounding boxes or center of mass
    #def say(msg):
    #    FreeCAD.Console.PrintMessage(msg)
    #    FreeCAD.Console.PrintMessage('\n')
    #def sayw(msg):
    #    FreeCAD.Console.PrintWarning(msg)
    #    FreeCAD.Console.PrintWarning('\n')
            ve1 = v1.sub(v2)
            ve2 = v3.sub(v4)
            ve1 = e1
            ve2 = e2
            ve1 = v1.sub(v2)
            ve2 = e2
            ve1 = e1
            ve2 = v3.sub(v4)
        else:
            return
        import math
    say(objs)
    coords = []
    normals = []
    coordPs = []
    sEdge = []
    j = 0
    # .BoundBox.Center
    #align faces
        #s = obj.Shape
        for fc in selEx:
            say ("j= "+str(j))
            s=fc
            pad=0
                #Part.show(fw)
                f.Shape=fw
                pad=1
            else:
                pad=0
            # LineColor
            red   = 1.0  # 1 = 255
            green = 0.0  #
            blue  = 0.0  #
            if create_points:
                if pad==0:
                    if use_bb:
                    else:
                else:
                    if use_bb:
                    else:
            if pad==0:
                if use_bb:
                else:
            else:
                if use_bb:
                else:
            #norm = f.Shape.Faces[0].normalAt(0,0)
            if j==0:
                if normal==1:
                    norm = f.Shape.Faces[0].normalAt(0,0)*-1
                else:
            else:
            #else:
            #    norm = f.Shape.Faces[0].normalAt(0,0)
            say (norm)
            if j>0:
                say (m_angle)
                say(rot_axis)
                say(rot_center)
                say(rot_angle)
                if rot_angle!=0:
                    if mode==0 or mode==2:
            j=j+1
    coords = []
    normals = []
    coordPs = []
    j = 0
    #align centers
        #s = obj.Shape
        for fc in selEx:
            s=fc
            print j
            pad=0
                #Part.show(fw)
                f.Shape=fw
                pad=1
            else:
                pad=0
            # LineColor
            red   = 1.0  # 1 = 255
            green = 0.0  #
            blue  = 0.0  #
            if create_points:
                if pad==0:
                else:
            if pad==0:
                if use_bb:
                else:
            else:
                if use_bb:
                else:
            say (norm)
            if j>0:
                pos=App.Vector((-coords[j][0]+coords[0][0])*cx,(-coords[j][1]+coords[0][1])*cy,(-coords[j][2]+coords[0][2])*cz)
                if mode==0 or mode==1:
            j=j+1
    for obj in objs:
    # except:
mario52
Postby mario52 » Thu Nov 24, 2016 12:36 pm
hi
done i clicked op "Create page"
you complete your page and when you are finished, delete the template "VeryImportantMessage"
Macro_Center_Align_Objects_with_Faces_or_Edges
mario
easyw-fc
Postby easyw-fc » Thu Nov 24, 2016 7:44 pm
mario52 wrote:hi
mario
thx a lot :)
easyw-fc
Postby easyw-fc » Fri Nov 25, 2016 11:17 pm
I just updated the macro to work also with FC 0.17 Body containers
jp-willm
Postby jp-willm » Sun Feb 12, 2017 11:11 am
easyw-fc wrote:Hi,
Maurice
[/code]
Nice tool 8-)
Thank you !
I have create a svg icon :
Center_Align.svg
(6.33 KiB) Downloaded 65 times
easyw-fc
Postby easyw-fc » Sun Feb 12, 2017 2:22 pm
jp-willm wrote: Hello,
Nice tool 8-)
Thank you !
I have create a svg icon :Center_Align.svg
Thx,
added to the Macro page ;)
https://www.freecadweb.org/wiki/Macro_C ... s_or_Edges
https://www.freecadweb.org/wiki/File:Ma ... _Edges.svg
renatorivo
Postby renatorivo » Sun Feb 12, 2017 5:43 pm
easyw-fc wrote:added to the Macro page
Only for consistency. It seems to me that all the other icons to the toolbar are .png
Renato
