an other Alignment Tool for Placing Parts
easyw-fc
Postby easyw-fc » Mon Jan 09, 2017 3:45 pm
'cause recently I've found some user asking for help in aligning part in FC without using assembly2,
I've uploaded a video to help in using my alignment tool...
Macro_Center_Align_Objects_with_Faces_or_Edges on Macro recipes
(still there is some work to do on aligning linear edges...)
hoping that could be of some help :)
Maurice
triplus
Re: an other Alignment Tool for Placing Parts
Postby triplus » Mon Jan 09, 2017 4:33 pm
I watched the video and such tools are indeed highly usable.
Thanks.
easyw-fc
Postby easyw-fc » Mon Jan 09, 2017 7:23 pm
triplus wrote:I watched the video and such tools are indeed highly usable.
Thanks.
thanks @triplus :D
r-frank
Postby r-frank » Tue Jan 10, 2017 7:20 am
Nice work Maurice, thanks for sharing ...
easyw-fc wrote:(still there is some work to do on aligning linear edges...)
Do you know this macro from Javier Martinez ?
My GrabCAD FreeCAD-Projects
HoWil
Postby HoWil » Tue Jan 10, 2017 8:55 am
easyw-fc wrote: hoping that could be of some help :)
Maurice
Thanks easyw-fc for sharing this.
Are the parts 'only' moved or is the relation between the faces/edges also stored somewhere like in assembly2?
Is your tool reusing code from assembly2? Is it maybe more performant or do you see some other benefits beside being simpler to handle than assembly2?
BR,
HoWil
easyw-fc
Postby easyw-fc » Tue Jan 10, 2017 9:30 am
r-frank wrote:Do you know this macro from Javier Martinez ?
thx I'll have a look :)
Maurice
easyw-fc
Postby easyw-fc » Tue Jan 10, 2017 9:47 am
Hi @HoWil
HoWil wrote: Are the parts 'only' moved or is the relation between the faces/edges also stored somewhere like in assembly2?
the macro is only moving parts, without adding any fixed constrains
HoWil wrote:Is your tool reusing code from assembly2?
the button Move is using assembly2 code...
Aligning functions are derived in part from Macro Work Feature
HoWil wrote:Is it maybe more performant or do you see some other benefits beside being simpler to handle than assembly2?
I developed this macro because assembly2 was missing a tool to align faces and to align axis for faces...
after having developed this macro I added these features also to assembly2
https://github.com/hamish2014/FreeCAD_a ... 2/pull/125
https://github.com/hamish2014/FreeCAD_a ... 2/pull/127
(and before I made assembly2 compatible with FC 0.17 Body thing
https://github.com/hamish2014/FreeCAD_a ... ba8011bc45
https://github.com/hamish2014/FreeCAD_a ... /README.md
'Thanks to Maurice (easyw-fc) assembly2 will work with files from FreeCAD 0.17.')
Moreover I use this Macro in cases when:
1) I don't need to have fixed constrains
2) I need to align parts maintaining a fixed position in the document for i.e. a single part
3) I need to align parts that are not aligned/constrained correctly by assembly2
here a thread about the difficulty to align parts in some situation (in italian)
viewtopic.php?f=28&t=19441&start=10#p150692
EDIT
4) an other thing is that with this tools the parts are just moved around and don't depend on assembly2 compatibility of solver in different releases of FC
Probably assembly2 would need some improvements in the solver, buth I think it would be a quite complex task...
Maurice
cox
Postby cox » Tue Jan 10, 2017 10:59 am
Like it a lot, Maurice :D
I would like to suggest one new feature regarding the flip normal selection.
How about as default behaviour, to choose the closest orientation(not rotate more than 180deg in any direction) and only use flip normal if this does not produce the wanted result.
EDIT: My thinking is that it would be easier to choose the correct setting up front, before executing the align command.
easyw-fc
Postby easyw-fc » Tue Jan 10, 2017 11:49 am
cox wrote:Like it a lot, Maurice :D
thx :D
cox wrote: How about as default behaviour, to choose the closest orientation(not rotate more than 180deg in any direction) and only use flip normal if this does not produce the wanted result.
flip normal is useful to joint / mate faces, instead of align them
the best would be as in Catia Snap tool, with a visual feed back... but for me it is a bit too complex task for a quite small benefit ...
Catia V5|Assembly Design|Move|Snap Tool
but I must confess that I envy a bit that interface :D
mario52
Postby mario52 » Tue Jan 10, 2017 5:05 pm
hi easyw-fc
try Macro_FCSpring_Helix_Variable (new version)
and see this section
principe:
1: create axis to center > center circles
2: discretize the axis (my macro 0.1 mm)
3: use the coordinates created
4: and displace the object along the axis
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
