Plug-in for AUTODESK Inventor files
Re: Plug-in for AUTODESK Inventor files
Hello Mr. Plonka,
My motivation is not creating interoperability between Inventor and FreeCAD, but creating Interoperability between Inventor 2010 and Inventor 2020 .
My preferred programming language is VBA, because it is shipped with Inventor as well as MS-Office, and its so easy to deal with their APIs.
I have attached a Sample iam-UFRxDoc-Disassembly.
Is there a way to exchange email-adresses for further communication? I'm still writing in this forum's language for other users convenience, but i would'nt mind switching to german.
Greetings from Aachen
CSchmitz
CSchmitz
- SampleUFRxDoc.zip
- (13.61 KiB) Downloaded 108 times
if you fellas decide to go off-forum to discuss, please consider keeping us updated on your efforts. There maybe more 'pioneers' like yourselves that are interested in this endeavor (despite the outcome being for FreeCAD or not). Thanks for your efforts and considerations.
Cheers
Cheers
Installed the latest stable version of FreeCAD for Windows a few days ago.
The Addon manager complained about missing xlutils and olefile when trying to install the plugin. Installing these using python3 (already had 3.8.5 on the computer) didn't help, but I noticed the FreeCAD Python console said 3.6.6 conda-forge.
Tried installing from the FreeCAD install directory (c:/users/username/AppData/Local/FreeCAD 0.18/bin) like this:
C:\Users\username\AppData\Local\FreeCAD 0.18\bin>python.exe -m pip install xlutils
C:\Users\username\AppData\Local\FreeCAD 0.18\bin>python.exe -m pip install olefile
After this the plugin installed without problems.
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: NorwegianBokmal/Norway (nb_NO)
Qt version: 5.6.2
Hello CSchmitz,
I‘m also very interested in understanding the structure of Inventor assembly files.
How did you create the sample UFRxDoc file? Did you translate the M. Plonka‘s code into VBA?
Thanks and have a nice day,
Alex
understanding the structure of the UFRxDoc will no result in any new information about how to import IAM files.
The raw structure of the IAM file is the same as the IPT files. You can use the same reader.
First thing should be to uncomment the importer in "init.py" line 13
Second thing: replace in "importerIL.py" line 52
Than you can start reverse engeneering the IAM files by simply importing them into FC - obviously no result will be displayed but :
#FreeCAD.addImportType("Autodesk INVENTOR assembly file (*.iam)", "importerIL")
logError(u"Sorry, AUTODESK's Inventor assemblies not yet supported!")
if (Import_IPT.read(doc, filename, readProperties)):
return Import_IPT
- while importing Inventor files, a folder with debug information is created.
- .\%ASSMBLY_FILE%_iam\RSeDb.log
- .\%ASSMBLY_FILE%_iam\0002.sat
- .\%ASSMBLY_FILE%_iam\0002_sat.history
- .\%ASSMBLY_FILE%_iam\0082.sat
- .\%ASSMBLY_FILE%_iam\0082_sat.history
- .\%ASSMBLY_FILE%_iam\AmAppSegment.log
- .\%ASSMBLY_FILE%_iam\AmBREPSegment.log
- .\%ASSMBLY_FILE%_iam\AmBrowserSegment.log
- .\%ASSMBLY_FILE%_iam\AmDcSegment.log
- .\%ASSMBLY_FILE%_iam\AmGraphicsSegment.log
- .\%ASSMBLY_FILE%_iam\AmRxSegment.log
- .\%ASSMBLY_FILE%_iam\DesignViewSegment.log
- .\%ASSMBLY_FILE%_iam\iProperties.log
- .\NBNotebookSegment.log
- watch the output-window for error messages. You will get the first instructions about what to do next.
At least SAT files are now availabe - but not usefull as they don't don't contian any bodies. - The AmDcSegment.log contain's the features to creaete your assembly.
OS;Windows10 64bit Japanese
FreeCAD0.19
Installation has normally ended, but the following error occurs at the time of a FreeCAD start, and it can't be used.
18:11:56 During initialization the error "'cp932' codec can't decode byte 0x9f in position 2258: illegal multibyte sequence" occurred in C:\Users\toshi\AppData\Roaming\FreeCAD\Mod\InventorLoader\InitGui.py
FreeCAD0.19
It seems that installation is fine.
Please, would you mind to share the file with me?
Thanks
Thanks
https://github.com/jmplonka/InventorLoader/issues/51Toshihiko wrote: ↑Sun Apr 18, 2021 9:32 am OS;Windows10 64bit Japanese
FreeCAD0.19
I solved this problem yesterday
Your first post, welcome to FreeCAD!
