Part-o-magic (again) [icon ideas for new tool wanted!]
DeepSOIC
Re: Part-o-magic (again)
Postby DeepSOIC » Thu Feb 16, 2017 11:53 pm
easyw-fc wrote:but atm I cannot test what I would like to create...
I would need to have an App::Part container to contains other objects or even other App::Part containers...
This would be useful to be used in an assembly structure ...
Part-o-magic supports creating nested Parts, or nested Modules, or even Parts within Modules. If it's not working for you, please explain in detail what you do.
easyw-fc wrote:1) make a compound of the App::Part structure
I thought Draft Clone would do that, but it doesn't. That might be a very simple fix to master FreeCAD.
easyw-fc wrote:2) make a union of the App::Part structure
Same as with clone ;) + Part Fuse.
easyw-fc wrote:3) make a simple copy of the App:Part structure (similar to Mux in assembly2)
I don't quite understand... Sounds like an easy deal, please explain in detail.
easyw-fc
Postby easyw-fc » Fri Feb 17, 2017 10:25 am
DeepSOIC wrote:Part-o-magic supports creating nested Parts, or nested Modules, or even Parts within Modules. If it's not working for you, please explain in detail what you do.
Hi, when using PoM I can only create nested Parts, but without the option to have more of one Part at the same level... may be I'm not using PoM in the right way...
I attach the desired and of the PoM tree I get
Great! Looking forward for it :D
If you use assembly2 to build up a model with parts, then you can create a Mux of your assembled parts...
The Mux is similar to a fusion and a single copy of the objects and it is a really nice option to have a single object of your assembled part without any boolean operation
Mux-example.FCStd
(9.63 KiB) Downloaded 7 times
thx for your attention
Maurice
DeepSOIC
Postby DeepSOIC » Fri Feb 17, 2017 10:33 am
easyw-fc wrote:Hi, when using PoM I can only create nested Parts, but without the option to have more of one Part at the same level... may be I'm not using PoM in the right way...I attach the desired and of the PoM tree I get
PoM always adds whatever is created to active container. Including new Parts. That is, to have "Part002" to "Part", activate "Part" before creating "Part002" by double-clicking it in tree (you can also get there using Leave, Enter buttons of PoM workbench, which I highly recommend adding to a global toolbar, as they are quite versatile).
To add another Part to the root of document, deactivate whatever is active (either by double-clicking it in tree, or pressing Leave button until it becomes grey)
easyw-fc
Postby easyw-fc » Fri Feb 17, 2017 10:50 am
thx, I will try it :D
An other thing very useful but missing is the option to select an App::Part root node and export the assembled components as STEP for example...
easyw-fc
Postby easyw-fc » Fri Feb 17, 2017 11:24 am
DeepSOIC wrote:To add another Part to the root of document, deactivate whatever is active (either by double-clicking it in tree, or pressing Leave button until it becomes grey)
works like a charm! thx :D
Should I add a FR for the following behavior?
3) make a simple copy of the App:Part structure as in Part WB
4) ability to select an App::Part root node and export the assembled/children components as STEP
Maurice
DeepSOIC
Postby DeepSOIC » Fri Feb 17, 2017 12:45 pm
easyw-fc wrote:Should I add a FR for the following behavior?
1) yes, but to FreeCAD tracker, as it's rather trivial to extend a Clone to do that.
2) i'll think about it. If 1 is fulfilled, achieving 2 is trivial. But I had an idea of making a variant of Module that will expose a fusion or a compound of its content. It's easy, I'm just not sure if it's useful.
3) definitely
4) I'm afraid I won't be able to do it
easyw-fc
Postby easyw-fc » Fri Feb 17, 2017 2:05 pm
DeepSOIC wrote:1) yes, but to FreeCAD tracker, as it's rather trivial to extend a Clone to do that.
done here
https://www.freecadweb.org/tracker/view.php?id=2905
DeepSOIC wrote:2) i'll think about it. If 1 is fulfilled, achieving 2 is trivial. But I had an idea of making a variant of Module that will expose a fusion or a compound of its content. It's easy, I'm just not sure if it's useful.
it will align the App::Part behavior to what is for Compounds
DeepSOIC wrote:4) I'm afraid I won't be able to do it
May be I was not clear... I'm not asking to save STEP hierarchy as in App:Part (that probably will be take on charge by the work of @vejmarie that is improving STEP inter-operability)
I would like to have the option to select a root note of a Part and export the objects as actually it can be done selecting a compound root node...
for example if I have a compound of a Cube and a Sphere, selecting the compound I will export the Cube and the Sphere as placed in the compound...
Do you think that would be possible?
Thx
Maurice
ickby
Postby ickby » Fri Feb 17, 2017 2:42 pm
I added a few notes to the tracker ticket. For discussion also here:
1. An App::Part container is a universal object which can hold any kind of DocumentObject like meshs or Paths or even pictures. I can't work with Part tools (Booleans, Compound etc.) which work with Part::Features only and hence result in a undefined behavior. The App::Part object should not work with those tools. Current behavior is correct.
2. To point 3: make a simple copy. I agree that the simple copy tool should handle App::Part objects, but this must involve creating a simple copy of all child DocumentObjects, as a DocumentObject is allowed to be only in a single local coordinate system (GeoFeatureGrouip, Which App::Part is).
Note that the story is completely different for Part-o-Magic containers that are a Part::Feature in itself.
easyw-fc
Postby easyw-fc » Fri Feb 17, 2017 3:01 pm
Hi @ikby
ickby wrote:1. An App::Part container is a universal object which can hold any kind of DocumentObject like meshs or Paths or even pictures. I can't work with Part tools (Booleans, Compound etc.) which work with Part::Features only and hence result in a undefined behavior. The App::Part object should not work with those tools. Current behavior is correct.
it would be possible to allow Boolean ops only if App::Part is containing Part::Features only?
so is App::Part container good for assembly objects?
If the container cannot work with boolean do you still consider this useful for STEP integration?
ickby wrote:Note that the story is completely different for Part-o-Magic containers that are a Part::Feature in itself.
or then PoM would be better?
ickby
Postby ickby » Fri Feb 17, 2017 3:13 pm
IMHO a bad idea. Tools don't know anything of local coordinate systems and that shoud stay so.
Yes, IMHO there is absolutely no reason why you need Booleans of Parts for Assemblies. All you want to do is to place your objects and groups of them, and App::Part is perfect for that.
Same argument, to my knowledge step assembly structures do not need any booleans between local coordinate systems.
