Part-o-magic (again)
triplus
Re: Part-o-magic (again) [now in add-ons]
Postby triplus » Sat Mar 18, 2017 8:08 pm
We discussed on how to create global toolbar from Python here. And the corresponding pull request can be found here:
https://github.com/DeepSOIC/Part-o-magic/pull/12
DeepSOIC
Postby DeepSOIC » Sat Mar 18, 2017 10:03 pm
Now, Part-o-magic will automatically create a small global toolbar.
Inkedglobal toolbar_LI.jpg (757.88 KiB) Viewed 254 times
If you don't like it, you can go to Tools->Customize->Toolbars->Global, and untick it.
You can also customize it to your taste there. If you want to reset it to default state, delete it, and part-o-magic will recreate the toolbar on next start-up.
Thanks @triplus for helping out. Even though I refused his PR, I used it as a resource to copy-paste from.
DeepSOIC
Postby DeepSOIC » Sat Mar 18, 2017 11:20 pm
Followup: toolbar with PoM PartDesign tools is now automatically added to PartDesign workbench.
HoWil
Postby HoWil » Mon Mar 20, 2017 3:25 pm
DeepSOIC wrote:Followup: toolbar with PoM PartDesign tools is now automatically added to PartDesign workbench.
Dear DeepSOIC,
I played a bit with PoM and do have some questions related the reorganization of a model. For instance if I have two PoM parts and want to shift a PartDesignNext-Body from one part to the other, how do I have to do that. I have made a simple test case and an according screencast please see:
:arrow:
The structure of the PDN-Body is lost after moving the Body to the other PoM-part. I manually have to organize everything. Is this the way it is or did I miss a thing? This is for sure a showstopper for really big models where you are not able to realign every feature by hand.
The other question I have is related to newly created axes on the main level next to the two parts after moving the body (please see the screencast). Where are they from? Are the lost or no more needed/duplicates?
Thanks in advance,
HoWil
DeepSOIC
Postby DeepSOIC » Mon Mar 20, 2017 4:36 pm
HoWil wrote:The structure of the PDN-Body is lost after moving the Body to the other PoM-part.
Hi!
Unfortunately, it's a FreeCAD bug at the moment (you should experience the same loss of structure even if you disable PoM observer). So I'm afraid reorganization is fundamentally screwed up as of now.
ickby
Postby ickby » Mon Mar 20, 2017 4:44 pm
Yes, it works badly currently. I have a fix for this and hope to make a pull request soon. (well, said this often enough and still its not done :oops: I try my best)
cox
Postby cox » Mon Mar 20, 2017 10:01 pm
ickby wrote:(well, said this often enough and still its not done :oops: I try my best)
No pressure, remember the motto: it's done when it's done, you are doing great work.
It is better to take your time and have fun, then pressure yourself and burn out.
Thank you, so much for your efforts :D
DeepSOIC
Postby DeepSOIC » Wed Mar 22, 2017 1:01 pm
I have a new tool in part-o-magic: Morph Container.
It's not yet totally done, but mostly it works. Now I need an icon. And so far, I failed to come up with a decent idea for the icon, so I ask for help here.
Here's how the tool works. Let's say, you have a Group in some your old project, and it would be nice to convert it into Part. This is where the tool comes in.
1. Select Group. Invoke the tool.
The tool does nothing yet, it switches into a waiting state. It waits for you do define the new container.
2. You create a new Part.
The tool reacts, moves all the content of Group into the new Part, copies as much properties as it can, redirects all links... and deletes the original Group. Essentially tries to make it look like it used to be a Group, and now it's Part.
triplus
Re: Part-o-magic (again) [icon ideas for new tool wanted!]
Postby triplus » Wed Mar 22, 2017 3:35 pm
Like a new migration tool from current PartDesign model to PartDesign NEXT model? Or what should it do and should be used for?
DeepSOIC
Postby DeepSOIC » Wed Mar 22, 2017 6:12 pm
Ahhh, that stupid PartDesign refuses to make a Part container for old-partdesign projects! And in PoM I just re-used Part creation button... Gotta replace it now.
