I think I managed to get it working without using coin sensors.
This version uses coin engines instead.
When changing the camera type (orthographic / perspective), you need to change a property of the grid, to reattach the new camera to it.
import FreeCAD
import FreeCADGui
import math
from pivy import coin
class gridNode(coin.SoSeparator):
def __init__(self):
super(gridNode, self).__init__()
self.vec = coin.SoTransformVec3f()
#self.vec.matrix.connectFrom(cam.orientation)
self.vec.vector = coin.SbVec3f(0,0,-1)
self.calc = coin.SoCalculator()
self.calc.A.connectFrom(self.vec.direction)
self.calc.expression.set1Value(0,"ta=0.5") # maxviz
self.calc.expression.set1Value(1,"tb=20.0") # factor
self.calc.expression.set1Value(2,"tA=vec3f(1,0,0)") # plane normal
self.calc.expression.set1Value(3,"tc=dot(A,tA)")
self.calc.expression.set1Value(4,"td=fabs(tc)")
self.calc.expression.set1Value(5,"oa=1.0-ta*pow(td,tb)")
self.calc.expression.set1Value(6,"oA=vec3f(oa,0,0)")
self.material1 = coin.SoMaterial()
self.material2 = coin.SoMaterial()
self.material3 = coin.SoMaterial()
self.coord = coin.SoCoordinate3()
self.line1 = coin.SoIndexedLineSet()
self.line2 = coin.SoIndexedLineSet()
self.lineSet = coin.SoIndexedLineSet()
self.addChild(self.coord)
self.addChild(self.material1)
self.addChild(self.line1)
self.addChild(self.material2)
self.addChild(self.line2)
self.addChild(self.material3)
self.addChild(self.lineSet)
self._vector1 = coin.SbVec3f(1,0,0)
self._vector2 = coin.SbVec3f(0,1,0)
self.normal = self._vector1.cross(self._vector2)
self._mainDim = 100
self._subDim = 10
self._maxviz = 1.0
self._factor = 1.0
self._numGridLines = 4
self.material1.diffuseColor = coin.SbColor(1,0,0)
self.material2.diffuseColor = coin.SbColor(0,1,0)
self.material3.diffuseColor = coin.SbColor(0.5,0.5,0.5)
self.material3.transparency.connectFrom(self.calc.oa)
@property
def transparency(self):
return self.material3.transparency.getValues()[0]
@transparency.setter
def transparency(self, tr):
# self.material3.transparency = tr
# self.material2.transparency = tr
@property
def vector1color(self):
return self.material1.diffuseColor.getValues()[0].getValue()
@vector1color.setter
def vector1color(self, color):
self.material1.diffuseColor = (color[0], color[1], color[2])
@property
def vector2color(self):
return self.material2.diffuseColor.getValues()[0].getValue()
@vector2color.setter
def vector2color(self, color):
self.material2.diffuseColor = (color[0], color[1], color[2])
@property
def gridcolor(self):
return self.material3.diffuseColor.getValues()[0].getValue()
@gridcolor.setter
def gridcolor(self, color):
self.material3.diffuseColor = (color[0], color[1], color[2])
@property
def vector1dir(self):
return self._vector1.getValue()
@vector1dir.setter
def vector1dir(self, vec):
self._vector1 = coin.SbVec3f(vec)
self.calc.expression.set1Value(2,"tA=vec3f(%f,%f,%f)"%(self.normal.getValue()[0],self.normal.getValue()[1],self.normal.getValue()[2]))
self.buildGrid()
@property
def vector2dir(self):
return self._vector2.getValue()
@vector2dir.setter
def vector2dir(self, vec):
self._vector2 = coin.SbVec3f(vec)
self.buildGrid()
@property
def mainDim(self):
return self._mainDim
@mainDim.setter
def mainDim(self, n):
self._mainDim = n
self.buildGrid()
@property
def subDim(self):
return self._subDim
@subDim.setter
def subDim(self, n):
self._subDim = n
self.buildGrid()
@property
def maxviz(self):
return self._maxviz
@maxviz.setter
def maxviz(self, n):
self._maxviz = n
self.calc.expression.set1Value(0,"ta=%f"%n) # maxviz
@property
def factor(self):
return self._factor
@factor.setter
def factor(self, n):
self._factor = n
self.calc.expression.set1Value(1,"tb=%f"%n) # factor
def linkTo(self, cam):
def buildGrid(self):
n = int(1.0 * self._mainDim / self._subDim)
r = []
nr = []
for i in range(1,n):
r.append( 1.0 * self._subDim * i)
nr.append(-1.0 * self._subDim * i)
r.append( self._mainDim)
nr.append(-self._mainDim)
nr.reverse()
fullRange = nr + r
pts = []
pts.append(-self._mainDim * self._vector1)
pts.append( self._mainDim * self._vector1)
pts.append(-self._mainDim * self._vector2)
pts.append( self._mainDim * self._vector2)
for i in fullRange:
pts.append(i * self._vector2 - self._mainDim * self._vector1)
pts.append(i * self._vector2 + self._mainDim * self._vector1)
pts.append(i * self._vector1 - self._mainDim * self._vector2)
pts.append(i * self._vector1 + self._mainDim * self._vector2)
self.coord.point.setValues(0,len(pts),pts)
self._numGridLines = len(fullRange) * 2
#self.gridcolor = self.gridcolor
#self.transparency = self.transparency
a = []
l = len(pts)-4
for i in range(l/2):
a.append(2*i + 4)
a.append(2*i + 5)
a.append(-1)
self.line1.coordIndex.setValue(0)
self.line1.coordIndex.setValues(0, 3, [0,1,-1])
self.line2.coordIndex.setValue(0)
self.line2.coordIndex.setValues(0, 3, [2,3,-1])
self.lineSet.coordIndex.setValue(0)
self.lineSet.coordIndex.setValues(0, len(a), a)
class gridObject:
def __init__(self, obj):
obj.Proxy = self
class gridVP:
def __init__(self, obj ):
obj.addProperty("App::PropertyDistance", "Total", "Size", "Size of a grid quadrant").Total = '100mm'
obj.addProperty("App::PropertyDistance", "Subdivision", "Size", "Size of subdivisions").Subdivision = '10mm'
obj.addProperty("App::PropertyFloat", "XY_Attenuation", "View", "XY plane attenuation").XY_Attenuation = 1.0
obj.addProperty("App::PropertyFloat", "XZ_Attenuation", "View", "XZ plane attenuation").XZ_Attenuation = 50.0
obj.addProperty("App::PropertyFloat", "YZ_Attenuation", "View", "YZ plane attenuation").YZ_Attenuation = 50.0
obj.addProperty("App::PropertyFloat", "XY_Visibility", "View", "XY plane max visibility").XY_Visibility = 1.0
obj.addProperty("App::PropertyFloat", "XZ_Visibility", "View", "XZ plane max visibility").XZ_Visibility = 0.5
obj.addProperty("App::PropertyFloat", "YZ_Visibility", "View", "YZ plane max visibility").YZ_Visibility = 0.5
obj.addProperty("App::PropertyColor", "GridColor", "Color", "Grid Color").GridColor = (0.5,0.5,0.5)
obj.Proxy = self
def attach(self, obj):
self.xy = gridNode()
self.xy.vector1dir = (1,0,0)
self.xy.vector1color = (1,0,0)
self.xy.vector2dir = (0,1,0)
self.xy.vector2color = (0,1,0)
self.xy.mainDim = 100
self.xy.subDim = 10
self.xy.maxviz = 1.0
self.xz = gridNode()
self.xz.vector1dir = (1,0,0)
self.xz.vector1color = (1,0,0)
self.xz.vector2dir = (0,0,1)
self.xz.vector2color = (0,0,1)
self.xz.mainDim = 100
self.xz.subDim = 10
self.xz.maxviz = 0.5
self.yz = gridNode()
self.yz.vector1dir = (0,1,0)
self.yz.vector1color = (0,1,0)
self.yz.vector2dir = (0,0,1)
self.yz.vector2color = (0,0,1)
self.yz.mainDim = 100
self.yz.subDim = 10
self.yz.maxviz = 0.5
self.sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
self.cam = FreeCADGui.ActiveDocument.ActiveView.getCameraNode()
self.xy.linkTo(self.cam)
self.xy.factor = 1.
self.xz.linkTo(self.cam)
self.xz.factor = 50.
self.yz.linkTo(self.cam)
self.yz.factor = 50.
self.grid = coin.SoSeparator()
self.grid.addChild(self.xy)
self.grid.addChild(self.xz)
self.grid.addChild(self.yz)
self.sg.addChild(self.grid)
def updateCam(self):
def onChanged(self, vp, prop):
self.updateCam()
if prop == 'Total':
if float(vp.Total) >= float(vp.Subdivision):
self.xy.mainDim = float(vp.Total)
self.xz.mainDim = float(vp.Total)
self.yz.mainDim = float(vp.Total)
else:
vp.Total = vp.Subdivision
if prop == 'Subdivision':
self.xy.subDim = float(vp.Subdivision)
self.xz.subDim = float(vp.Subdivision)
self.yz.subDim = float(vp.Subdivision)
else:
vp.Subdivision = vp.Total
if prop == 'XY_Attenuation':
if vp.XY_Attenuation < 0.1:
vp.XY_Attenuation = 0.1
elif vp.XY_Attenuation > 100:
vp.XY_Attenuation = 100
self.xy.factor = vp.XY_Attenuation
if prop == 'XZ_Attenuation':
if vp.XZ_Attenuation < 0.1:
vp.XZ_Attenuation = 0.1
elif vp.XZ_Attenuation > 100:
vp.XZ_Attenuation = 100
self.xz.factor = vp.XZ_Attenuation
if prop == 'YZ_Attenuation':
if vp.YZ_Attenuation < 0.1:
vp.YZ_Attenuation = 0.1
elif vp.YZ_Attenuation > 100:
vp.YZ_Attenuation = 100
self.yz.factor = vp.YZ_Attenuation
if prop == 'XY_Visibility':
if vp.XY_Visibility < 0.0:
vp.XY_Visibility = 0.0
elif vp.XY_Visibility > 1.0:
vp.XY_Visibility = 1.0
self.xy.maxviz = vp.XY_Visibility
if prop == 'XZ_Visibility':
if vp.XZ_Visibility < 0.0:
vp.XZ_Visibility = 0.0
elif vp.XZ_Visibility > 1.0:
vp.XZ_Visibility = 1.0
self.xz.maxviz = vp.XZ_Visibility
if prop == 'YZ_Visibility':
if vp.YZ_Visibility < 0.0:
vp.YZ_Visibility = 0.0
elif vp.YZ_Visibility > 1.0:
vp.YZ_Visibility = 1.0
self.yz.maxviz = vp.YZ_Visibility
if prop == 'GridColor':
self.xy.gridcolor = vp.GridColor
self.xz.gridcolor = vp.GridColor
self.yz.gridcolor = vp.GridColor
def onDelete(self, feature, subelements):
self.sg.removeChild(self.grid)
return(True)
def main():
obj=FreeCAD.ActiveDocument.addObject("App::FeaturePython","Grid")
gridObject(obj)
gridVP(obj.ViewObject)
if __name__ == '__main__':
main()
