Get current view as RGB matrix or similar
JMG
Post by JMG »
Hi!
Is there a way to get the current scene image (2d) as a rgb/hsv/yuv/etc matrix or at least in a numpy-opencv-tractable form?
I would like to access the scene as if it was a video stream, but I only found how to save a png image and I want to avoid saving/erasing several times per second (if possible).
This is for an experiment about an aumented reality editor (using aruco tags and all that), following this idea:
https://www.youtube.com/watch?v=CzD48UkGsK8
Javier.
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
Re: Get current view as RGB matrix or similar
Post by Kunda1 »
Neato
microelly2
Post by microelly2 »
In my experiments the write to filesystem time is not the bottleneck for performance.
but a solution for this problem is welcome.
