List Select Macro (Select hidden sub-objects)
HoWil
Re: List Select Macro (Select hidden sub-objects)
Postby HoWil » Thu Aug 22, 2019 7:11 pm
realthunder wrote: Thu Aug 22, 2019 11:11 am Yes, it's already in the upstream.
:D yippie :!:
bernd wrote: Ping
Hey Bernd, Is it possible to use it that way in FEM?
HoWil
Postby HoWil » Fri Aug 23, 2019 11:37 am
I did test it with the 0.19_pre appimage and noticed that no solids are listed. Is it possible to add solids as well? A simple test-case is creating a cube and a sphere in Part-wb and applying 'Boolean Fragmenst'. After that there exists a third solid-domain between the cube and the sphere which is the target to select.
Thanks in advance,
BR,
HoWil
Screenshot from 2019-08-23 13-36-31.png (268.22 KiB) Viewed 778 times
BooleanFragments_of_cube_and_sphere.FCStd
sample file for selection
(11.31 KiB) Downloaded 23 times
realthunder
Postby realthunder » Sat Aug 24, 2019 2:45 am
HoWil wrote: Fri Aug 23, 2019 11:37 am I did test it with the 0.19_pre appimage and noticed that no solids are listed. Is it possible to add solids as well? A simple test-case is creating a cube and a sphere in Part-wb and applying 'Boolean Fragmenst'. After that there exists a third solid-domain between the cube and the sphere which is the target to select.
That's a very useful feature that is lacking in the current selection framework. I actually thought about this in the past too. Not easy to add. Let me think about it.
tthomas20
Postby tthomas20 » Tue Jan 28, 2020 8:21 pm
I have updated the code for this macro and it is working in 0.18.4, but when I am in FEM it will not let me select the inner object. I have been trying to follow the tutorial
https://www.freecadweb.org/wiki/FEM_She ... site_Block
and I am stuck on selecting the second object for the second mesh region.
The report view gives me
File "C:\Users\tthomas\AppData\Local\FreeCAD 0.18\Mod\Fem\femguiobjects\FemSelectionWidgets.py", line 496, in addSelection
self.parseSelectionFunction(self.added_obj)
File "C:\Users\tthomas\AppData\Local\FreeCAD 0.18\Mod\Fem\femguiobjects\FemSelectionWidgets.py", line 411, in selectionParser
elt = selection[0].Shape.getElement(selection[1])
<class 'SystemError'>: <built-in method getElement of Part.CompSolid object at 0x000001CACF71DD58> returned NULL without setting an error
I am not quite sure what to do at this point and any help would be appriciated
FEM Of 2 Materials Tutorial.FCStd
(12.9 KiB) Downloaded 9 times
HoWil
Postby HoWil » Sat Feb 01, 2020 8:00 pm
tthomas20 wrote: Tue Jan 28, 2020 8:21 pm I have updated the code for this macro and it is working in 0.18.4
Hi tthomas20,
Can you please share your code. This will make it easier for others to review it and give maybe necessary feedback.
BR
tthomas20
Postby tthomas20 » Mon Feb 03, 2020 3:40 pm
Sure. This should be the most up to date version on GitHub.
SelectionTools_rc.py
(21.89 KiB) Downloaded 21 times
ListSelect.py
(6.21 KiB) Downloaded 19 times
HarryvL
Postby HarryvL » Thu Feb 13, 2020 12:15 pm
Does anybody have (positive) experience with installing the tool under Windows? I put it in a directory .../Src/Mod/SelectionTool but don't know how to get FC to recognise it. It doesn't show up in menu item Edit > Preference > Display as I automatically got under Ubuntu
OS: Windows 10 (10.0)
Version: 0.19.19409 (Git)
Hash: 94280f15cafbabb4af601d78e435f021b261c3d0
Python version: 3.6.8
Qt version: 5.12.1
Locale: English/Denmark (en_DK)
alexu
Postby alexu » Thu Feb 13, 2020 1:09 pm
HarryvL wrote: Thu Feb 13, 2020 12:15 pm Does anybody have (positive) experience with installing the tool under Windows? I put it in a directory .../Src/Mod/SelectionTool but don't know how to get FC to recognise it.
Under Windows, Macros and Workbenches are normally located in:
C:\Users\<$YOUR_USER_NAME>\AppData\Roaming\FreeCAD
Add to Macros or Mod directory as appropriate.
tthomas20
Postby tthomas20 » Thu Feb 13, 2020 6:29 pm
HarryvL wrote: Thu Feb 13, 2020 12:15 pm Does anybody have (positive) experience with installing the tool under Windows? I put it in a directory .../Src/Mod/SelectionTool but don't know how to get FC to recognise it. It doesn't show up in menu item Edit > Preference > Display as I automatically got under Ubuntu
It worked for me on Windows with FC 0.18.4. I didn't put it in …/src/Mod, nor did I put it in the Macro directory.
I added it to...AppData\Local\FreeCAD 0.18\Mod\SelectionTools. After restarting FC it showed up in my preferences.
The only issue I am having now is the one mentioned above where it will not let me select internal objects in the FEM workbench such as to assign a material
HoWil
Postby HoWil » Fri Feb 21, 2020 6:14 pm
tthomas20 wrote: Thu Feb 13, 2020 6:29 pm
Hi tthomas20
Only to be sure, is this your repo? https://github.com/tomate44/SelectionTools
