List Select Macro (Select hidden sub-objects)
HoWil
Re: List Select Macro (Select hidden sub-objects)
Postby HoWil » Thu Aug 22, 2019 7:11 pm
realthunder wrote:
Thu Aug 22, 2019 11:11 am
Yes, it's already in the upstream.
:D yippie :!:
bernd wrote: Ping
Hey Bernd, Is it possible to use it that way in FEM?
HoWil
Postby HoWil » Fri Aug 23, 2019 11:37 am
I did test it with the 0.19_pre appimage and noticed that no solids are listed. Is it possible to add solids as well? A simple test-case is creating a cube and a sphere in Part-wb and applying 'Boolean Fragmenst'. After that there exists a third solid-domain between the cube and the sphere which is the target to select.
Thanks in advance,
BR,
HoWil
Screenshot from 2019-08-23 13-36-31.png (268.22 KiB) Viewed 477 times
BooleanFragments_of_cube_and_sphere.FCStd
sample file for selection
(11.31 KiB) Downloaded 15 times
realthunder
Postby realthunder » Sat Aug 24, 2019 2:45 am
That's a very useful feature that is lacking in the current selection framework. I actually thought about this in the past too. Not easy to add. Let me think about it.
tthomas20
Postby tthomas20 » Tue Jan 28, 2020 8:21 pm
I have updated the code for this macro and it is working in 0.18.4, but when I am in FEM it will not let me select the inner object. I have been trying to follow the tutorial
https://www.freecadweb.org/wiki/FEM_She ... site_Block
and I am stuck on selecting the second object for the second mesh region.
The report view gives me
File "C:\Users\tthomas\AppData\Local\FreeCAD 0.18\Mod\Fem\femguiobjects\FemSelectionWidgets.py", line 496, in addSelection
self.parseSelectionFunction(self.added_obj)
File "C:\Users\tthomas\AppData\Local\FreeCAD 0.18\Mod\Fem\femguiobjects\FemSelectionWidgets.py", line 411, in selectionParser
elt = selection[0].Shape.getElement(selection[1])
<class 'SystemError'>: <built-in method getElement of Part.CompSolid object at 0x000001CACF71DD58> returned NULL without setting an error
I am not quite sure what to do at this point and any help would be appriciated
FEM Of 2 Materials Tutorial.FCStd
(12.9 KiB) Downloaded 1 time
HoWil
Postby HoWil » Sat Feb 01, 2020 8:00 pm
Hi tthomas20,
Can you please share your code. This will make it easier for others to review it and give maybe necessary feedback.
BR
tthomas20
Postby tthomas20 » Mon Feb 03, 2020 3:40 pm
Sure. This should be the most up to date version on GitHub.
SelectionTools_rc.py
(21.89 KiB) Downloaded 3 times
ListSelect.py
(6.21 KiB) Downloaded 3 times
HarryvL
Postby HarryvL » Thu Feb 13, 2020 12:15 pm
Does anybody have (positive) experience with installing the tool under Windows? I put it in a directory .../Src/Mod/SelectionTool but don't know how to get FC to recognise it. It doesn't show up in menu item Edit > Preference > Display as I automatically got under Ubuntu
OS: Windows 10 (10.0)
Version: 0.19.19409 (Git)
Hash: 94280f15cafbabb4af601d78e435f021b261c3d0
Python version: 3.6.8
Qt version: 5.12.1
Locale: English/Denmark (en_DK)
alexu
Postby alexu » Thu Feb 13, 2020 1:09 pm
Under Windows, Macros and Workbenches are normally located in:
C:\Users\<$YOUR_USER_NAME>\AppData\Roaming\FreeCAD
Add to Macros or Mod directory as appropriate.
tthomas20
Postby tthomas20 » Thu Feb 13, 2020 6:29 pm
It worked for me on Windows with FC 0.18.4. I didn't put it in …/src/Mod, nor did I put it in the Macro directory.
I added it to...AppData\Local\FreeCAD 0.18\Mod\SelectionTools. After restarting FC it showed up in my preferences.
The only issue I am having now is the one mentioned above where it will not let me select internal objects in the FEM workbench such as to assign a material
HoWil
Postby HoWil » Fri Feb 21, 2020 6:14 pm
Hi tthomas20
Only to be sure, is this your repo? https://github.com/tomate44/SelectionTools
