How to run the freecad-python scripts in the command line?
Tom28
Post by Tom28 »
I have a pyhton script which works well in the FreeCad Python console.
But I want to run it through the command-line in order to get it automated.
I searched a lot and tried so far two things:
- opening the FreeCadCmd.exe but there seems no python scripts working
- opening the python.exe in the /bin folder of Freecad. This seems also not to work when I put there the python code ... or do I need to load some librarys first?
Does anyone have experience with that?
Many thanks
Tom
GSR
Re: How to run the freecad-python scripts in the command line?
Post by GSR »
Hi Tom28,
On my machine, all I need to do is add the path to the FreeCAD libraries to the system path and then import FreeCAD from there. I add the following code block at the top of my scripts with the rest of my module imports.
-GSR
# FreeCAD related modules
# For 0.16 stable
sys.path.append('/usr/lib/freecad/lib')
# For 0.17 daily developmental
# sys.path.append('/usr/lib/freecad-daily/lib')
import FreeCAD
import Part
import Sketcher
Leatherman
Post by Leatherman »
GSR wrote: Sun Aug 13, 2017 8:08 pm Hi Tom28,
-GSR
# For 0.16 stable
import FreeCAD
import Part
import Sketcher
That's a good one. Thank you. :D
ickby
Post by ickby »
Normally all you need to do is to pass the script as command line argument, like
FreeCADcmd.exe myScript.py
(syntax is for windows, but the principle holds for all Operating Systems)
Tom28
Post by Tom28 »
thanks a lot I will try both and inform you if it is working
Many thanks
Tom
triplus
Post by triplus »
There is one more option available from the FreeCAD GUI:
https://forum.freecadweb.org/viewtopic. ... 76#p180338
Tom28
Post by Tom28 »
ickby wrote: Mon Aug 14, 2017 5:43 am Normally all you need to do is to pass the script as command line argument, like
This works for me and seems for me a very easy way to accomplish this
Many thanks to all
Tom
ajarivas72
Post by ajarivas72 »
Hello
In Linux use the following command:
freecadcmd myscript.py
luimuyi
Post by luimuyi »
ajarivas72 wrote: Sun Sep 23, 2018 5:14 am Hello
I tried this command on Linux, but it will report an error:'[Cannot load Gui module in console application.]'
openBrain
Post by openBrain »
luimuyi wrote: Sun Aug 02, 2020 1:47 am
Which seems logical. 'freecadcmd' is the CLI command so it has no awareness of the GUI part.
If your script is UI based, you have to run 'freecad my script.py'.
