Measure/Measure Angular in python
more11
Postby more11 » Tue Oct 10, 2017 7:48 pm
I need some help scripting measurements. Three is nothing in documentation or in the forum. There is no output in Python console when doing it in the gui.
The Draft.makeAngularMeasurement doesn't work for me as I am doing my stuff in 3D using Part.
Point taken :-)
easyw-fc
Re: Measure/Measure Angular in python
Postby easyw-fc » Tue Oct 10, 2017 8:45 pm
Hi @more11
I've started to work at my Manipulator workbench exactly for that reason...
I have an Aligner, a Mover and a Caliper that are working with Part objects
https://forum.freecadweb.org/viewtopic.php?f=9&t=24742
https://forum.freecadweb.org/viewtopic. ... 61#p194777
ATM I've not finished yet the part related to angular measurement... I think it will be available in few days
Please have a try with the WB and give me some feedback :D
Maurice
more11
Postby more11 » Wed Oct 11, 2017 3:43 am
Thanks Maurice! Link to your source code?
Point taken :-)
Postby Kunda1 » Wed Oct 11, 2017 3:49 am
https://github.com/easyw/Manipulator
easyw-fc
Postby easyw-fc » Wed Oct 11, 2017 9:29 pm
I made some improvement with the Caliper
I have some issue on some angles ... but it is quite near :D
Maurice
Postby Kunda1 » Thu Oct 12, 2017 3:10 am
:o
Leatherman
Postby Leatherman » Thu Oct 12, 2017 11:38 am
indeed a very helpful wb and an impressive work. Thanks :D
more11
Postby more11 » Thu Oct 12, 2017 8:00 pm
I have tried the WB. It doesn't work properly for me. I want to measure angles on wires. This is how I make wires:
def makeWire(points, closed=True):
    lines = []
    for i in range(0, len(points)-1):
        lines.append(Part.makeLine(points[i], points[i+1]))
    if closed:
        lines.append(Part.makeLine(points[len(points)-1], points[0]))
    wire = Part.Wire(lines)
    return wire
The I create faces with Part.Face(), which I then extrude() the face.
I can upload a drawing if you would like something to work on.
The "Measure/Measure Angle" works as it should.
Mårten
Point taken :-)
more11
Postby more11 » Thu Oct 12, 2017 8:03 pm
Since I want to make the measurements in my python code generating the drawing, it would be fantastic if you could print the calls with its parameters to the python console. With this output maybe I can figure out how to call the workbench code from python.
Point taken :-)
easyw-fc
Postby easyw-fc » Thu Oct 12, 2017 8:21 pm
Mårten
the Caliper is aimed to work as a friendly Gui, not as a library to be called...
Anyway your issue is due to the fact that my routines work with 3D objects, getting Edges from those, and not with Wires ...
A reference library for getting Angles in python is there
https://www.freecadweb.org/wiki/FreeCAD ... th_library
If you need to consider Part/Body recursive placement you can have a look at Caliper.py or Mover.py to see how I did it
Maurice
