All new features are now merged.
shai
Hi @shaise,
https://forum.freecadweb.org/viewtopic. ... 00#p257892ulrich1a wrote: ↑Sat Sep 22, 2018 5:16 pm I have updated my script on https://github.com/ulrich1a/sheet_ufo
It produces now profiles, bend lines and labels in Visgroups. These Visgroups can be exported into an Autodesk DXF 2D format and go there into respective layers. Although the export of the text into DXF does still not work due to a bug in the exporter but is maybe also not necessary.
A spreadsheet with the bend data: radius, bend direction and k-factor is generated.
Ulrich
I just found this. These new sketch-based features are fantastic. The problem is, their discoverability factor is nil. There is no chance an end user will know about them without seeing this forum topic.
Bend
|__ Sketch
What do you think?yorik wrote:ping
