help on sheet metal script
f3nix
Re: help on sheet metal script
Postby f3nix » Fri Jan 11, 2019 8:40 pm
Hi.
Could someone check if this is reproducible? Or am I missing something?
I'm using 4mm steel in this example.
It should be a 90x90 L-bracket.
1. kfactor set to 0,86 and unfold parameter set to true
Total unfolded length is 172,98mm
This is right for a cnc press I will be using.
2. kfactor set to 0,86 and unfold parameter set to false.
Select a face and click unfold. Leave the checkboxes unchecked.
Total unfolded length is 172,33mm
3. kfactor set to 0,86 and unfold parameter set to false.
Select a face and click unfold. Set manual k-factor to 0,86.
Total unfolded length is 175,69mm.
Thanks for your great work! :)
Cheers,
Mateusz
FreeCAD SheetMetal - 557a8fb67d903ffb8b8f6a640d192da5b56a7501
OS: Debian GNU/Linux buster/sid
Version: 0.18.15592 (Git)
Build type: Debug
Hash: a7c0f4bc5b62ec304a5855796ca3d10a42c7a46e
Python version: 2.7.15+
Qt version: 5.11.3
Locale: Polish/Poland (pl_PL)
L-bracket-test.FCStd
(20.55 KiB) Downloaded 35 times
bavariaSHAPE
Postby bavariaSHAPE » Fri Jan 18, 2019 10:07 pm
Hello dear FreeCAD forum friends,
while working into the Sheet Metal WB I noticed the following:
1. relief Type set to round
2. relief factor set to true
Result: »relief Type« is displayed »rectangle«, not »round«. The »relief factor« is used correctly.
If I switch the »Use Relief factor« to false again, the »relief Type« is »round« again.
Can anyone reproduce that?
:idea: Achim
Sheet Metal: V0.2.20 10 Jan 2019
OS: Windows 7
Version: 0.17.13509 (Git)
Branch: releases/FreeCAD-0-17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.14
OCC version: 7.2.0
Parameter.FCStd
(27.72 KiB) Downloaded 29 times
jaisejames
Postby jaisejames » Sat Jan 19, 2019 2:36 pm
Round relief is with half circle. It work only if depth is greater width of relief.
Reason - no of face created in rectangle is three. no of face created need to be three in round also. If not whatever features created after that keep jumping due to face number change during toggling rectangle to round.
jaisejames
Postby jaisejames » Wed Jan 23, 2019 11:58 am
Hi.
Cheers,
Mateusz
Build type: Debug
Qt version: 5.11.3
Thank for reporting issue. I request Shaise to correct it.
shaise
Postby shaise » Thu Jan 24, 2019 9:23 am
Hi f3nix,
The problem is difference between European and American standard of k_facror (one of them is 1/2 the other). I have now changed the unfold system to European standard (which is compatible with Ulrich's original unfolder script). Now both unfolding from the properties, and the unfolding button match.
Please update.
shai
jaisejames
Postby jaisejames » Thu Jan 24, 2019 1:46 pm
Solid Shape to Sheet metal Tutorial.
Steps:
[example created using 70 x 50 x 30 cube ]
Step 1 - Fillet all Object to (thickness + radius ). say thk = 1.0 & Radius = 1.0 .So fillet radius = 1.0 +1.0 = 2.0
Step 2 - Change to draft workbench, select faces required & select facebinder tool
Step 3 - Change to Part work Bench, use 3d offset & set -1mm for inside one.
unfolding view
f3nix
Postby f3nix » Thu Jan 24, 2019 4:36 pm
Hi f3nix,
Please update.
shai
Hi!
Thank you both! :)
Discussion continued on GitHub.
Cheers,
Mateusz
jaisejames
Postby jaisejames » Fri Feb 01, 2019 11:53 am
A simple Solid shape to sheet metal tool
solid model.png (7.33 KiB) Viewed 721 times
solid to sheetmetal.png (14.72 KiB) Viewed 721 times
Code attached.
SheetMetalSolidtoSMCmd.py
(11.82 KiB) Downloaded 37 times
Postby chrisb » Fri Feb 01, 2019 1:01 pm
Interesting extension. Will it be integrated in SheetMetal?
shaise
Postby shaise » Sun Feb 03, 2019 5:54 pm
Great feature!
However I found out that the order of selecting the edges sometimes generate error.
For example in the attached file, if you select the edges in the following order, it makes an error:
The error:
File "D:\Downloads\download\freecad\FreeCAD_0.18\Mod\FreeCAD_SheetMetal\SheetMetalSolidtoSMCmd.py", line 150, in execute
selFaceNames = fp.baseObject[1], MainObject = fp.baseObject[0])
File "D:\Downloads\download\freecad\FreeCAD_0.18\Mod\FreeCAD_SheetMetal\SheetMetalSolidtoSMCmd.py", line 129, in smShape
base_solid = base_shell.makeOffsetShape(thk, 0.001, inter = False, self_inter = False, offsetMode = 0, join = 0, fill = True)
<class 'Part.OCCError'>: Geom_RectangularTrimmedSurface::U1==U2
But if you select in different order, it can work.
testsolidsm.FCStd
(3.39 KiB) Downloaded 22 times
