help on sheet metal script
Re: help on sheet metal script
Postby chrisb » Sat Jun 23, 2018 9:12 pm
shaise wrote:
Sat Jun 23, 2018 9:04 pm
Can try selecting different faces for the unfold, then try converting to sketch?
Selecting different faces the unfold projection is always in XY plane. Is this on purpose? Converting to sketch worked in all cases (which I tried).
Bildschirmfoto 2018-06-23 um 23.09.20.png (20.31 KiB) Viewed 623 times
shaise
Postby shaise » Sat Jun 23, 2018 9:35 pm
Here is my file, where it failed (attached)
I have selected the outside left wall of bend005, unfold and try to draft convert to sketch.
TestSheetmetalProject.FCStd
(13.71 KiB) Downloaded 14 times
easyw-fc
Postby easyw-fc » Sat Jun 23, 2018 10:23 pm
shaise wrote:
Sat Jun 23, 2018 8:47 pm
The generated projection is a part, not a sketch. It looks like if I try to unfold by selecting a standing wall as a seed to unfold, the outcome projection can not be converted to sketch (I get a c++ error. bug?)
Thanks!
shai
Hi @shai,
please have a try with the attached file.
I have added the code to create a sketch from the projection (and I set the transparency of the Undold to 70%).
SheetMetalUnfolder.py
(64.1 KiB) Downloaded 16 times
Feel free to adapt or modify as you prefer.
Thanks again for your WB. it is very useful! :D
PS I tested fine with some old user cases:
https://forum.freecadweb.org/viewtopic. ... 10#p229329
https://forum.freecadweb.org/viewtopic. ... 40#p225073
https://forum.freecadweb.org/viewtopic. ... 20#p200544
easyw-fc
Postby easyw-fc » Sat Jun 23, 2018 10:35 pm
Hi @shai,
I noticed your post after posting my code...
I managed to change my code to work with your example too.
(64.16 KiB) Downloaded 19 times
here it is.
Please have a try.
shaise
Postby shaise » Sun Jun 24, 2018 5:31 am
Hi easyw,
No, it still have the same issue. Load the attached file, click on the left wall (the green face in the image) and perform unfold. The same error. (happens only on certain faces)
shai
TestSheetmetalProject1.FCStd
(7.79 KiB) Downloaded 17 times
easyw-fc
Postby easyw-fc » Sun Jun 24, 2018 8:23 am
Hi easyw,
shai
This issue could happens also when doing the conversion through the Draft Menu 'Draft to Sketch'
('[Draft.todo.commit] Unexpected error:', <class 'Base.FreeCADError'>, 'in ', <built-in method closeDialog of tuple object at 0x000001EEBAC047C8>, '(', None, ')')
It seems a bug in orienting the edges when converting the edges to the Sketch.
We could fill a bug with a simple example.
Anyway, the actual code is adding already a very useful feature :)
shaise
Postby shaise » Sun Jun 24, 2018 9:06 am
Indeed This is helpful. At first I thought it will be quite complex to add the fold lines (as the unfold code is not mine, and I'm not as talented as Ulrich1a...) But it turned out to be ok.
I will now wrap up things (I want to add a task dialog, so the user can select weather to generate the sketch or not) and commit it to the main code.
Thanks for all the help with the sample code.
shai
easyw-fc
Postby easyw-fc » Sun Jun 24, 2018 3:05 pm
Thanks a lot!
I was trying to create a Sketch using the edges and creating the geometry, but I cannot generate correctly open Arcs...
Here my tentative:
import FreeCAD, Draft, Sketcher
doc = App.ActiveDocument
edges = doc.UnfoldProjection.Shape.Edges
# doc.Shape2DView_sc.Shape.Edges #App.ActiveDocument.UnfoldProjection.Shape.Edges
usk = FreeCAD.activeDocument().addObject('Sketcher::SketchObject',"Unfold_Sketch")
for e in edges:
    print e.Curve
geo=[]
for e in edges:
    if 'Line' in str(e.Curve):
        geo.append(Part.LineSegment(e.Vertexes[0].Point,e.Vertexes[1].Point))
    elif 'Circle' in str(e.Curve):
        Radius = e.Curve.Radius
        Center = e.Curve.Center
        Axis = e.Curve.Axis
        StartAngle = e.Curve.FirstParameter
        EndAngle = e.Curve.LastParameter
        geo.append(Part.ArcOfCircle( Part.Circle(Center,Axis,Radius),StartAngle,EndAngle , False))
#print geo
usk.addGeometry(geo)
doc.recompute()
I'm attaching also the FC file
test-sketch-2.FCStd
(38.6 KiB) Downloaded 19 times
I cannot create a not closed Arc
shaise
Postby shaise » Sun Jun 24, 2018 6:03 pm
is this to bypass the Draft.makeSketch?
easyw-fc
Postby easyw-fc » Sun Jun 24, 2018 6:08 pm
Hi Shai,
I've solved the issue of Arcs...
Here the code that will generate Sketches in all cases... What are not considered are BSplines.. but they shouldn't be in the generated UnfoldProjection, if I recall correctly...
(64.88 KiB) Downloaded 17 times
Please have a try :D
test-sketch-3.FCStd
(38.17 KiB) Downloaded 18 times
