Macros troubleshooting?
OakLD
Postby OakLD » Fri Jan 12, 2018 7:52 pm
is there no info on macros troubleshooting? I tried to search posts and docs and found none.
Apart from the broad question, to start with a example, I have a problem executing FCinfo macro. It gives me no errors, no python console messages, no report messages. So I have no idea where to start troubeshooting. Tested with several files, including a simple bar made from scratch.
Running FC 0.16 / 6712 on WinXP x64.
Regards,
Oak
Regards,
Oak
Re: Macros troubleshooting?
Postby chrisb » Fri Jan 12, 2018 10:09 pm
How did you install FCInfo?
OakLD
Postby OakLD » Sat Jan 13, 2018 8:08 pm
I installed it using macro addons_installer.FCmacro.
Regards,
Oak
GeneFC
Postby GeneFC » Sat Jan 13, 2018 9:49 pm
In my experience FCInfo creates a docked window, but the window is initially closed. Look around in the corners of your display. It could be behind something else, such as the report panel.
There is no interaction with the report panel or the python console. I have no idea is this behavior is due to some system settings I use, but I did not do anything special for FCInfo.
Gene
mario52
Postby mario52 » Sun Jan 14, 2018 3:29 pm
hi
the macro begin below the window see the video
the little problem with this version .. the macro stay always resident
you can modify the value line 185 for not docking (window separate time to find)
global testing       ; testing       = 2     # if testing == 1 MainWindow separate
                                             # if testing == 2 RightDock
                                             # else       == other LeftDock
and modify to 1
global testing       ; testing       = 1     # if testing == 1 MainWindow separate
here where is the macro FCInfo (version docked)
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
OakLD
SOLVED Re: Macros troubleshooting?
Postby OakLD » Mon Jan 15, 2018 12:24 am
Hello
Thank you for your help, it lead me to a solution.
I didn't find the panel anywhere in within the FreeCAD, but when I looked at the macro file carefully, I found out it contains only 1 line, while Mario refered to line 185... I looked up the file on the web and downloaded and installed it manually and now it runs, although without the panel and icons, for the moment.
Regards,
Oak
mario52
Postby mario52 » Mon Jan 15, 2018 9:54 am
hi
if you give the value 1 in line 185 the window is not docked and same this:
download the icon here
Macro_FCInfo_Icon.zip
(52.91 KiB) Downloaded 1075 times
i create a zip file, uncompress the zip and copy the file image in the same directory of the macro
now i search for ameliorate...
mario
