I am searching for macro for Aligning Section Plane to selected Face.
Any macro exist?
Align Section Plane to selected Face
Re: Align Section Plane to selected Face
hi
example create plane to selected face (all directions)
EDIT 27/09/2021 11h09 Paris : adding the parenthesis on print() for compatible Python 3
mario
#https://forum.freecadweb.org/viewtopic.php?f=22&t=27002&p=216033&hilit=Macro_FCPlane#p216033
#Align Section Plane to selected Face
# -*- coding: utf-8 -*-
from __future__ import unicode_literals
* Copyright (c) 2017 2018 <mario52> *
* This file is a supplement to the FreeCAD CAx development system. *
* This program is free software; you can redistribute it and/or modify *
* it under the terms of the GNU Lesser General Public License (LGPL) *
* as published by the Free Software Foundation; either version 2 of *
* the License, or (at your option) any later version. *
* for detail see the LICENCE text file. *
* Use at your own risk. The author assumes no liability for data loss. *
* It is advised to backup your data frequently. *
* If you do not trust the software do not use it. *
* This software is distributed in the hope that it will be useful, *
* but WITHOUT ANY WARRANTY; without even the implied warranty of *
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
* GNU Library General Public License for more details. *
* You should have received a copy of the GNU Library General Public *
* License along with this macro; if not, write to the Free Software *
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 *
* USA *
* http://www.freecadweb.org/wiki/index.php?title=Macro_FCCircularText *
* WARNING! All changes in this file will be lost and *
* may cause malfunction of the program *
__Title__ = "FCPlane"
__Author__ = "Mario52"
__Version__ = "00.00"
__Date__ = "20/02/2018"
import Draft
from FreeCAD import Base
App = FreeCAD
doc = FreeCAD.ActiveDocument
if doc == None:
doc = FreeCAD.newDocument()
selectedEdge = FreeCADGui.Selection.getSelectionEx()[0].SubObjects[0] # select one element
sel = FreeCADGui.Selection.getSelection()
diagonalObject = int(sel[0].Shape.BoundBox.DiagonalLength)
plr = plDirection = FreeCAD.Placement()
if hasattr(selectedEdge,'Surface'):
print( "surface")
########## section direction
yL = selectedEdge.CenterOfMass
uv = selectedEdge.Surface.parameter(yL)
nv = selectedEdge.normalAt(uv[0], uv[1])
direction = yL.sub(nv + yL)
r = App.Rotation(App.Vector(0,0,1),direction)
plDirection.Rotation.Q = r.Q
plDirection.Base = yL
plr = plDirection
boundBoxLX = boundBoxLY = boundBoxLZ = diagonalObject
FCSpring = doc.addObject("App::DocumentObjectGroup","FcPlane")
plan = App.ActiveDocument.addObject("Part::Plane","PlaneX-R")
plan.Length=boundBoxLZ
plan.Width=boundBoxLX
plan.Placement = plr
plan.Placement.Rotation = plan.Placement.Rotation.multiply(App.Rotation(0,-90,0))
plan.Placement = plan.Placement.multiply(App.Placement(App.Vector(-float(plan.Length)/2.0,-float(plan.Width)/2.0,0.0), App.Rotation(App.Vector(0.0,0.0,0.0),0.0), App.Vector(0,0,0)))
plan.ViewObject.LineColor = (1.00000,0.66667,0.00000)
plan.ViewObject.ShapeColor = (0.6,0.0,0.0)
plan.ViewObject.Transparency = 90
plan.ViewObject.LineWidth = 1.0
FCSpring.addObject(plan)
plan = App.ActiveDocument.addObject("Part::Plane","PlaneY-V")
plan.Length=boundBoxLY
plan.Width=boundBoxLZ
plan.Placement.Rotation = plan.Placement.Rotation.multiply(App.Rotation(0,0,90))
plan.ViewObject.ShapeColor = (0.0,0.6,0.0)
plan = App.ActiveDocument.addObject("Part::Plane","PlaneZ-B")
plan.Length=boundBoxLX
plan.Width=boundBoxLY
plan.ViewObject.LineColor = (1.0,1.0,1.0)
plan.ViewObject.ShapeColor = (0.0,0.0,0.6)
#create axis
points=[FreeCAD.Vector(0.0,0.0,0.0),FreeCAD.Vector(0.0,0.0,boundBoxLX)]
centerX = Draft.makeWire(points,closed=False,face=False,support=None)
centerX.Placement = plr
centerX.Placement.Rotation = centerX.Placement.Rotation.multiply(App.Rotation(0,90,0))
centerX.Placement = centerX.Placement.multiply(App.Placement(App.Vector(0.0,0.0,-float(boundBoxLX)/2.0), App.Rotation(App.Vector(0.0,0.0,0.0),0.0), App.Vector(0,0,0)))
centerX.ViewObject.LineColor = (1.0,1.0,1.0)
centerX.ViewObject.LineWidth = 1.0
centerX.ViewObject.DrawStyle = str("Dashdot")
centerX.Label = str("Axis White PlaneX")
FCSpring.addObject(centerX)
centerY = Draft.makeWire(points,closed=False,face=False,support=None)
centerY.Placement = plr
centerY.Placement.Rotation = centerY.Placement.Rotation.multiply(App.Rotation(0,90,90))
centerY.Placement = centerY.Placement.multiply(App.Placement(App.Vector(0.0,0.0,-float(boundBoxLX)/2.0), App.Rotation(App.Vector(0.0,0.0,0.0),0.0), App.Vector(0,0,0)))
centerY.ViewObject.LineColor = (1.0,1.0,1.0)
centerY.ViewObject.LineWidth = 1.0
centerY.ViewObject.DrawStyle = str("Dashdot")
centerY.Label = str("Axis White PlaneY")
FCSpring.addObject(centerY)
centerZ = Draft.makeWire(points,closed=False,face=False,support=None)
centerZ.Placement = plr
centerZ.Placement.Rotation = centerZ.Placement.Rotation.multiply(App.Rotation(0,0,0))
centerZ.Placement = centerZ.Placement.multiply(App.Placement(App.Vector(0.0,0.0,-float(boundBoxLX)/2.0), App.Rotation(App.Vector(0.0,0.0,0.0),0.0), App.Vector(0,0,0)))
centerZ.ViewObject.LineColor = (1.0,1.0,1.0)
centerZ.ViewObject.LineWidth = 1.0
centerZ.ViewObject.DrawStyle = str("Dashdot")
centerZ.Label = str("Axis White PlaneZ")
FCSpring.addObject(centerZ)
FreeCAD.ActiveDocument.recompute()
else:
print( "select a face")
mario
you may want to see atjaisejames wrote: ↑Tue Feb 20, 2018 6:32 am I am searching for macro for Aligning Section Plane to selected Face.
Any macro exist?
Manipulator WB
Aligner does it
(old macro was https://www.freecadweb.org/wiki/Macro_C ... s_or_Edges)
Thank you all for quick support. I will study these macros.
My aim to Draft section plane work automatically align
First I will have to create Boundbox size based on Section plane linked objects[as given code]. Then I need to align to selected face based on above macros.
Also align based on Draft Axis. so I can generate sectional view quickly.
import Part
ObjectsList = [ sub.Shape for sub in obj.Objects ]
pc = Part.Compound(ObjectsList)
obj.ViewObject.DisplayLength = pc.BoundBox.XLength
obj.ViewObject.DisplayHeight = pc.BoundBox.YLength
i am able to create a macro. but it is not working. pls see the below code
import Arch, Part
import FreeCAD as App
import FreeCADGui as Gui
v = Gui.activeDocument().activeView()
class Select_object:
def __init__(self,view):
self.SectionPlane = None
self.selectedEdge = None
self.view = view
App.Console.PrintMessage("choose the SectionPlane\n")
Gui.Selection.clearSelection()
self.klick_event = self.view.addEventCallback(
"SoMouseButtonEvent", self.choose_SectionPlane)
def choose_SectionPlane(self, cb):
if cb["State"] == "DOWN":
sel = Gui.Selection.getSelection()
if len(sel) > 0:
self.SectionPlane = sel[0]
self.view.removeEventCallback(
"SoMouseButtonEvent", self.klick_event)
"SoMouseButtonEvent", self.choose_Face)
App.Console.PrintMessage("choose_Face_to_Align\n")
def choose_Face(self, cb):
selectedEdge = Gui.Selection.getSelectionEx()[0].SubObjects[0] # select one element
if sel:
self.Align_SectionPlane(self.SectionPlane,selectedEdge)
def Align_SectionPlane(self,SectionPlane,selectedEdge):
ObjectsList = [ obj.Shape for obj in SectionPlane.Objects ]
diagonalObject = int(pc.Shape.BoundBox.DiagonalLength)
print "surface"
plr = plDirection
########## make Section Plane Aligned to selected face
SectionPlane.ViewObject.DisplayHeight = boundBoxLX
SectionPlane.ViewObject.DisplayLength = boundBoxLY
SectionPlane.Placement = plr
SectionPlane.Placement = SectionPlane.Placement.multiply(App.Placement(App.Vector(-float(boundBoxLX)/2.0,-float(boundBoxLY)/2.0,0.0), App.Rotation(App.Vector(0.0,0.0,0.0),0.0), App.Vector(0,0,0)))
App.activeDocument().recompute()
SectionPlane.ViewObject.LineColor = (1.00000,0.66667,0.00000)
SectionPlane.ViewObject.LineWidth = 1.0
Select_object(v)
I change some code . now it is working
import Arch, Part
view = Gui.ActiveDocument.ActiveView
class Select_object(object):
self.view = Gui.ActiveDocument.ActiveView
self.klick_event = self.view.addEventCallback("SoMouseButtonEvent", self.choose_SectionPlane)
if len(sel) > 0:
self.view.removeEventCallback("SoMouseButtonEvent", self.klick_event)
self.klick_event = self.view.addEventCallback("SoMouseButtonEvent", self.choose_Face)
sel = Gui.Selection.getSelectionEx()
if len(sel) > 0:
selectedEdge = sel[0].SubObjects[0] # select one element
diagonalObject = int(pc.BoundBox.DiagonalLength)
print "surface"
plr = plDirection
Select_object(view)
