Part.Cross_sections Object type
mermaldad
Post by mermaldad »
I have a question about the type associated with the output of the cross-sections operation on the Part Workbench. I am working with them in a script, and I have found that if I create cross-sections on a fusion, the resulting object is a Part.Feature. However, if I create cross-sections of a simple object, like a pad, the resulting object is of type NoneType. My workaround is to fuse two pads, one contained within the other, but I'd like to know if there is a more elegant way to handle this. For example, can the NoneType cross-sections be converted to something that has a Shape?
OS: Ubuntu 16.04.4 LTS
Version: 0.16.6712 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
ulrich1a
Re: Part.Cross_sections Object type
Post by ulrich1a »
Can you supply a sample script, that shows the behavior? It makes it easier to answer.
Ulrich
mermaldad
Post by mermaldad »
Here it is. In trying to create it, I discovered an interesting clue: Originally I created and sliced the plain figure, then the compound figure. It worked. Both "_cs" objects were of type "Part:Feature". If, however, I reverse the order as in the code below, the "_cs" object for the plain figure is of type "NoneType".
# Step 1: Create a new document
App.newDocument("Unnamed")
# Step 5: Use Part:Box to create another cube
App.ActiveDocument.addObject("Part::Box","Box")
App.ActiveDocument.ActiveObject.Label = "Cube"
# Step 6: Use Part:Cylinder to create a cylinder
App.ActiveDocument.addObject("Part::Cylinder","Cylinder")
App.ActiveDocument.ActiveObject.Label = "Cylinder"
# Step 7: Move to cylinder to enclose it within the second cube
App.getDocument("Unnamed").Cylinder.Placement=App.Placement(App.Vector(2.54,2.54,0), App.Rotation(App.Vector(0,0,1),0), App.Vector(0,0,0))
# Step 8: Use Part:Union to fuse the second cube and cylinder together
App.activeDocument().addObject("Part::MultiFuse","Fusion")
App.activeDocument().Fusion.Shapes = [App.activeDocument().Box,App.activeDocument().Cylinder,]
# Step 9: Use Part:Cross Section to create a cross-section object (again auto-generated code)
from FreeCAD import Base
wires=list()
shape=FreeCAD.getDocument("Unnamed").Fusion.Shape
for i in shape.slice(Base.Vector(0,0,1),4.99999):
    wires.append(i)
comp=Part.Compound(wires)
slice=FreeCAD.getDocument("Unnamed").addObject("Part::Feature","Fusion_cs")
slice.Shape=comp
slice.purgeTouched()
del slice,comp,wires,shape
# Step 2: Use Part:Box to create a cube
# Step 3: move it from the origin
App.getDocument("Unnamed").Box.Placement=App.Placement(App.Vector(0,25.4,0), App.Rotation(App.Vector(0,0,1),0), App.Vector(0,0,0))
# Step 4: Use Part:Cross Sections to create a cross section object; note that the code here was auto-generated
wires=list()
shape=FreeCAD.getDocument("Unnamed").Box.Shape
    wires.append(i)
slice=FreeCAD.getDocument("Unnamed").addObject("Part::Feature","Box_cs")
slice.Shape=comp
# Step 10: Examine objects in model
ob = FreeCAD.getDocument("Unnamed").getObject("Fusion")
print("type(Fusion): ",type(ob))
ob = FreeCAD.getDocument("Unnamed").getObject("Fusion_cs")
print('type(Fusion_cs): ', type(ob))
ob = FreeCAD.getDocument("Unnamed").getObject("Box001")
print("type(Box001): ",type(ob))
ob = FreeCAD.getDocument("Unnamed").getObject("Box001_cs")
print('type(Box001_cs): ', type(ob))
with output:
('type(Fusion): ', <type 'Part.Feature'>)
('type(Fusion_cs): ', <type 'Part.Feature'>)
('type(Box001): ', <type 'Part.Feature'>)
('type(Box001_cs): ', <type 'NoneType'>)
