recovering viewprovider after working in no-gui-mode
looo
Postby looo » Wed Apr 18, 2018 2:08 pm
Ssomehow the python proxy of the viewprovider gets lost after working in no-gui-mode (jupyter-notebook). While it makes sense that no view-provider is stored in no-gui-mode, my object won't work without the proxy of the viewprovider.
the 2 attachments show the problem.
1. create line in draft and save as fc_with_gui.fcstd
2. start fc in no-gui mode:
import FreeCAD
doc = FreeCAD.openDocument("fc_with_gui.fcstd")
doc.save("fc_without_gui.fcstd")
3. open the file in freecad (with gui)
(2.11 KiB) Downloaded 9 times
fc_with_gui.fcstd
(3.76 KiB) Downloaded 11 times
microelly2
Re: recovering viewprovider after working in no-gui-mode
Postby microelly2 » Wed May 02, 2018 10:39 am
Does it make sense to recreate the viewprovider after "the document is restored"?
onDocumentRestored(self, obj):
ViewProvider(obj.ViewObject)
looo
Postby looo » Wed May 02, 2018 4:07 pm
microelly2 wrote:Does it make sense to recreate the viewprovider after "the document is restored"?
I am not sure if it is the right way. I guess this fnction is also called in nogui-mode.
microelly2
Postby microelly2 » Wed May 02, 2018 8:29 pm
[I am not sure if it is the right way. I guess this fnction is also called in nogui-mode.
but you can check whether the gui is up at that moment
looo
Postby looo » Wed May 02, 2018 10:39 pm
yes thats a good idea.
