why 1pyramid?(4)array or class
mrrclb48z
Postby mrrclb48z » Fri Apr 27, 2018 1:39 pm
?1. global name?
?2. I want argument ----> array or class
macro---->short source
I do not understand Python.
Thank you in advance and sorry for the bad english!
import FreeCAD
import Part
import DraftTools
import Draft
import Mesh
def myPyramidCal(xIn,yIn,bIn,hIn):
        x = float(xIn)
        y = float(yIn)
        b = float(bIn)
        h = float(hIn)
        x2 = x+b*0.5
        y2 = y+b*0.5
        x3 = x+b
        y3 = y+b
        z = 0
        z2 = h
        P1x=x
        P1y=y
        P1z=z
        P2x=x
        P2y=y3
        P2z=z
        P3x=x3
        P3y=y3
        P3z=z
        P4x=x3
        P4y=y
        P4z=z
        P5x=x2
        P5y=y2
        P5z=z2
        return P1x,P1y,P1z,P2x,P2y,P2z,P3x,P3y,P3z,P4x,P4y,P4z,P5x,P5y,P5z
def myPyramidSld(P1x,P1y,P1z,P2x,P2y,P2z,P3x,P3y,P3z,P4x,P4y,P4z,P5x,P5y,P5z):
        a =[[x,y,z],          #dummy
            [P1x,P1y,P1z],
            [P2x,P2y,P2z],
            [P3x,P3y,P3z],
            [P4x,P4y,P4z],
            [P5x,P5y,P5z]]
        m1 = Mesh.Mesh([a[2],a[5],a[3]])
        m2 = Mesh.Mesh([a[4],a[5],a[1]])
        m3 = Mesh.Mesh([a[1],a[5],a[4]])
        m4 = Mesh.Mesh([a[4],a[3],a[5]])
        m5 = Mesh.Mesh([a[1],a[2],a[3],a[1],a[3],a[4]])
        mesh=Mesh.Mesh()
        mesh.addMesh(m1)
        mesh.addMesh(m2)
        mesh.addMesh(m3)
        mesh.addMesh(m4)
        mesh.addMesh(m5)
        shape = Part.Shape()
        shape.makeShapeFromMesh(mesh.Topology,0.05)
        solid = Part.makeSolid(shape).removeSplitter()
        myWedgei='x' + str(P1x) + 'y' + str(P1y)+ 'z' + str(P1z)
        f = App.activeDocument().addObject("Part::Feature",myWedgei)
        f.Shape = solid
def myTxtXYZ(P5x,P5y,P5z):
        myWedgei='x' + str(P5x) + 'y' + str(P5y)+ 'z' + str(P5z)
        p5 = FreeCAD.Vector(P5x,P5y,P5z)
        myText = Draft.makeText(myWedgei,p5)
        myText.Label = myWedgei
b=1
h=1
P1x,P1y,P1z,P2x,P2y,P2z,P3x,P3y,P3z,P4x,P4y,P4z,P5x,P5y,P5z=myPyramidCal(0,0,b,h)
Gui.activeDocument().activeView().viewAxonometric()
Gui.SendMsgToActiveView("ViewFit")
Error msg
Traceback (most recent call last): File "xxx.FCMacro",
line 66, in myPyramidSld(P1x,P1y,P1z,P2x,P2y,P2z,P3x,P3y,P3z,P4x,P4y,P4z,P5x,P5y,P5z) File "xxx.FCMacro",
line 34, in myPyramidSld a =[[x,y,z], #dummy : global name 'x' is not defined
TheMarkster
Re: why 1pyramid?(4)array or class
Postby TheMarkster » Fri Apr 27, 2018 8:05 pm
The error you are getting is because you are trying to access x, y, and z, but there are no such variables either local to the function, global to the script, or being passed in as parameters to the function. Simplest fix for this is to just pass x, y, and z in as parameters to that function.
Example (bad)
def myFunction():
    xMin = x #error because there is no such x
Example (good)
def myFunction(x):
    xMin = x #okay because x is passed in as parameter
Example 3 (good) (creates global x, readable within the function)
x = 1
def myFunction():
    xMin = x #okay because x is global variable accessible (read only) from within function
If you decide to create a global x (as in example 3) keep in mind if you want to change x inside a function you will need to use the global keyword.
Example 4 (bad if you want to change global x inside function)
x = 1 #global x
def myFunction():
    x = 2 # does not change global x (no error message, but only creates new local x and sets it to 2)
print x #output is 1
myFunction()
print x #output is still 1 (can be source of many python bugs)
Example 5 (good if you want to change global x within function)
x = 1 #global x
def myFunction():
    global x #tell python you want to change global x, not create new local x
    x = 2 #changes global x
myFunction() #changes global x to 2
print x #output is 2
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
mrrclb48z
Postby mrrclb48z » Wed May 02, 2018 6:42 am
Thank you.
full script :
import FreeCAD
import Part
import DraftTools
import Draft
import Mesh
        x = float(xIn)
        y = float(yIn)
        b = float(bIn)
        h = float(hIn)
        x2 = x+b*0.5
        y2 = y+b*0.5
        x3 = x+b
        y3 = y+b
        z = 0
        z2 = h
        P1x=x
        P1y=y
        P1z=z
        P2x=x
        P2y=y3
        P2z=z
        P3x=x3
        P3y=y3
        P3z=z
        P4x=x3
        P4y=y
        P4z=z
        P5x=x2
        P5y=y2
        P5z=z2
        xDummy=0
        yDummy=0
        zDummy=0
        a =[[xDummy,yDummy,zDummy],          #dummy
            [P1x,P1y,P1z],
            [P2x,P2y,P2z],
            [P3x,P3y,P3z],
            [P4x,P4y,P4z],
            [P5x,P5y,P5z]]
        mesh=Mesh.Mesh()
        mesh.addMesh(m1)
        mesh.addMesh(m2)
        mesh.addMesh(m3)
        mesh.addMesh(m4)
        mesh.addMesh(m5)
        f.Shape = solid
b=10
h=10
P1x,P1y,P1z,P2x,P2y,P2z,P3x,P3y,P3z,P4x,P4y,P4z,P5x,P5y,P5z=myPyramidCal(0,20,b,h)
TheMarkster
Postby TheMarkster » Sat May 05, 2018 6:06 am
One of the faces is missing. I made this change to your code:
        m3 = Mesh.Mesh([a[1],a[5],a[2]]) #was 1,5,4, but was already a 4,5,1
mrrclb48z
Postby mrrclb48z » Tue May 08, 2018 1:32 pm
Thank you.
full script:
import FreeCAD
import Part
import DraftTools
import Draft
import Mesh
        x = float(xIn)
        y = float(yIn)
        b = float(bIn)
        h = float(hIn)
        x2 = x+b*0.5
        y2 = y+b*0.5
        x3 = x+b
        y3 = y+b
        z = 0
        z2 = h
        P1x=x
        P1y=y
        P1z=z
        P2x=x
        P2y=y3
        P2z=z
        P3x=x3
        P3y=y3
        P3z=z
        P4x=x3
        P4y=y
        P4z=z
        P5x=x2
        P5y=y2
        P5z=z2
        xDummy=0
        yDummy=0
        zDummy=0
            [P1x,P1y,P1z],
            [P2x,P2y,P2z],
            [P3x,P3y,P3z],
            [P4x,P4y,P4z],
            [P5x,P5y,P5z]]
        m1 = Mesh.Mesh([a[1],a[2],a[5]])
        m2 = Mesh.Mesh([a[2],a[3],a[5]])
        m3 = Mesh.Mesh([a[3],a[4],a[5]])
        m4 = Mesh.Mesh([a[4],a[1],a[5]])
        mesh=Mesh.Mesh()
        mesh.addMesh(m1)
        mesh.addMesh(m2)
        mesh.addMesh(m3)
        mesh.addMesh(m4)
        mesh.addMesh(m5)
        f.Shape = solid
b=10
h=10
