Testing it with a sketch with 3 edges returns something below... and seem to be something Abdullah mention earlier...?
- Further test show this Tag behaves interestingly... It return a UUID kind of string, unlike the Geometry[index] / Shape.Edge[Index]..
(sorry, i can't read c++ and a beginner in python only, so what I can do is lengthy trial and error below...)
>>> se1=s.Geometry[0] >>> se2=s.Geometry[1] >>> se3=s.Geometry[2] >>> >>> se1.Tag 'a5ee5ee6-7937-4873-925f-579d1d8be4b8' >>> se2.Tag '49e613b7-a5dd-474d-a16b-52d15e7cefc3' >>> se3.Tag '8181cc10-e04b-4384-8115-54219c49078e'
- Now delete '2nd' edge... assign and read the Tag again... no '3rd' edge of cos.
... now the geometry index 'shift', which is kind of 'topological issues' / problem?, referencing to same index leads to wrong element..
... but seem the Tag is 'constant' right?
>>> s01=s.Geometry[0] >>> s02=s.Geometry[1] >>> s03=s.Geometry[2] Traceback (most recent call last): File "<input>", line 1, in <module> IndexError: list index out of range >>> >>> s01.Tag 'a5ee5ee6-7937-4873-925f-579d1d8be4b8' >>> s02.Tag '8181cc10-e04b-4384-8115-54219c49078e'
- Then, w/o saving it, close it and re-open it (i.e. keep 3 edges)...
... so it seem the Tag is generated each time the file is opened, but never change (unlike the geometry or shape.edge index which change) when some edges in the middle are deleted.
>>> se1.Tag '622356c1-5d35-401d-8e49-3eb8ec26e973' >>> se2.Tag '61d5bc7c-055b-417d-a41c-33032ad1499b' >>> se3.Tag '7833b3c9-2ebf-45c9-96ef-38c576a0e0ee'
(Which I am hoping Realthunder's Sketch Export feature would have solved it all along...!) one of missing pieces in the puzzle!
EDIT: https://forum.freecadweb.org/viewtopic. ... 32#p214271abdullah wrote: ↑Sat Feb 10, 2018 8:47 amThe code is this (src/Mod/Part/App/Geometry.h), see getTag() below and the protected functions:paullee wrote: ↑Sat Feb 10, 2018 8:03 am
I am interesting in the 'unique identifier' you mentioned, hope somebody can help looking in the code and use it. My test to use the convoluting workflow: datum constraints+expression engine+reference datum constraints is not productive though works. I guess the 'unique identifier' would make resolve it fundamentally.
Thanks anyway.
class PartExport Geometry: public Base::Persistence { TYPESYSTEM_HEADER(); public: virtual ~Geometry(); virtual TopoDS_Shape toShape() const = 0; virtual const Handle(Geom_Geometry)& handle() const = 0; // Persistence implementer --------------------- virtual unsigned int getMemSize(void) const; virtual void Save(Base::Writer &/*writer*/) const; virtual void Restore(Base::XMLReader &/*reader*/); /// returns a copy of this object having a new randomly generated tag. If you also want to copy the tag, you may use clone() instead. /// For creation of geometry with other handles, with or without the same tag, you may use the constructors and the sethandle functions. /// The tag of a geometry can be copied to another geometry using the assignTag function. virtual Geometry *copy(void) const = 0; ...
EDIT: https://forum.freecadweb.org/viewtopic. ... 30#p216875realthunder wrote: ↑Sat Feb 24, 2018 9:11 amYes, it calculates the name of external edge by hashing linked object_name+element_name. You can delete the external edge, and later link back to the same edge, the name stays the same. However, to have a complete safe external link, you still need the linked object to have a stable topological name, and I plane to work on that too.[*]It seem edges are now using 'unique identifier' that would not repeated / recycled right? And it become safe again to use Link to External Edges right?
