So I'm trying to sort out how to watch another object for changes in it's properties. Essentially, I'm creating a FeaturePython object which takes a Line object as a child. I'm using the FeaturePython object to store metadata about the line, for example, it's bearing w.r.t the unit Y axis.
So, the Bearing property of the FP object, then, needs to update whenever the Line object changes...
Watching an object for property changes
- Joel_graff
Re: Watching an object for property changes
Should be able to use setExpression() to do it. For example, given an object named Cylinder and another named Line, if we wanted Cylinder's Height property to always be equal to Line's Y2 - Y1 value:
App.ActiveDocument.Cylinder.setExpression('Height',u'Line.Y2-Line.Y1')
What about using a App::PropertyLink property to have your FeaturePython object "triggered" when the Line object is changed :Joel_graff wrote: ↑Fri Jun 15, 2018 4:46 pm So I'm trying to sort out how to watch another object for changes in it's properties. Essentially, I'm creating a FeaturePython object which takes a Line object as a child. I'm using the FeaturePython object to store metadata about the line, for example, it's bearing w.r.t the unit Y axis.
class myFeaturePythonProxy(object):
def class __init__(self, fp):
fp.addProperty("App::PropertyLink", "LineObject", "myFP","Link to Line object")
fp.addProperty("App::PropertySomething", "Bearing", "myFP","Bearing")
def execute(self, fp):
# usually, execute is run whenever one of its child objects is touched.
update_bearing_property(fp)
# ... usual code here
def update_bearing_property(self, fp):
# check fp.LineObject properties
fp.Bearing = ... something
you can simply install a document observer which is called when a object changes. I did not find a python example, but in the cpp file you can see the kind of functions that are exposed:
https://github.com/FreeCAD/FreeCAD/blob ... erPython.h
- Joel_graff
Fascinating. I'll keep that in mind. I'm starting to sort the problem out, but if I can't solve it, this might do the trick...
- Joel_graff
[SOLVED] Watching an object for property changes
Solved this. The trick was to create a group object and add the object to be watched as a child. This triggers an auto update of the parent.
