Generating a voxel representation of a CAD model
In my project, I am trying to voxelize a 3D CAD model to a (lets say a30 x 30 x 30) voxel grid.
I have a collection of models in STEP file format, which I am able to load into FreeCAD. Below is my current plan.
Create a bounding box around cad model, divide the box into voxels, do a boolean intersection of each voxel with CAD model geometry, and return the fraction of voxel filled by the model for each voxel.
Parts workbench has the boolean operations I need, but since I am very new to FreeCAD, I wanted to know what people here think.
I would like to find out if someone here have previously done voxelization in FreeCAD, if so what was your approach.
Re: Generating a voxel representation of a CAD model
Thanks for sharing that post. I did look at that post, during my research on how to approach my problem using FreeCAD. That workbench is specifically for drawing using voxels.
My project instead is voxelizing a given 3D model.
Maybe this offers some insight. https://forum.freecadweb.org/viewtopic. ... 10#p136893
"fight the good fight"
Thanks for the links.
To put more context, here is an example of what I am trying to do,
This is a simple rectangular plate with a hole.
Below is a visualization of volume fractions, with 40x40x4 regular voxel grid.
- microelly2
The function getVolume() will get the volume of the intersection of a cube and the object where the cube is placed at x,y,z relative to the object's boundbox xmin,ymin,zmin values.
I only did very minimal testing using the attached model.
Are you looking to make a model of the results are is your main interest just getting the data? If you try to model 40x40x4 little cubes that's 6400 objects, quite a lot for FreeCAD to try to deal with. The function above shows the box, which adds it to the document object, but I only did it to be able to see where the box was getting put. Performance will be better if you don't show the box every time through.
Here is slightly more complete example, with loops to generate the data. Enable report panel view to see the data.
import FreeCAD
import Part
def getVolume(object,x,y,z,cubeSize=1):
box = Part.makeBox(cubeSize,cubeSize,cubeSize)
bb = object.Shape.BoundBox
x1,y1,z1,x2,y2,z2 = bb.XMin,bb.YMin,bb.ZMin,bb.XMax,bb.YMax,bb.ZMax
targetX,targetY,targetZ = x1+x,y1+y,z1+z
if targetX > x2 or targetY > y2 or targetZ > z2:
raise StandardError('Out of bounds error.')
box.Placement = App.Placement(App.Vector(targetX,targetY,targetZ),App.Rotation(0,0,0),App.Vector(0,0,0)) #location, eular angles, center
intersection = box.common(object.Shape)
vol = intersection.Volume
Part.show(box)
return vol
obj = App.ActiveDocument.getObject('Cut')
vol = getVolume(obj,10,17,0)
import FreeCAD
import Part
box.Placement = App.Placement(App.Vector(targetX,targetY,targetZ),App.Rotation(0,0,0),App.Vector(0,0,0)) #location, eular angles, center of rotation
#Part.show(box)
return vol
#vol = getVolume(obj,10,17,0)
data=[]
for xx in range (0,40):
for yy in range(0,40):
for zz in range(0,4):
data.append([(xx,yy,zz),round(getVolume(obj,xx,yy,zz),4)])
pass
for d in data:
FreeCAD.Console.PrintMessage(str(d)+'\n')
- plate-with-hole.FCStd
- (9.32 KiB) Downloaded 82 times
Yes. My main interest is just getting the data.Are you looking to make a model of the results are is your main interest just getting the data?
In that case I think FreeCAD will be up to the task. It's when you start trying to add large numbers of objects to the document when performance begins to lag. If you only need the data there's no need to display all the cubes, except during testing/debugging, and even then perhaps a random sampling will suffice. 40x40x4 = 6400 objects, too many for FreeCAD to easily manage in the document tree, but if you randomly add 1 in every 10 that brings the number down to a more manageable 640 (on average). The actual data will use all the cubes, but only 1 in 10 would be displayed with the code below.
import FreeCAD
import Part
import random
from PySide import QtCore,QtGui
if random.randint(1,10)==1:
Part.show(box)
b = App.ActiveDocument.ActiveObject
color = vol/float(cubeSize**3)
b.ViewObject.ShapeColor=(color,color,color) #grayscale
return vol
data=[]
QtGui.QApplication.processEvents()
pass
for d in data:
